Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle > Stella's Kitchen
Old 04-14-2008, 06:13 PM   #225
Lauerman
Profile:  1961 16' Bambi
Bend , Oregon
Sport Grill MVP
Just bought the Sport Grill MVP. Looked at the Coleman Road Trip but was not impressed with the quality. However, the Sport Grill MVP offers the same versitility with a higher lever of construction. For example, the grill/griddle components are made of Cast Iron. And it seemed a lot more durable. Works with both small propane tanks or can be adapted for use with larger tanks. Definately worth a look!
Lauerman is offline   Reply With Quote
Old 04-14-2008, 06:26 PM   #226
Jimandrod
Jimandrod's Avatar
Profile:  2008 28' Safari SE
Placitas , New Mexico
Originally Posted by ibgl6
I found this in a ad when I did a search for the baby Q on Google Hope this helps.....SAM
A disposable 14.1-oz. propane cylinder (not included) lasts up to 1.5 hours.
Hey thanks - that's the answer I was looking for! I appreciate it!
Jimandrod is offline   Reply With Quote
Old 04-14-2008, 06:40 PM   #227
Jimandrod
Jimandrod's Avatar
Originally Posted by jcanavera
You have to take off the bottle holder ring to handle the fat bottles. I went out and bought a smaller 11 lb. tank. You might find that a suitable alternative.
Jack
Thanks Jack - Yup - the ring is still on there so if I want to use the fat one it would have to come off. I'm leaning towards an 11lb tank - I think it's a great idea. There is also a 5 lb tank that I might consider. Then when I have the big tanks filled I can have the little one done at the same time.
Originally Posted by fotochop
You should consider replacing one of your regulator outlets with a "Y" or "Tee" that allows you to add another propane hose to your existing bottle, that way you wouldn't have to haul another bottle out when camping and could just hook your Weber up to your trailer and burn some meat..
It's not a bad idea and a lot of people do that for their grills, but, it also limits the location for using the grill. I'd rather have the flexibility to be able to move it around freely.
Originally Posted by RIstream'n
We use an 11 lb tank from Cabella's. Perfect size and it's completely flat on the bottom.
That's the direction that I'm leaning in. I just don't know if I'm going to get a 5 lb or the 11 lb.
Old 04-14-2008, 07:32 PM   #228
DrPlay
DrPlay's Avatar
Profile:  2006 25' International CCD
Freehold , New Jersey
I also have the Coleman RoadTrip. Also purchased the flat 'griddle' for doing the pancakes, bacon etc, AND the stove top attachment for a coffee pot, soup pot etc. Comes with the regular grill tops suitable for steaks, dogs and the like. ALSO purchased the extra hose and adapter and a small 5lb propane tank. Have used a dozen times and still on the first tank. I don't like the small 1 lb tanks.
DrPlay is offline   Reply With Quote
Old 04-14-2008, 07:48 PM   #229
ibgl6
ibgl6's Avatar
Profile:  1973 27' Overlander
Southport (Panama City) , Florida
I dont know what the coleman looks like but my Thermos grill to go comes with a 60/40 split griddle/flat for eggs and pan cakes....SAM
Your Friend Sam In (Southport) Panama City Florida Air#15607
Good Sam (LifeTime Member)
ibgl6 is offline   Reply With Quote
Old 04-20-2008, 08:04 AM   #230
6thChief
Profile:  2001 30' Limited
Fonthill , Ontario
I use the stainless steel Napoleon portable grill. Excelent quality but a bit bulky for extensive travel vacations. Pricey at $325, but should last forever, mine has over 30,000 miles on it and I use the trailer tanks almost exclusively but can use the small tanks as well.
6thChief is offline   Reply With Quote
Old 04-20-2008, 09:17 AM   #231
Jimandrod
Jimandrod's Avatar
Originally Posted by Jimandrod
We have a Weber Baby Q and have been using it at home off of a 20lb propane cylinder. When we take to the road this summer the grill will be with us but I don't want to take the 20 lb tank nor do I want to hook up to the big tanks on the trailer.
We stopped by Camping World yesterday and bought a refillable 5 lb tank. It seems like it will be the perfect size to haul around with the Baby-Q. Ir should last for while between refills and we won't be throwing any of the non-refillable canisters into the environment.
Old 04-20-2008, 09:32 AM   #232
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Originally Posted by Janet
As reported earlier in this thread we had an infrared grill from frontage but it was too hot! we burned more food and never really made friends with it. last year we got a Napoleon Freestyle propane grill that came with a cool attachment to mount on the hitch receiver - love this grill!!! It comes in both infrard and regular burner - we got the regular burner... no more burnt offerings (well not many)
I bought one of these on clearence last fall. Paid just over $200. Stainless and heavy. She will last forever! No hitch attachment though.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 5 09-10-2006 06:10 PM
LP Quick Connect for Gas Grill Mod-Streamer LP Gas, Piping, Tanks & Regulators 12 12-19-2005 04:46 PM
Portable heater suggestions ALANSD Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-22-2005 02:54 PM
Portable Generator Marks Generators & Solar Power 35 10-07-2003 03:14 PM
Cleaning the portable water systems after use Silvertwinkie Fresh Water Systems 4 07-01-2003 03:46 PM
