Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle > Stella's Kitchen
Old 05-07-2007, 10:12 PM   #183
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
I started with a Frontgate infrared grill and hated it. At the recommendations of Jim Clark I bought a Magna and love it! I have the rectangular one. I also bought the table top legs and it is well worth its price tag.
Family of Disney Fanatics
WBCCI# 4821
streamin across america
Old 05-12-2007, 08:34 PM   #184
Profile:  1996 34' Excella
Sanford , Florida
Send a message via AIM to Folkie53 Send a message via Yahoo to Folkie53
I got a Holland because of the promise to never flame up. I was skeptical on the claim but am now a believer. I can't believe how easy it is to cook on this thing. I have had It on a beach and cooked chicken without any problems.
There are two types of people in this world. Those that have an Airstream and those that wish they did. I feel sorry for the have-nots. HEE HEE
Folkie53 is offline   Reply With Quote
Old 05-12-2007, 09:18 PM   #185
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Infrared grilling is 'different' than what you are used to on a Weber or other conventional grill. Once you learn how to use it properly, the difference is unbelievable!
I was a confirmed Weber guy until I tasted a steak done on an infrared. Went out the next day and bought a Solaire Mini grill. Burned a couple of steaks getting it right, but once you do, you'll never go back to a conventional grill.
Don't leave home without it!
Lew Farber -Certified Master RV Tech (currently on Forums sabbatical)
WBCCI #1456/VAC (assoc) #1456 AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 05-14-2007, 01:20 PM   #186
Solaire made the grill I had and re-badged it for Frontgate. The second time I used it, the malleable metal regulator threads stripped. I ordered a new regulator from Solaire and it leaked. The first time I used the new regulator it literally burst into flames when I pressed the igniter. I had to run to the Airstream door and grab the fire extinguisher to put the fire out. The flames melted the knob. Solaire sent me a new regulator but the burner made a low pitched hissing noise...the fire had damaged the infrared burner. The next time I used it, the burner burst into flames just as I was removing the steak from the grill. Total cost per use of the grill: $105.74 plus cost of burnt steaks and chicken. Solaire has changed the design of the grill including burner design since mine was purchased and the new burner won't fit mine. Therefore, I have a $400 stainless steel doorstop. In my opinion, Solaire should have offered to replace my grill since their new regulator damaged the otherwise perfectly good burner. As it is, I never had a chance to get used to using it and as a result of my limited experience with the Solaire/Frontgate Infrared grill, I am not interested in buying another.
Cost of Magma Grill: $329 and I've used it about half a dozen times without any incidents. I contacted Magma directly before I purchased one of their products and was assured that the parts for my grill will always be available as has parts for the first model they introduced over 30 years ago. Piece of mind: priceless.
WBCCI# 4821
Old 05-14-2007, 02:43 PM   #187
Profile:  2005 22' International CCD
Woodland Park , Colorado
Originally Posted by Porky Pig
So the best Weber I can find ... fo me .. would be the Smokey Joe Platinum with the 18.5 inch grill.
The Weber Smokey Joe is a great grill. I use mine at home, and on the road. Can't beat the taste of charcoal, especially with wood chips. I will never buy a gas grill again. jk
JK3500 is offline   Reply With Quote
Old 05-23-2007, 03:26 PM   #188
Gator1
Gator1's Avatar
Profile:  2006 25' Safari
San Antonio , Texas
Mini Big Green Egg
I am a huge fan of the Big Green Egg! I have a large one at home and like it so much I bought the mini model for camping. It will easily handle everything from 750 degree steaks to slow smoked whole chicken.
The other day we smoked a 3.5 pound chicken for 2.5 hours at 300 degrees - perfect. Yesterday was burgers, last weekend was high temp seared steaks.
A Ceramic Smoker, Grill, Barbecue. The ancient oriental kamado cooker re-born.
The prices are a bit high, but not as bad as some quoted on this thread. Also a little heavy (35 lbs), but it fits under the tonneau on my truck.
Gator1 is offline   Reply With Quote
Old 05-24-2007, 08:40 AM   #189
Originally Posted by Gator1
I am a huge fan of the Big Green Egg! ...Jim
I've heard a lot of great things about them and have seen the small ones. I think I may have even seen a propane knock-off. I just don't have the room to carry one.
WBCCI# 4821
Old 05-24-2007, 09:33 AM   #190
Wayne&Sam's Avatar
Profile:  2007 20' Safari SE
Cuddebackville , NY
Images: 16
We're just about to head out on our shake down. I've been lamenting that the AS didn't have a BBQ like my SOB did. So I bought a Weber BabyQ and will try it out. Right now it runs off 14 oz bottles, but I'll hook it up to the LP tanks if it works OK.
