Old 02-21-2015, 02:44 PM   #505
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Originally Posted by IanPoulin View Post
pharm - the mini-max was released but only two or three months ago. Here in central virginia, only Green Top Sporting goods had them in stock at this point out of all the authorized dealers. 13" grill diameter, so enough for pies, cakes, roasts and sizable enough for good smoking work too.
The weight is 65KG, or 90lbs.
2011 Airstream International Serenity 28' - 30a/taupe
2013 Ford F150 v6-ecoboost with max tow and HD payload packages
I didn't think our MiniMax was that heavy so checked the spec's again, 63 lbs. or 28.5 KG. I can lift and move it on my own, or we both grab a side.
Doug and Cheryl
Old 02-21-2015, 03:06 PM   #506
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
The grill space on the previous mini I recall being 10 inches - 13 seems better
I'll keep this in mind for later on for sure !!!
The atoms of our bodies are traceable to stars that manufactured them...We are not figuratively, but literally stardust.
PharmGeek is offline   Reply With Quote
Old 02-21-2015, 04:56 PM   #507
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
I stand corrected -- thanks! editing my old post (if I can) to avoid confusions.
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 02-21-2015, 05:28 PM   #508
indy's Avatar
1962 22' Safari
kansas city , Missouri
Images: 22
DCmom, the volcano will work with a 10" DO Lodge I did get the Volcano cast iron flat Grittle made for it and the oven hood as well.
indy is offline   Reply With Quote
Old 02-21-2015, 09:08 PM   #509
IanPoulin's Avatar
Aldie , Virginia
Indy - good feedback! Now that I have baking/smoking out of the way for boondocking with the egg, I am looking at both the weber-Q and volcano for propane (and fire restricted area) cooking.
Old 07-04-2015, 10:43 AM   #510
urnmor's Avatar
Berlin , Maryland
Propane grill with good controls
I have been following this thread and read many of the posts, however I have not seen any comments on how well u can control the temp and flame with the knobs.
Anyway I am looking to replace my old two burner Coleman camp stove with a more modern propane grill. I would like one that can really control the flame and heat to cook eggs, pancakes and bacon. I do have a Cobb that uses charcoal however it takes to long to heat for breakfast.
I like the Cobb but will probably use the new grill also at night.
urnmor is offline   Reply With Quote
Old 07-04-2015, 02:26 PM   #511
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I used my babyq-1000 weber for bacon with a lodge cast iron griddle in it - cooked the bacon awesome
I did not try eggs yet - but will report back
My cast iron griddle has two sides - a flat side and a ridged side - I think you would need to be careful and not have it all too hot
As far as flame ups - the babyq does excellent in controlling these
Any tips from others on eggs on the babyq would be appreciated - but I played it safe and cooked my eggs on a Teflon skillet in the AS
Old 07-04-2015, 06:07 PM   #512
urnmor's Avatar
Berlin , Maryland
I will be interested to see your comments. I have done a significant search and have found little regarding temp control
Old 07-05-2015, 04:13 PM   #513
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Here's an idea for cooking those eggs...
Uses butane canisters. Many different brands available. Inexpensive, compact, and great for eggs! We don't carry a camp stove any more - just our trusty mini CharBroil BBQ and the butane saute stove.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 07-05-2015, 09:47 PM   #514
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Yeah - I've been wondering about something like this or induction cooktop for outdoor use
Old 07-06-2015, 06:31 AM   #515
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
As I shared- I just picked a grill and it has the control for eggs but as an electric option the induction is great but two things I found was that you need 1800 watts and cast iron. Funny thing is, while that wattage is what gives induction its claim to fast boil, low power with cast iron is critical if you don't want to scrape the food off the pan. I tried four different so-called induction cookware pans and they did not work! The disc base too small. Allclad works and cast iron. Considering grills weight and size is important. I keep leaving mine at home. Out of room.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-06-2015, 07:32 AM   #516
Mont Vernon , New Hampshire
I carried one of the single burners for years. FYI, you can get them very inexpensively at Asian markets ($30). Many Asians use them for their woks. The one I purchased has a beefy carrying case (but a bit larger than some other brands)
They also sell the butane canisters at the Asian markets in multi-packs.
Katy
bugsbunny is offline   Reply With Quote
Old 07-06-2015, 10:01 AM   #517
urnmor's Avatar
Berlin , Maryland
I also have an induction one burner and it works great owever I am looking for something that does not use elecric but can multitask ie cook ribs, pork butts, steaks at night and eggs bacon and pancakes in the morning.
I have seen some portable grills that are infrared but I have never used one. does anyone have experience with them and if so how do you like them?
Old 08-13-2015, 06:17 AM   #518
pickettmd's Avatar
2014 16' Sport
Franklin , Indiana
Thumbs up Grills
I have a Cobb charcoal grill. They are stainless steel and have a look that matches our Sport. They aren"t very big but great for two people and only use seven or eight pieces of charcoal to operate. Works as a grill or oven. Cobbgrillamerica.com
pickettmd is offline   Reply With Quote
What grill do you use? 6xblessd Stella's Kitchen 62 10-26-2014 08:18 AM
Where Do You Store Your Grill????? StanandLynn Our Community 36 08-21-2008 03:15 PM
New outside propane grill for my 67 Overlander bighowdytex Our Community 8 01-07-2008 12:08 PM
Broken Grill toaster one General Motorhome Topics 4 08-06-2006 07:40 AM
