Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle > Stella's Kitchen
Old 11-30-2006, 05:24 PM   #169
vajeep's Avatar
Profile:  1976 27' Overlander
Copper Hill , Virginia
Images: 49
We love our Webber Q. They sure do get a great grill in a small package!!
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
WBCCI# 7627 / VAC
Air #2798
vajeep is offline   Reply With Quote
Old 11-30-2006, 07:08 PM   #170
buckwheat's Avatar
Profile:  North central , Alabama
ScottMac, the Kristline looks like the absolutely perfect solution to our search for a quality, affordable, versatile, compact grill. We especially like the Grill/3 kit... propane, charcoal, and electric all in the same grill, Woo!Hoo! Thanks for the link!
BubbleHead Fred
"Underway is the only way!"
buckwheat is offline   Reply With Quote
Old 12-01-2006, 05:03 PM   #171
Profile:  2003 25' Safari
Yukon , Oklahoma
Buckwheat,
I just recently ordered it directly from Kristline. I could only find a few online retailers and they wanted quite a bit more money. Plus, Kristline included their "Roto-Kabob" at no extra charge. It is an ingenious little gizmo - I hope it works as advertised.
ScottMac is offline   Reply With Quote
Old 12-06-2006, 10:16 PM   #172
Profile:  2007 19' Bambi
Rouses Point , New York
Stainless Grill
Greetings, just joined the forum so not quite set up yet. I have found two very interesting grills, one high end and one low end.
http://www.rasmussen.biz/grills/portG.html The Solaire is a legend in the boating community and comes in two choices of Stainless steel, regular and ultra salt water proof. Retail starts at $550 but you can buy it now on ebay for $350. It matches an Airstream and could be mounted to the trailer via the hitch coupling.
I also like the Coleman Road Trippers. http://www.coleman.com/coleman/colem...ategoryid=2036
Sincerely,
Salmo.salar
Salmo.salar is offline   Reply With Quote
Old 05-07-2007, 09:44 AM   #173
FT RVing
lebolewis's Avatar
Profile:  1976 31' Sovereign
A place w/low Humidity , FT RVing, north & south
"How to" convert the Weber Baby Q grill?
I need a good portable grill. After much research, I have zeroed in on Two Webers, the "Baby Q" and the "Go-Anywhere" and a nice stainless Grillware unit from Lowes. They all use the small propane bottles for fuel. However, the two Webers use the hard-to-find 14 oz bottles and the Grillware unit uses the common easy-to-find 16 oz size.
My question is "are the connections to the grill for each bottle size different?" And if yes, then how can you easily convert the 14oz connection on the Weber to accomodate the 16oz connection? Thank you. Bill
lebolewis is offline   Reply With Quote
Old 05-07-2007, 09:56 AM   #174
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Send a message via AIM to jcanavera
Bill, I have a Baby Q and to use the 16 oz bottle, you just remove the 14 oz bottle wire holder and use the bottle. If you have the space, I'd recommend buying a 10lb refillable propane tank and connection hose. It makes the grill a lot more useful and you will save a bundle on propane. Also buy the folding stand on wheels and cover.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 05-07-2007, 10:10 AM   #175
FT RVing
lebolewis's Avatar
Jack
Good information, Jack. Thank you. So, the connector is the same on the grill for the 14oz and the 16oz bottles. Just need to remove the 14oz wire holder on the Baby Q so the 16oz size can get to the connecton. I got it. Thanks, Bill
Old 05-07-2007, 10:23 AM   #176
jcanavera's Avatar
Fenton , Missouri
Images: 143
The only problem (if one at all) is the 16 oz bottle will not be supported like the 14 oz. was (with the wire holder). I used to slip something underneath the bottle (between the table and the bottle end) to give the bottle some support. This really isn't a big issue though.
One other note, is to be sure to follow the directions and season the grill top. It is cast iron and you need to do this right. The grill itself cooks faster than any portable BBQ I've ever owned. Just read the book that comes with it, especially the care and feeding of the grill top.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-07-2007, 12:48 PM   #177
sander17's Avatar
Profile:  1996 28' Excella
Okemos , Michigan
Images: 42
Go-Anywhere experience.
I need a good portable grill. After much research, I have zeroed in on Two Webers, the "Baby Q" and the "Go-Anywhere" . Bill
We tried the propane Go-anywhere and found it cooks slowly and is hard to clean.
We are now using the small Smokey Joe with a charcoal chimney style starter (newspaper starts the coals burning--no lighter fluid). It takes about 15 min. to hot coals and the only cleanup is the grill. After use, I close both vents and pour the cooled unburned coals into a plastic small garbage bag. It goes in the chimney for storage till next time.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 05-07-2007, 01:54 PM   #178
Profile:  1977 31' Sovereign
McHenry , Illinois
I purchased a Campchef sports grill for our local club directly from them. They gave us a dealership in hopes we would sell more. I have sold three more to other local clubs and individuals at a 25% discount. It has lots of capacity for big groups and we run it off a 10lb tank or off one of the trailer tanks. It folds for compact transporton in durable bags. Goggle "campchef" to see if your club would like one. PM me, if interested or further infromation.
Old 05-07-2007, 03:23 PM   #179
Bradjun1's Avatar
Profile:  1999 34' Limited
1962 19' Globetrotter
Northern , Minnesota
We just went with the BabyQ and we are very happy with it. We use the 16oz bottles and we also bought the Weber hose to attach it to our 30# bottles. The best thing about this grill is even temps everywhere on the cooking surface. We have done steaks ,chicken breasts, pork chops and other foods with out any problems. We also got the cover and stand. We are well pleased with this grill.
Bradjun1 is offline   Reply With Quote
Old 05-07-2007, 04:45 PM   #180
Profile:  2004 25' Classic
West Chazy , New York
We have a Magna stainless steel marine kettle type grill left over from our boating days. It uses disposable propane containers, has a variety of mounts available including table legs which is what we use. All parts can be replaced, the unit can fit into a sunbrella carry bag (which holds down the odor) and it cooks really great. You can find it online at places like West Marine.
Ron
2004 Classic 25 - The Silver Sausage
2008 Silverado LTZ CC 2500 4x4 Duramax - Brutus
WBCCI 2623
romap is offline   Reply With Quote
Old 05-07-2007, 07:02 PM   #181
STREAMTEAM's Avatar
Profile:  1973 23' Safari
Alamosa , Colorado
Smoky Joe...by Webber...with the legs off fits into a couple of lawn leaf bags, with charcol, chips, starter, whatever. We use a plastic storage box with snap lid for everything. We do fires at night and use the coals for fresh trout in the morning...
STREAMTEAM is offline   Reply With Quote
Old 05-07-2007, 09:40 PM   #182
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
We use a Cobb. It works great for the Airstream life. 8 briquettes cooks our meal, and it is easy to clean.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Where Do You Store Your Grill????? Lemontree Our Community 36 08-21-2008 04:15 PM
What grill do you use? 6xblessd Stella's Kitchen 62 01-10-2008 09:16 PM
New outside propane grill for my 67 Overlander bighowdytex Our Community 8 01-07-2008 01:08 PM
Broken Grill toaster one General Motorhome Topics 4 08-06-2006 08:40 AM
Armstrong Grill davespann Parts Archive 2 06-25-2004 10:43 AM