Old 05-24-2007, 05:44 PM   #191
ESCAPE POD's Avatar
Profile:  2007 19' Safari SE
Seal Beach , California
Patio Classic
For our needs (usually just my wife and myself), we've been very happy with the "Patio Classic Bucket BBQ". It's light, compact, and starts the charcoal with just 2 sheets of newspaper (no starter fluid). The base acts as the "chimney" for heating the coals, which are ready for cooking in about 15 minutes. The grill cover has adjustable vents. The grill is roughly 12" in diameter, but, again, takes care of the BBQ needs of two people very well. It sells for about $50. A "google" search with the above title will give you plenty of hits.
We shall not cease from exploration, and the end of all our exploring will be to arrive where we started and know the place for the first time. -T.S. Eliot
Jerry & Susan
2007 19' Bambi SE
2003 Dodge Dakota 4.7L V-8
ESCAPE POD is offline   Reply With Quote
Old 05-29-2007, 10:30 PM   #192
Rosie the Riveted
Profile:  1969 25' Tradewind
Balfour , BC
We use a Force Ten Marine "Stow and Go" that we liberate from our boat when we're Airstreamin'. It has adjustable air inlets that allow you to vary the amount of air going in so you can cook in all weathers. Ok, so it's not charcoal but we get to have dinner, typhoon or not.
KC
Ken & Janice is offline   Reply With Quote
Old 06-02-2007, 11:51 AM   #193
Commercial Vendor
soldiermedic's Avatar
Profile:  1975 29' Ambassador
1953 21' Flying Cloud
O'fallon , Missouri
Send a message via Yahoo to soldiermedic
Originally Posted by InsideOut
This summer we got something that may interest you...it's the Coleman Road Trip Grill. It has interchangable cooking components that allow it to be used as a BBQ, Stove, Griddle or 1/2 one thing & 1/2 another. It uses the small disposable propane tanks, but we also purchased an additional hose which allows us to hook it up to our trailer's OPD tanks or any other 20lb tank. I LOVE it...the only complaint is it's a bit heavy, but it appears to be made well.
If you keep your eye open you can find it for under $150...
Shari
After following this thread awhile, I bought one of these grills. Works very nice. Just need to get the adapter for 20 lb tank, and an additional grill.
Steve
soldiermedic is offline   Reply With Quote
Old 06-02-2007, 01:09 PM   #194
Stefrobrts's Avatar
Profile:  1968 17' Caravel
. , Washington
I really like the looks of that. What do you set it on when you're cooking though? From the design I'd guess the base gets pretty hot.
Stephanie
Old 06-02-2007, 03:17 PM   #195
SilverGate's Avatar
Profile:  2007 23' Safari SE
San Diego , California
Weber 51020 Smokey Joe Platinum Charcoal Grill is our favorite and can be seen in use on our trip to South Carlsbad State Beach (post #174)
http://www.airforums.com/forums/f396/silvergates-safari-home-last-29471-13.html
The Platinum version has a cooking area of 18 ½" which we like for several steaks at a time.
But I think that Weber may not be making this version right now, but it is still available in stores.
We bought ours at DixieLine this spring, but I saw that it is also available at Amazon.com:
http://www.amazon.com/Weber-51020-Smokey-Platinum-Charcoal/dp/B00004U9VU
Name:	HPIM0847 Larry cooking brunch.jpg
SilverGate is offline   Reply With Quote
Old 06-03-2007, 06:36 PM   #196
Fenghuang's Avatar
As in SilverGate's posted photo, to increase the heat for frying on a (Charcoal Companion) griddle with a Smokey Joe charcoal BBQ, the hot coals are on a supplemental coal grill grate that is resting on top of a wok ring (3-4 tuna cans with tops and bottoms removed will also do) resting on top of the existing coal grill grate. The rolls toasted and the sausage nicely browned.
Without this adaptation, frying bacon/sausage/eggs requires extended time with compromised results.
A man who takes away another man's freedom is a prisoner of hatred; he is locked behind the bars of prejudice and narrow-mindedness. I am not truly free if I am taking away someone else's freedom, just as surely as I am not free when my freedom is taken from me. NELSON MANDELA
Fenghuang is offline   Reply With Quote
Where Do You Store Your Grill????? Lemontree Our Community 36 08-21-2008 04:15 PM
What grill do you use? 6xblessd Stella's Kitchen 62 01-10-2008 09:16 PM
New outside propane grill for my 67 Overlander bighowdytex Our Community 8 01-07-2008 01:08 PM
Broken Grill toaster one General Motorhome Topics 4 08-06-2006 08:40 AM
Armstrong Grill davespann Parts Archive 2 06-25-2004 10:43 AM
