03-14-2016, 02:37 PM
#621
Displaced Beach Bum
2016 30' International
Texas Airstream Harbor
We carry a George Foreman electric grill so we do not have the mess of cleaning a grill for travel. Stores well and since it cleans well with removable grates no greasy smell when stored.
We drag Mitzi a 2016 International 30 w/Goodyear Endurance, Equalizer 1000, pulled by a 2018 GMC Sierra 1500 SLT 4x4, Crew Cab, 5.3L V8 ECOTEC3, 3.42 axle, 8 speed auto WBCCI #6111
03-15-2016, 08:47 AM
#622
1973 Argosy 24
Kitchener
, Ontario
As long as you camp near a current bush, that'll play. Might as well just use a fry pan.
04-03-2016, 09:36 PM
#623
2016 30' Classic
Lorton
, Virginia
I've ruled out the Cobb. Uses Teflon coated parts, yeesh!
04-10-2016, 07:00 PM
#624
2016 30' Classic
Lorton
, Virginia
Decided on the Lodge cast iron charcoal grill and it's inbound.
04-10-2016, 07:08 PM
#625
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale
I ended up with a Mini Big Green Egg. BGE just came out with the Mini carrier just like the MiniMax.
05-02-2016, 06:19 PM
#626
Sag Harbor
, New York
I see via your earlier link that this grill weighs 32 pounds. Yikes!
Are you happy with it, and especially with the height adjustment? Do you carry it in the tow vehicle?
Our FC20 has limited weight carrying abilities, so we use the small round Weber charcoal grill, in part for its light weight.
Peter
05-02-2016, 07:27 PM
#627
2021 25' Globetrotter
Jamestown
, Rhode Island
Peter
Until my back gives out I'm going to haul our Big Green Egg MiniMax at 65 plus pounds...
You haven't lived until you play with one of these!
Bruce
Loving our 2021 Globetrotter 25 and our 2022 Ford F-150 King Ranch 5.0!!! Plenty of payload, not even close to axel limits and it drives and rows beautifully…
05-02-2016, 07:35 PM
#628
Jamestown
, Rhode Island
Ribs!
Yummmm...
Bruce
05-02-2016, 07:40 PM
#629
Sag Harbor
, New York
Looks great, thanks!
05-02-2016, 09:08 PM
#630
2023 Interstate 19
Scottsdale
That will be my next BGE!
05-02-2016, 09:12 PM
#631
2016 30' Classic
Lorton
, Virginia
Peter
Yes, quite happy. Just made two steaks on it, delicious. The nice thing about it is it isn't very tall, making storage options plentiful. My Classic has side storage compartments for easy storage of the grill.
05-03-2016, 03:24 PM
#632
Sag Harbor
, New York
Thanks. Curious whether they offer any kind of cover/lid for this grill, like the Webers have? A lid enables "baking" in a grill which can be invaluable for thicker steaks, legs of lamb, and so forth. A small thermometer inside (or held on magnetically to the lid) aids in monitoring the "oven" temp.
05-07-2016, 11:44 AM
#633
2017 25' International
Carlsbad
Bruce,
How do you pack the BGE for travel?
I have a small BGE, 12" diameter. Some time I'd like to bring it along. My 27 FB has no space for it. It has to go in the bed of the truck. Do you remove the dome for travel?
05-07-2016, 01:17 PM
#634
2008 25' Classic
Full Time
I've got a mini BGE at home but I can't figure out how to regulate the temperature. Its either too hot or not hot enough despite fiddling with the top and lower vents. Maybe the smaller ones don't work as well. I just use it for burgers as they make a mess of my O'Grill.
Kelvin
05-07-2016, 10:52 PM
#635
Carlsbad
Kelvin,
The smaller eggs aren't really more difficult. The key is picking a temp, open the vents all the way , when you're 50 degrees and closing, start closing the vents and coast to 500.
It does take patience and practice.
05-07-2016, 11:01 PM
#636
Carlsbad
https://youtu.be/TOuA-NQ761U
I disagree with this video a little. I like to start closing the vents as I approach desired temp. It easier to raise the temperature than to reduce it.
Once you do it , you'll find the perfect degree of vent opening for top and bottom. Remember that the lid should stay closed...
Don't give up
05-08-2016, 02:08 AM
#637
Jamestown
, Rhode Island
Kelvin
Not sure about the Mini but both our MiniMax and large are fairy easy to regulate. In fact I prefer the MiniMax much of the time. It seems simpler to control at times....
One mistake I used to make was in not using enough hardwood charcoal. It needs enough or it won't come up to temperature.
Another issue can be that a given bag of charcoal can be a dud. Throw it away if you get a bad batch. It will simply frustrate you if you continue to use it...
Finally, the end of some bags contain more dust than chunks and this densely packed charcoal can create a situation where there is a lack of air flow resulting in a cold BGE... There is always a difference in the first of the bag new charcoal and the end of the bag old charcoal... Plan your airflow accordingly or simply use just the bigger chunks only.
Don't give up
You said let! It can take a looooong time for the temp to drop once you get it roaring.
Bruce
05-08-2016, 09:26 AM
#638
2023 Interstate 19
Scottsdale
The mini is like all the others. No issues with mine compared to my large.
05-08-2016, 10:06 AM
#639
2008 25' Classic
Full Time
Im using the BGE charcoal. Usually I light it with the top and lower vents open wide then walk away. I come back on its 600F. Maybe I don't know what temperature to cook with. So for burgers, a steak or chicken what is the best temperature. Another issue seems its too hot in the middle and the coals on the side are cooler. Is it better to start a starter stick to the side? Thanks
Kelvin
05-08-2016, 10:44 AM
#640
Carlsbad
I light in the center for direct cooking. For chicken I like 350 ,
Steaks a little higher maybe 500. The key is maybe coming back sooner and close them down to 50% ? Then watch.
After you get the hang of it you'll find that it's easy. When I slow cook, 225 ish , a pinky finger width on the bottom and 30% on top. You'll get it .....
Kind of like hooking up an Airstream!
