Old 07-14-2016, 09:05 AM   #659
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Volcano update
Originally Posted by loechli View Post
Another vote for Solaire Anywhere, I had used it as my only grill at home as well as traveling with my airstream, it is an Excellent grill!
I see the also now make a Solaire Anywhere mini.
http://solairegasgrills.com/products/portable-grills/
Steve
Used the new Volcano yesterday for first time. Very impressed at the quality of the unit and how it folds and stores. Cooking was using 12 coals, on top of the heating disk. Very impressed with heat distribution due to design of the conical sides. Steak was done to perfection in 10 min using cooking hood. I have not used gas yet, but happy so far.
gypsydad is online now   Reply With Quote
Old 07-15-2016, 05:39 AM   #660
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We are very happy with the "everywhere" model. It rides in t's carrying case the back of the Mercedes ML320 CDI along with an 12Vdc air compressor when we tow the 23D. We modified the fitting on one of the propane tanks so we can connect the grill to the tank with a long hose. That was easier at the time than an adapter to the front grill outlet of the trailer. We do use that propane grill outlet to power the Honda 2,000 watt generator. The stainless steel legs collapse and are stored in the sewer hose compartment on the back of the trailer.
Cooking times are much shorter than the Weber Q1200 we carry in the truck for the 31' Classic.
Old 07-16-2016, 09:04 AM   #661
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
I also like my Volcano. I added a piece of foil on the bottom for easier cleanup. Next up I will purchase a pizza stone. Tried to cook a pizza without it and lets just say its a work in progress.
LilNomad
LiLNomad is offline   Reply With Quote
Old 08-17-2016, 03:13 PM   #662
BirdDog's Avatar
2015 25' FB Flying Cloud
Carriere , Mississippi
Grease Grief
We have only made one trip in our Airstream and it was our first time camping http://www.airforums.com/forums/f42/...ke-153547.html. We had the Airstream for a year before we used it which gave me plenty of time to investigate cooking with grills. Our camping routine is to only spend a day or two or three in each stop. This is my grilling story.
Started out with the 2 burner Camp Chef with table and cover. You grill burgers and grease goes everywhere and is not easy to clean. It came with a 3-way manifold that leaked and became an attention getter. This was replaced with parts from Tejas Grill parts.
Not ready to give up on Camp Chef, I ordered aluminum GrillGrates which would sear the meat and burn off the grease. I gave up on this idea pretty quickly.
Next was the Lodge cook table with the Tuscan Grill. After cooking with this I discovered that it is not easy to clean and clumsy to store.
Everyone on this forum likes Dutch Oven cooking so I bought a 10" deep DO and like it for cooking.
Next and finally I have given up on open fire grilling and have decided to cook everything in a large Teflon pan over propane. This includes burgers and steaks. This unit is pricey but very well made of aluminum and stainless steel. It is used mostly by river rafters and 4X4 off road campers. https://adventure-ready.com/store/partner-steel-18-2-burner-propane-stove/.
It uses a 30psi regulator and cannot use the Airstream low pressure LP tap. It can produce a lot of heat.
No matter what you cook grease splatters everywhere. The burner and grate unit slide out so that the insides can be wiped clean with a paper towel.
Bon Appetit,
Joel
BirdDog is offline   Reply With Quote
Old 08-18-2016, 02:43 PM   #663
Sainte-Julie , Quebec
Napoleon
Travel Q is nice
laperrl is offline   Reply With Quote
Old 08-18-2016, 04:23 PM   #664
Long Island , New York
Just finished a delicious burger off our old Weber Smokey Joe 14" charcoal grill. In the vein of Keep It Simple, Stu, this grill can't be beat! Unfortunately the new 14" ones do not have vent holes in the bottom, like the larger 18" model does.
https://www.amazon.com/Weber-40020-P...558740&sr=1-11
No clean up other than to brush off the grill when hot just before the next use. Fits in our plywood go-box in the back of the van, along with charcoal and a starter chimney.
OTRA15 is online now   Reply With Quote
Old 08-18-2016, 06:11 PM   #665
FCStreamer's Avatar
2014 30' Flying Cloud
I was all set to get the Weber Q1200 when I ran into this one at Lowes.
https://www.amazon.com/Char-Broil-TR...broil+portable
It's the Charbroil Grill2Go. I just purchased a slightly larger model for my campsite.
http://www.ourflyingcloud.com/2016/0...ing-grill.html
I was intrigued by the IR marketing, and having used my campsite grill I'm a believer. So I saw the smaller portable version cheaper than the Weber and I was sold.
I'll let you guys know how it turns out.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2013 Cadillac Escalade Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 08-19-2016, 10:11 AM   #666
Hampton , Virginia
I had the 14" model for tailgating. Didn't like how it heated or cooked. Not enough air flow for me. Tried the 18" and love it.
Getaways is offline   Reply With Quote
Old 08-19-2016, 10:12 AM   #667
Did yours have the air vents in the bottom, like our older 14" one does? Makes all the difference. When this one rusts out, will move up to the 18" probably.
Old 08-20-2016, 06:01 AM   #668
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
We got the standard weber smokey joe and can cook for 2-4 on it.
If you get one, check out the zippered carry bag for it on Amazon. Really nice for storage.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 08-22-2016, 09:45 AM   #669
2014 19' Flying Cloud
Livingston , Texas
Been following this grill quest for sometime. I currently have a charbroil infrared tabletop. It's just to large and cumbersome to take with us. While in Menards home supplies store I found a small compact grill by Coleman called a "fold and go" it was only $30 so I took a chance. Wow, what a great grill. I've cooked steaks etc. and all have turned out great. I purchased the carry case, the wire grill for coffee pot our stews etc.and the solid griddle. We love it and it just great for the two of us. Go see the YouTube videos reviews. Easy cleanup also.
Munchie is offline   Reply With Quote
Old 08-23-2016, 08:02 AM   #670
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Texas Airstream Harbor , Texas
Send a message via Skype™ to beachbouy
Overwhelmed researching grills
Looking at grills that connects to low pressure propane supply and very easy to clean and very portable.
Looking at Camco 57305 Olympian 5500 Stainless Steel Portable Grill but open to suggestions.
Has anyone converted the Char-Broil TRU-Infrared Portable Grill2Go Gas Grill to connect to low pressure propane?
We drag Mitzi a 2016 International Serenity 30 with Goodyear Endurance shoes, with an Equal-i-zer 1000 yanked around with a 2015 GMC Yukon XL SLT 4x4, 5.3L V8 ECOTEC3, 3.92 axle, 6-speed auto WBCCI #6111 AIR #107335
beachbouy is offline   Reply With Quote
Old 08-23-2016, 06:20 PM   #671
Livingston , Texas
Beachbouy I connected my charbroil grill 2go to my quick connect on the trailer with no problems. My local gas company will make any hose with connectors. Had him make me one - hooked up - did some steaks. Didn't change anything.
Old 08-24-2016, 03:05 PM   #672
2015 23' Flying Cloud
Livermore , California
I ordered a Weber Q conversion kit from Calore with 120" hose and ended up going with a BGE. If anyone want this kit please PM for details.
http://caloreequipment.com/products/...-trailers.html
cactusjk is offline   Reply With Quote
What grill do you use? 6xblessd Stella's Kitchen 62 10-26-2014 08:18 AM
Where Do You Store Your Grill????? StanandLynn Our Community 36 08-21-2008 03:15 PM
New outside propane grill for my 67 Overlander bighowdytex Our Community 8 01-07-2008 12:08 PM
Broken Grill toaster one General Motorhome Topics 4 08-06-2006 07:40 AM
