Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle > Stella's Kitchen
Old 06-13-2007, 01:58 PM   #15
Aria
Aria's Avatar
Profile:  1967 20' Globetrotter
Sauquoit , New York
We use a Revere Copper Bottom perculator. We grind our coffee beans before we leave and place them in a sealed container. Perk on the propane stove.
Aria is offline   Reply With Quote
Old 06-13-2007, 02:07 PM   #16
bobandcarla
bobandcarla's Avatar
Profile:  2005 25' Classic
Pelham , New Hampshire
French press
We just got a french press with an insulated pot and it's shiny! We grind at home if we are boondocking. Cleanup isn't all that bad and it makes great coffee.
Bob & Carla
05 classic 25'
WBCCI # 1836
bobandcarla is offline   Reply With Quote
Old 06-13-2007, 03:29 PM   #17
SilverRanger
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
Same as Bob & Carla. We use the French Press at home and on the road. Water is heated in shiney stainless pot, then pressed. The press doubles as a vacuum insulated carafe, so it stays warm for a long time.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WBCCI# 4582
WDCU
SilverRanger is offline   Reply With Quote
Old 06-13-2007, 03:32 PM   #18
FreshAir
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
Originally Posted by BamCamper
I use a similar method...heat the water on the stove top and then pour through a Melitta type cone filter into a stainless thermos. It stays hot for hours.
(Hi janetb!)
Oh, Laura, thank you. My brother in law gives of-the-wall gifts with all the gift giving opportunities. A couple of months ago I unwrapped my birthday gift from him anticipating another wierd gift. He did not disappoint me. NOW I am not disappointed thanks to your post. I unwrapped an old collectible type ribbed aluminum thermos, with a cork for a stopper and red cup cap. I am not a coffee junky but do enjoy a morning cup occassionally. With a smiley blank stare I said "Thank you, Steve?" In his explanation he said,"For your Airstream." NOW I will carefully place it into our Airstream.
Neil.......and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
Lake San Antonio, 10/07
'Cover Photo'
1966 Trade Wind
455 cid
Old 06-13-2007, 04:13 PM   #19
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
We're from Santa Monica (where the foam meets the flakes) and as such we don't drink no coffee out of pots (just allow me to Vente a little)! We, bean' gourmets, only drink brew from just ground beans that have been carefully packed to prevent bruising. We would roast fresh beans, but the aroma brings the weak-willed sniffing around the door and if we give them any coffee, they're likely to whine about not being able to sleep. Since we dont have 110V when boondocking, we simply crush each individual bean with a pair of vice-grips or and use individual filters made from virgin wood pulp (G** forbid recycled-you just don't know where it's been). Tedious you say? Maybe, but counting the beans gives accurate reproducibility from cup to cup. There is no accounting for taste among bean counters! If part of a cup is allowed to get cold (we would normally throw it the street if we were in town and go back to Star*****) I simply stck the antenna for my handheld CB (linear amp'd, of course) and press talk. The RF(maybe it's BS, I forget) does the rest SALUD! Gosh! This is such an exciting topic. I think I'll go make a cup of coffee and try to calm down.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-13-2007, 04:38 PM   #20
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
On the boat, we heat water in a teapot and grind beans in a GSI Lexan Coffee Grinder sitting on a 33 ounce GSI Lexan JavaPress
Coffee is served in two 16 ounce wide-base Sea Bowld Stainless Steel Travel Mugs that keep it hot for quite awhile. The press also has an insulating wrap.
Coffee never tasted so good as it does when kicked back in the cockpit at anchor on a cool, calm morning out on the water.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 06-13-2007, 05:10 PM   #21
markdoane
Profile:  , Minnesota
Images: 59
All this talk about beans is giving me gas. Any good quality Arabica bean works for me.
My thing is the water. Here in Minnesota we have very good water quality. I use only untreated water directly from the Prairie Du Chien aquifer. No chlorates, thank you.
Non-contributing deadbeat.
markdoane is online now   Reply With Quote
Old 06-13-2007, 05:48 PM   #22
wheel interested
wheel interested's Avatar
Profile:  2007 27' Classic FB
Lapeer , Michigan
Images: 118
Nothing fancy, boil water in the teakettle, pour it into the thermos/travel cup and pop in a Folger's coffee single. Same routine I use for starting the morning from a rest stop, then hunt for a doughnut.
Carol
Mackinaw City Forums Rally October 3-5
wheel interested is offline   Reply With Quote
Old 06-13-2007, 05:56 PM   #23
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
Saint Paul, MN tap water comes out at 8.4pH and is so alkaline an alka-seltzer nearly levitates above the water with a whirring noise, and dissolves in about twenty seconds... and when summer algae blooms in the shallow lakes they use for summer supplement it smells like a fishing pond straight from the tap... Its a buck a gallon for decent water in this neck of the woods...
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Old 06-13-2007, 06:20 PM   #24
markdoane
Images: 59
Originally Posted by Wabbiteer
Saint Paul, MN tap water comes out at 8.4pH and is so alkaline an alka-seltzer nearly levitates . . .
The last lab report was even higher than 8.4pH. Minneapolis and St Paul both use the Mississippi River and surface water.
Water from the Prairie Du Chein aquifer may be hard, but it doesn't stink in the summer.
Old 06-13-2007, 06:36 PM   #25
Goin camping
Profile:  2007 25' Safari FB SE
valencia , California
Originally Posted by ScottW
I use the propane stove to heat water and brew the coffee in a french press. Can also heat water on one of our coleman white gas stoves, outside.
Don't make more than we can drink in one sitting, so keeping it hot isn't a problem.
^ Thats what we do too.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is offline   Reply With Quote
Old 06-13-2007, 10:08 PM   #26
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Hi, we have a pot just like the one in post #3; I think it is a Coleman. And we only use bottled water. Oh yeah, so far we haven't even used it yet, we have been useing the 110 volt coffee maker. We have not been without 110 power since we bought the stove top model.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 06-13-2007, 10:47 PM   #27
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
Wow I'm psyched
I'm a coffeeholic and the lexan grinder is a GREAT idea. The two best things for coffee are: Filtered water and Fresh beans freshly ground.
Even Starbucks admits that coffee is 99.7% water so while I do drink tap water without reserve, when traveling especially I use bottled for coffee. Let's face it, water tastes different in different areas, and what you carry in your fresh water tank can go a bit off too over time.
Paula
Today is a gift. That's why they call it "the present"
Old 06-14-2007, 07:10 AM   #28
Aria
Aria's Avatar
Sauquoit , New York
Interesting and informative...that's the Forum style. With our coffee we usually want some toast. How do you prepare toast? Aria
The Official Coffee Of Airstream moosetags Airstream "In the News" 35 12-15-2006 04:24 PM
Coffee Makers Tarheel General Appliance Topics 7 12-01-2004 09:33 PM
Coffee to go Turtle On The Road... 3 05-28-2004 11:00 PM
Newsweek Article On Vintage AS montanaandy Our Community 14 07-31-2003 02:15 PM
