Old 03-08-2016, 01:53 PM   #603
Long Island , New York
Sure enough! I would like to see one in operation.
Old 03-08-2016, 02:11 PM   #604
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Metairie , Louisiana
There are plenty of videos online of demos and reviews. Here's one…
WBCCI #1105
TAC LA-4
Engineering: Finding complex solutions to simple problems you didn't even know you had.
Old 03-08-2016, 02:30 PM   #605
2016 25' Flying Cloud
Holly Springs , Mississippi
After trying many different makes, my favorite is the Binford 240 volt Pro 5000 XL with 6-speed fan, auto turn rotisserie and surround sound.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 03-08-2016, 04:13 PM   #606
Thanks Protagonist.
Do you know if any of the models have a fold-up carrying handle like the small Weber grills? It is handy to carry things in one hand especially on uneven ground.
I use my round Weber charcoal grills (both small and large) as both a grill and oven -- by banking the coals on one side, and using a magnetic thermometer on the side of the cover to regulate draft and temperature. As you observe, the best meats are mostly baked, but that initial blast of high heat to sear them is important IMO.
Thanks again for the video.
Peter
Old 03-08-2016, 08:20 PM   #607
2015 23' Flying Cloud
Livermore , California
What length of hose is recommended if we want to connect into the AS connector? Using a Weber Q1200 with a Calore quick disconnect conversion kit.
cactusjk is offline   Reply With Quote
Old 03-08-2016, 09:31 PM   #608
No, the Cobb doesn't have a built-in carry handle. But it comes in a carry bag that has handles.
Being stainless steel you can't use a magnetic thermometer stuck to the side. And due to the shape you can't bank the coals on one side; they're permanently in the middle. So you don't really get temperature regulation, either. Can't have everything.
WBCCI #1105
TAC LA-4
Old 03-08-2016, 09:34 PM   #609
2016 30' Classic
Lorton , Virginia
The Cobb is new to me -- here is some Cobb Salad to munch on FYI:
Cobb Salad
http://www.cobbglobal.com/cobb/
Looks pretty neat . . . and efficient.
PS Protagonist does the grill grid cooking surface get hot enough to put a sear on steaks first? Thanks
The Cobb looks pretty nice! I don't care for LP grilling and prefer charcoal.
For you Charcoal grilling Airstreamers, is the Cobb about the best out there or any other favorites? Any portable charcoal grills that use LP to start?
Zybane is offline   Reply With Quote
Old 03-09-2016, 06:48 AM   #610
1986 31' Sovereign
Miami , Florida
The Cobb is a PIA to clean, though. All the fat runs down into a moat. I could never figure out how to dump the moat without dumping the ashes and making a mess or vice versa.
Other than that, it works great for small meals.
Mike
Old (usually dirty) Nissan Titan
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 03-09-2016, 06:53 AM   #611
We go with the small round Weber charcoal grill. Keep It Simple Stu.....
14" Weber Smokey Joe
But no carry handle. We have a dedicated plywood box in the back of the van to store the (cooled) grill with no clean-up at all, except for brushing the grill top (hot) right before the next grill session. Quick and easy . . . again . . . KISS.
The rectangular Weber Go Anywhere is another option:
Go Anywhere
Which does fold up with a carry handle. One drawback to this second grill is that it does not have air vents in the bottom, which has the corresponding benefit of not releasing sparks on to the ground in forested areas.
We use a chimney to start the coals, but those petroleum pellets are also available, if you don't mind the petrochemical aspect . . . . . . A bunch of newspaper in the grill can get the charcoal started also, but with less consistency depending on wind.
Old 03-09-2016, 07:00 AM   #612
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I have seen 12' and 15' propane hoses. Airstream supplies one in new trailers about five feet long.
Old 03-09-2016, 09:47 AM   #613
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Anoter easy way to start a charcoal grill is with a portable blowtorch.
urnmor is offline   Reply With Quote
Old 03-13-2016, 09:55 AM   #614
2016 30' Classic
Lorton , Virginia
I think I may go with this for charcoal grilling:
http://www.amazon.com/gp/product/B00...f_rd_i=desktop
Made by Lodge (USA) and should last a lifetime. I am thinking about switching all my cookware over to cast iron.
Use a chimney for starting:
http://www.amazon.com/Weber-7416-Rap...8FZZVJY5K1HPPK
Old 03-13-2016, 10:08 AM   #615
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
That looks like an awesome grill!
An alternative way to start it might be to use the little grill starters like the ones Big Green Egg sells. They are easier to store than the chimney and they start ours every time...
Bruce B is offline   Reply With Quote
Old 03-13-2016, 10:28 AM   #616
Any ideas on how best to store a Weber Q 1200 such as an Actionpacker, etc?
What grill do you use? 6xblessd Stella's Kitchen 62 10-26-2014 08:18 AM
Where Do You Store Your Grill????? StanandLynn Our Community 36 08-21-2008 03:15 PM
New outside propane grill for my 67 Overlander bighowdytex Our Community 8 01-07-2008 12:08 PM
Broken Grill toaster one General Motorhome Topics 4 08-06-2006 07:40 AM
