Old 01-29-2016, 01:47 PM   #575
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Originally Posted by switz View Post
Reducing the image size will allow it to display in the proper orientation.
Thanks Switz. I never understood why I had that problem.
DoublTrouble is offline   Reply With Quote
Old 02-10-2016, 12:57 PM   #576
AI Joe's Avatar
Key Largo , Florida
Images: 11
Originally Posted by grizbear View Post
I carry two a cobb great for smoking, roasting, grilling uses only 8 to 10 bricquets comes with all in one carry bag. I also carry an O-grill that runs on propane when I'm in a hurry or places that don't allow fires of any kind. Starts first time every time comes with a carry bag legs fold up lid locks slide in bag and go. Runs on any propane source 20b tank or any of the 1lb bottles. Good camping all. Rand
We also just bought an O-Grill 500 for our new AI EXT GT - and we love it. Easy setup; clean-up and cooks great, especially if there is only two of you. Check out this on YouTube:
AI Joe is offline   Reply With Quote
Old 03-05-2016, 10:31 AM   #577
2015 23' Flying Cloud
Livermore , California
Torn between a Weber Q1200 and a Magma. Lots of good info in here.
cactusjk is offline   Reply With Quote
Old 03-05-2016, 08:31 PM   #578
Actually it is now between a Weber Q 1200 or a Big Green Egg Mini!
Old 03-05-2016, 09:38 PM   #579
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Couldn't decide. We ended up with the Weber Q1200 for our Airstream travels, and Big Green Egg MiniMax for home. Tried the BGE on one long trip but too heavy for convenience, and the ceramic possibly too fragile for extended travel. Probably a great weekender though.
Doug and Cheryl
Old 03-06-2016, 07:02 AM   #580
Starstream's Avatar
Spring , Texas
I have a Kingsford charcoal grill that looks like a small BBQ pit and prefer hardwood charcoal. I also have an oiless turkey fryer that runs on LP. (Supposedly cooks other things too. It was a gift from my daughter and son-in-law, and I haven't had an opportunity to use it yet.) My outside arsenal also includes a large cast-iron skillet and antique dutch oven. I wanted to keep my cooking options open depending on my mood or weather conditions.
Besides the new fancy stove with oven I have my eye on, I have a 3" deep electric skillet which is deep enough for frying and a Cuisinart multi-cooker in the 7 qt. size.
Our old 2-burner camp stove is likely to come too. Though I might just get the Coleman 2-burner stove with oven at some point. It has a battery-operated electronic ignitition which will make it much safer to operate.
Starstream is offline   Reply With Quote
Old 03-06-2016, 08:06 AM   #581
The only reason I am not jumping on the Q1200 is that BGE now makes a carrier for the Mini Egg like the carrier for the MiniMax. The Mini is small but might be good enough for the two of us. Also, the Mini weighs around 35 lbs.
How do you transport your Q1200? Wish Weber still made the duffle bags!
Old 03-06-2016, 08:29 AM   #582
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We went with the Solaire grill, stand and carrying case as it was very light. We carry it inside the Mercedes. We have a very long propane adapter hose and a propane tank adapter so the grill can be easily accessed and we do not have to carry any additional propane tanks.
In the truck where weight is not the issue, we carry both propane and a Weber Q2200.
These are two very different grilling styles, to put it mildly.
Old 03-06-2016, 11:26 AM   #583
I too have the Solaire. I made the mistake of ordering the low pressure hose and valve from Solaire in order to use the quick connect on the Airstream. It does work, but lacks the heat intensity of the standard LP setup. So, the moral to the story is, chasing technology is not always best. Switz, when you cook that Porterhouse on the Solaire, take it off 10 degrees lower than your target "doneness" wrap it I in foil, let it rest for 10 mins.
Old 03-06-2016, 11:41 AM   #584
lewster's Avatar
Naples, FL , Hood River, OR
I use Alton Brown's method on my Solaire for rib-eyes. 2 min. then turn 90 deg. Flip. Repeat above. Remove and let it rest 5 min.
Perfect medium every time for the last 16 years. 😄
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Old 03-06-2016, 12:40 PM   #585
Firedog1
Firedog1's Avatar
2018 30' Classic
Woodbridge Connecticut & , Venice Florida
I'm with you Lew. Perfect every time on the Solare
Russ and Lisa
2018 Classic 30
2015 F250 King Ranch 4x4 turbo diesel
Sold but not forgotten: 2005 Classic 25 Limited
2015 Classic 30 RB
Firedog1 is offline   Reply With Quote
Old 03-06-2016, 02:38 PM   #586
Starstream's Avatar
Spring , Texas
After reading thru many of the comments on this thread, old and new, (and including my earlier post) I'm thinking simple is good. Could there possibly be anything better than a Lodge cast-iron grill pan? Best non-stick ever, easy to clean, can be used anywhere (campfire or campstove), and lasts forever. I think I'll get mine back from my younger daughter.
Old 03-06-2016, 03:18 PM   #587
2016 25' Flying Cloud
Holly Springs , Mississippi
The Solaire's get panned by a lot of their owners (see Amazon ratings), and is a very expensive unit. Given the many poor reviews primarily focused on bad customer service and not honoring the warranty, just get a Weber Q1200 and be done with it.
You can make yourself crazy researching every possible portable cooker...
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 03-06-2016, 03:20 PM   #588
Exactly! I am not a big fab of IR on grills.
What grill do you use? 6xblessd Stella's Kitchen 62 10-26-2014 08:18 AM
Where Do You Store Your Grill????? StanandLynn Our Community 36 08-21-2008 03:15 PM
New outside propane grill for my 67 Overlander bighowdytex Our Community 8 01-07-2008 12:08 PM
Broken Grill toaster one General Motorhome Topics 4 08-06-2006 07:40 AM
