Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle > Stella's Kitchen
Old 12-03-2003, 03:16 PM   #15
zduke4x's Avatar
Profile:
cheaper works too!
Was given a Charbroil 187 sq. inch cookerwhich is a small bottle grill and a hose conversion as a gift and for a cheap unit it has been remarkably good for a couple of people...supplemented by a George Foreman grill. Very small and portable...probably not what I would have bought initially but it does the job well for me...I believe about 30/35 dollars most anywhere...lol..jem
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
zduke4x is offline   Reply With Quote
Old 12-03-2003, 08:05 PM   #16
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
Let me add a vote for the Coleman Road Trip grill, which came with one grill and one griddle insert. We bought an extra grill insert, a stove insert, and the carrying case. This was on recommendation from one of my friends in the Winnebago club.
So far, it's replaced the old Char-Broil on the deck at the house. I was surprised to get five 30-40 minute cooking sessions on one little bottle with both burners going on medium.
It has a LOT of heating capacity to go with all that space... I've had the grill loaded up with burgers and brats, and it didn't take any longer than for a few. I'm told that extra heating capacity makes a big difference at higher altitude, where the Thermos Grill-To-Go can take forever.
NOTHING sticks to the grill or griddle. Easy to wipe clean.
It isn't perfect.
The water pan is a great idea, until you try to balance it and keep from spilling water (and nasty grease) when removing it. My friend told me to forget about the water, and just spray the pan with PAM. That's what they do. I tried it and it's GREAT!
The stand is a bit tedious to fold out and "assemble"... more annoying than a problem. But you don't have to use the stand if you have a picnic table. The stand does have adjustable feet for unlevel ground.
It's a fairly large unit, but we have plenty of truck bed, so that isn't an issue.
In summary, it's probably overkill for just two people, but if you like to party with a bunch of others over, it's really hard to beat.
Maurice
AB8XA
AIR # 804, WBCCI 5446
The Long, LONG Trailer
Paralleled Honda EU2000i
Old 12-03-2003, 08:21 PM   #17
47WeeWind's Avatar
Profile:  1948 16' Wee Wind
1964 19' Globetrotter
Denver , Colorado
Images: 13
Magma 14-1/2" dia. propane grill
I use the small size (14-1/2" diameter) stainless steel grill by Magma, available at West Marine. It mounts outside my 64 Globe Trotter just aft of the door (under the canopy for rain) and connects to the low pressure side of the large propane tanks on my trailer. In wintertime, I move the socket mount to a table just outside my house back door and hook it up to an old 30 pound propane tank & regulator, then grill. I like the small size and relative portability. It can be seen here:
http://www.westmarine.com/webapp/wcs...roductId=49613
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
47WeeWind is online now   Reply With Quote
Old 12-03-2003, 09:59 PM   #18
Moderator Emeritus
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
We use a Weber tabletop "Clone" we got at a discount store for $12. I also bought a butane powered single burner hotplate for $17 on Ebay.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 12-31-2003, 09:56 PM   #19
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Back up the thread aways, Brad mentioned the TEC grill listed in the Williams&Sonoma catalog. The price has come down a little to $419!
I've had a fullsize version of the TEC for a number of years and can vouch that it's a great grill. It's a breeze to use thanks to it's innovative design and it gets the job done fast without many flare-ups. I like that in a grill!
Pricey, but very nice...
-Dallas
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 01-01-2004, 09:06 AM   #20
Royce's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Check out the Woodflame. we have had the Delecto model for about 6 years now and couldn't be happier. Heats up fast, under 2 minutes, cooks hot enough to seal in juces, easy temp control and only burns hard wood chunklets for fuel. Packs into a carry bag. It is a forge principle using D cell batteries to run the fan and 2.75" square hardwood blocks for fuel. We use ours regular and get well over a year on four batteries. The grill is made in Canada and was designed orginally for camping. If you call ask for Karen and tell her Royce sent you. She was very helpful when I called in and had a bunch of questions.
The only dificulity I had was learning to light it. The directions are not as clear as they could be. I can now light it with one match and be cooking in less than two minutes. My mehod is one half sheet of news print crumpled in the bottom of the forge pot, hard wood block ready to drop in. Light paper, turn on the fan on high, drop the block and close up the grid.
No connection just a happy user, YMMV.
Check them out at Woodflame BBQ
Royce
Royce (KORKK) and Karen
AIR# 3913
'77' Minuet 6 Metre TV: '94' Wrangler, 4.0L inline 6, Ford 8.8 rear, NV4500 tranny, Old Man Emu suspension, 30x9.5 tires
Royce is offline   Reply With Quote
Old 01-01-2004, 09:15 AM   #21
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
The low-road
For years, I have carried a small charcoal grill that I bought at Cabela's in Sidney, Colorado while passing through from South Dakota. I guess the diameter at about 13". It has detachanble legs and a carrying bag and cost me all of about $12 as I recall. The grill is the perfect size for 2 people.
With the grill, I carry a bag of match-light charcoal with mesquite. If kept well sealed, the charcoal retains the match-light ability for a long time. A 10# bag usually lasts over a year.
