Old 05-15-2011, 11:35 AM   #169
Airstreamer
J5MM's Avatar
2012 27' FB International
Bellevue , Washington
Images: 78
I go to Goodwill a lot and found these mugs which are made of enamelware (sp?) and they are from Pottery Barn. I was so surprised to find out how these mugs keep hot beverages, well, so hot and for such a long time. Plus they are lightweight and very very durable. This is how we make our coffee:
{blog}Just 5 More Minutes to Enjoy Non-Stop Outdoor Adventures and Culinary Discoveries in the Northwest with our Airstream ★Blogger for GoRVing.com
J5MM is offline   Reply With Quote
Old 05-15-2011, 12:43 PM   #170
Mexray's Avatar
1978 28' Ambassador
Morada , California
This is what works for me.... It's also great for distilling small batches of sour-mash to fill up my mason jar servers...
Ray & Pat; Morada, CA
Old 05-15-2011, 01:24 PM   #171
2010 25' FB Flying Cloud
Davenport , Iowa
I thought this was camping. I make campfire coffee over the camp fire.
I have a large enamel coffee pot , NO insides. I use 2 gallons of water and bring to a boil. next add 1 lb of coffee and add it SLOWLY as not to boil over. next take one egg and break it shell and all to the coffee. Put the lid on and boil for another 10 minutes. This will last on the fire all day or until empty. Serves 8 - 10 people.
I leave the pot and ingredients out and the one who empties or up first in the AM starts the next pot.
Airtandem is offline   Reply With Quote
Old 09-25-2011, 01:32 PM   #172
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Camp Coffee
I think Airtandem and I are on the same page on this one.
This pic is staged, I do use this older Coleman on the weekends to perk the small Coleman SS perk pot and it does a fine job, actually the best working perk pot I have owned others were aluminum.
But if we have a get together then THE BIG POT comes out and goes over the open fire. It is a Mirro 11 qt ( 2 3/4 gallon) boiler and it is a doozie. Get it boiling, reduce heat, add grounds, slow rolling boil, let it rest to settle and line em up. I don't think I would even waste my time trying this one on the Coleman.
To put a size with the pot, it is about 17" tall to the bail handle and about 11 1/4" wide at the bottom.
As far as using pots that you want to keep clean on an open fire, I just rub liquid soap on the outside of the pot/pan up as high on the pot as I think is necessary, but always below the rim. Soap don't taste so good. Clean up is really simple, rinse, scrub as needed with steel wool or Scotch Brite and minimum elbow grease.
Name:	Coffee's ready.JPG
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 09-25-2011, 01:55 PM   #173
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Here's My Coffee Maker WHen We Boondock
We had the best coffee at the White Sands Rally!
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 09-25-2011, 02:49 PM   #174
volvophile's Avatar
colorado springs , Colorado
Images: 14
If wer'e going to be on shore power, we bring our home unit, a 58mm La Pavoni Pro. It has a manual lever to press the water through the grounds, so with some practice, you can compensate for changes in humidity, altitude, grind, and oil in the beans. OK the real reason is, it looks cool, makes a mean espresso, and has a powerfull steamer.
For boondocking I'm trying out 2 different setups. The first is a lexan camp espresso maker I got from the clearance table at REI. It has a normal grouphead setup for the ground and a chamber for hot water that seals tight, and a hand pump to preasurize the water chamber to run the water through the grounds. I couple that with and stove-top steamer for making mochas, latte's and hot chocolates for the kids. The other rig I've been tinkering with is a Bellman CX-25 (theyve had a dozen different names over the last few decades, but thats what theyre being sold as nowadays) I still need some more practice with that one however because results have been spotty. If its just coffee for me, Ill cheat and use those Starbucks Via packets. Just need hot water, no mess, little fuss and nothing to throw away except for the little pouch, which by the way, makes a handy spoon to stir it with
Champagne wishes and Caviar dreams!
Budwieser budget.
volvophile is offline   Reply With Quote
Old 09-25-2011, 03:24 PM   #175
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Keep it simple...
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-25-2011, 03:31 PM   #176
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Had One th the Sixties...
Originally Posted by ROBERT CROSS View Post
Keep it simple...
...and forgot all about it. I loved it. Can you still buy these?
Ken L
1966 Tradewind 24
Old 09-25-2011, 04:30 PM   #177
Overland Adventurer
The Manfam's Avatar
2009 34' Panamerica
2004 34' Classic S/O
Thin Air , Rocky Mountains
Cafe
I use the entire garage of my Panamerica for mine.......
If overland travel was easy, everyone would do it....
The Manfam is offline   Reply With Quote
Old 09-25-2011, 05:04 PM   #178
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Yep! Chemex
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 09-25-2011, 06:16 PM   #179
A little history....It just seems right with the Airstream.
"How's the coffee???"
"excellent"
PFC
RLC
Old 10-02-2011, 05:43 PM   #180
Winder , Georgia
Trader Joe's coffee is awesome! Big fan of the house blend....
blackhawksid is offline   Reply With Quote
Old 10-02-2011, 06:48 PM   #181
Badger65's Avatar
1965 20' Globetrotter
Edmonton , Alberta
Images: 11
We've been cheating....http://www.amazon.com/Starbucks-VIATM-Ready-Colombia-Coffee/dp/B001UHHXU2[/URL].... boiled water, splashed with this... in an insulated MEC cup.... seriously? I am fussy... but this morning sipping on this, with a Globe and Mail newspaper, tucked into the gaucho.... perFECTion...
Badger65 is offline   Reply With Quote
Old 10-02-2011, 07:48 PM   #182
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
Campin' Coffee
Six-cup percolator on camp stove or inside stove. Pour first cup over hands to wake up. Drink next cup. Pour the rest in the thermos. It's usually gone before it gets cold.
We do admire the other more elegant coffee prep above - it's all great stuff.
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
gsmithii is offline   Reply With Quote
The Official Coffee Of Airstream moosetags Airstream "In the News" 40 03-17-2009 06:26 AM
Coffee Makers Tarheel General Appliance Topics 7 12-01-2004 09:33 PM
Coffee to go Turtle On The Road... 3 05-28-2004 11:00 PM
Newsweek Article On Vintage AS montanaandy Our Community 14 07-31-2003 02:15 PM