If you haven't visited a Cabella store,you are in for a treat. It would take a half day to completely cover the store. A new Cabela's is currently slated for Buda, Texas, just 18 miles from my door and a stone's throw from my Airstream dealer. I can't wait.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 01-01-2004, 03:08 PM   #22
frozen chosen's Avatar
Profile:
Royce, thanks for the post; that grill looks very cool. No prices on the website.... Seems others are really just gas burners which hardly deserve to be called barbeque grills. Does the fan prevent hot spots, and can you maintain low settings or does the unit pretty much operate at v. high temps? Also, how long to the cubes burn and what are they made of? God knows WHAT is in "self-lighting" briquettes.
frozen chosen is offline   Reply With Quote
Old 01-01-2004, 03:26 PM   #23
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Thumbs up George Foreman propane grill
We used one of the cheapie $20 propane grills for years, and just carried it around in a cardboard box. When it got really nasty and rusty (usually two summers of hard use), we threw it away and bought another.
Last summer, after looking at the Colemans and the other brands of 'tailgater' grills for around $140, my wife found a "George" propane grill at the famous French retailer Tar-get' for $39. It's got it's own stand and wheels. It'll do either the stand or a picnic table. but folds down reasonably compactly for storage in the Excursion. The cook top is teflon and huge. I thought initially that I'd not like it, as the flames heat the bottom of the grill, and the fats run off into a cup so the 'smoked' flavor wouldn't be there, but I confess that I actually like the thing, and food prepared on it is superb! Cleanup is a snap, and there's no burned-on grease to get messy. All for $39. I am impressed with it in spite of myself!
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
1994 Airstream B190 & 2006 Bigfoot 25B25RQ
Old 01-01-2004, 03:55 PM   #24
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Haven't seen this one in person yet, but it has potential
http://store.yahoo.com/infomercialshowcase/q-grill.html
They have been running the informercials on it on late night television. It is also in the Skymall catalog that you find on those long boring flights.
Aaron
Old 01-01-2004, 04:29 PM   #25
Royce's Avatar
Frozen,
As I recal I paid about $175 for the grill. It burns hardwood chunklets for fuel. If you buy from Woodflame they will be unfinished hard wood flooring cut offs 2.75"x2.75"x0.75" Almost any kiln dried North American hardwood will work. I build custom furniture and so have plenty of fuel available as scrap left over from the build process. Should be easy to find someone local to supply you with their scraps. It uses 3-4 of the cut offs to grill one load of burgers or steaks. About 6-8 for chicken or small roast. The temp is easy to control by the variable speed fan. I tyically start off with three of the blocks in the burner and fan on high for 1-2 minutes per side then turn to medium setting for the balance of the cook. Eight burgers can be done at a time if you are careful and three blocks (one load) will be enough. If you want a more smokey flavor just toss in a fresh chunklet on the coals and turn off the fan for a couple of minutes. There is almost no ash created as the system burns completly. Just under the grill is a flame disfuser that makes the system pretty even temp all over the grill surface. If you are grilling in the wind it will be a llittle cooler on the windward side.
Royce
AIR# 3913
Old 01-01-2004, 04:42 PM   #26
Profile:
I've used a small portable Ducane gas BBQ for years and it has been great.
http://www.ducane.com/take_it_or_leave_it.asp
I highly recommend it.
oscarb57 is offline   Reply With Quote
Old 01-04-2004, 03:45 AM   #27
Van
Profile:  1977 23' Safari
Hillsboro , Oregon
I have and love the Thermos Grill 2 Go. It is real similar to the Coleman grill.
It runs about $130.00. I have used it for one season and it is a great grill. Cooks my breakfast as well because half the grilling surface is a gridle. The folding legs can be a bit wobbly if close attention is not paid to placement of the legs during setup. Other than that it is a great grill. Light, easy to use, folds up and stashes away fast and easy.
Besides that, it looks better than the Coleman. Everyone knows that a red grill cooks best.
Van
2005 F-150 FX4, SC, 4X4, 5.4 V8
former '78 Argosy 20' Minuet owner
former '77 23' Safari owner
current 25' Fun Finder X-250BHS SOB owner
Van is offline   Reply With Quote
Old 01-04-2004, 07:24 AM   #28
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
lowest tech
i use the good old weber smokey joe. with charcoal of course.
costs about 30 bucks last time i checked. if it gets damaged or rusted through i doesn't owe me anything!
i actually have two, one was given to me by fellow campers at sturgis, they bought it to use and couldn't (and didn't plan to) take it home with them. they were on bikes and said even with the cost of the grill it was cheaper than eating out a couple of nights at the rally! bonus for me! (i did give them a couple of cold miller highlifes in trade)
transporting the smokey joe can be difficult because it is top heavy and wants to tip over. i found that it fits nicely into a standard milk crate and with a couple of bungees to keep the lid in place it rides in the back of my pickup very well. small bbq tools and lighter fluid fit in the bottom of the milk crate as well.
i also have a propane king cooker with a large aluminum pot for boiling sweet corn or seafood. it runs on a standard 20 lb propane bottle. the bottle fits into a milk crate as well, allowing it to be safely stowed in the pickup.
the king cooker doubles as a water heater for washing dishes when we have a large group and i don't want to fill the grey tank.
john
you call them ferrets, i call them weasels.
Where Do You Store Your Grill????? Lemontree Our Community 36 08-21-2008 04:15 PM
What grill do you use? 6xblessd Stella's Kitchen 62 01-10-2008 09:16 PM
New outside propane grill for my 67 Overlander bighowdytex Our Community 8 01-07-2008 01:08 PM
Broken Grill toaster one General Motorhome Topics 4 08-06-2006 08:40 AM
Armstrong Grill davespann Parts Archive 2 06-25-2004 10:43 AM
