Old 07-30-2018, 11:06 AM   #1
Mollysdad's Avatar
Words.
I'm curious, I hear words used here that I've never heard.
"Goucho" for seating area, and "Stinger" for hitch shank.
I wonder where they originated?
Can you think of more?
Old 07-30-2018, 11:17 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I believe that the goucho term is actually from AS advertising. I *assumed* that the stinger term came from Hensley or ProPride manuals. Put another way, they are something a marketing department came up with .... Could be I'm just confused ... yet again ....
Old 07-30-2018, 11:28 AM   #3
2007 22' International CCD
Sometimes I'm convinced the Hensley/ProPride 'stinger' is a reference to what happens to your shins when you run into one of them. At least "stinger' is more polite than the usual string of profanity that results from such a collision...
More likely, its a reference to the way the parts go together when hooking up--
Old 08-05-2018, 01:12 PM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Our AS has a gaucho sofa. The action to open it is different from all other bed-sofas. It's not a hide-a-bed, or a Davenport. Think in terms of how you would bring a sofa bed into an AS through the door and install it. The gaucho opened up is like carrying a 4-inch thick 4 by 8 piece of foam through the doorway and into the AS. It mounts on a steel fame with two clamps around the steel drill rod - 4 bolts. Much much easier than trying to shoehorn in a hide-a-bed.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 08-05-2018, 01:52 PM   #5
Mollysdad's Avatar
Sounds like a futon to me.
gau∑cho
ˈɡouCHō
noun
a cowboy of the South American pampas.
Old 08-06-2018, 08:15 AM   #6
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
gau∑cho
ˈɡouCHō
noun
No, it's not a futon. The mattress for the gaucho is actually split into 2 distinct pieces. Unfortunately, there are no videos of this on youtube. Basically, the part of the sofa you sit on does not move, but the backrest swings up and forward and then rotates and lies flush with the seat part at the forward edge. The whole mattress does have a hinge at the very rear so that it can be lifted to gain access to what is behind it, namely the battery boxes and charger/convertor, in my case two huge size 4D AGM batteries and the Xantrex Freedom 3012 convertor/charger/inverter.
VE3JDZ
AIR 12148
WBCCI 8080
Old 08-06-2018, 11:14 AM   #7
AlanMcD's Avatar
Cincinnati , Ohio
Stinger
The stinger is the part that comes out of the hitch reciever on the truck for a Pro Pride and a Hensley sway control hitch. They don't use a ball but instead have a shank or stinger that protrudes out of the receiver 10" or so where the ball would be on other hitches like an Equalizer.
-Alan
Cincinnati, OH
Blog: http://alanandcarie-airstream.blogspot.com/
AlanMcD is offline   Reply With Quote
Old 08-06-2018, 11:18 AM   #8
AlanMcD's Avatar
Cincinnati , Ohio
(Image pulled from the internet)
-Alan
Cincinnati, OH
Old 08-06-2018, 11:29 AM   #9
The two rather beefy tabs on the sides of the 'stinger' accommodate the over-center latches mounted on the head that hold the hitch head and stinger together whilst towing. A couple safety locking pins go in the small holes. Hensley Manufacturing and ProPride are very similar, ProPride is quite a bit 'chunkier' in its construction.
The picture is of a typical ProPride adjustable stinger assembly, and it's very apparent this one has been adjusted for height at least once, based on the pattern of the missing paint.
It also shows signs of a great deal of use, probably by a very happy owner...
The "stinger" name probably comes from the fact that it is inserted into the hitch head when hooking up. My theory is that since it sticks out quite a bit when not hitched up, is down where it is hard to spot, and clobbers the heck out of the unwary shin, the effect is a "..get ready for a lot of stinging**'"when you do run into it.
** Part of my favorite line from the "Over The Hedge" movie...a genuine riot, if you ever followed the comic strip.
Old 08-06-2018, 12:21 PM   #10
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
RE: Gaucho - Thanks. I wasn't aware that the back came down n front of the seat. I guess I have a "jackknife". My seat slides forward and the back comes down behind it.
RE: Stinger - My guess is that the back end of the truck looks like the back end of a bee.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-08-2018, 01:31 PM   #11
RE: Stinger:
Operationally determined this is the absolutely correct name for this assembly of about 90 pounds of solid 2" steel bars and 1/2 inch gusset plates, as of yesterday evening.
Had to move the AS last night so I can work on a few things. Hoisted the stinger into place on the truck, found the 5/8" pin for the receiver, but not the locking clip. Went out of the garage to find a substitute. Came back, installed a chunk of wire to safe the pin. Got back up, promptly slammed left shin into the blankety-blank edge of the stinger. Now shin still stings, nice scab over the cut and a nice purple bruise this morning. "Clumsy Carp" and I must be brothers...
QED.
Old 08-08-2018, 01:56 PM   #12
Long Island , New York
Originally Posted by rmkrum View Post
. . . promptly slammed left shin into the blankety-blank edge of the stinger. Now shin still stings, nice scab over the cut and a nice purple bruise this morning.
Maybe this is where they got the name "Stinger" . . . ?
Old 08-08-2018, 02:21 PM   #13
I would bet that's where the name came from...its still hurtin'
I just had to move the trailer a mile or so--I didn't expect shin damage...you would think I had this figured out better by now.
Working alone in the solid dark, it took only 2 tries to get the stinger into the head. elapsed time from start to drive away about 20 minutes total. When I got the AS in front of the "up the hill" house, I was exactly 10 inches off the curb and parallel to it, as planned, no brag. Just had to back up a bit to center between both of our driveways and unhitch. Other than shin damage, a reasonable night's exercise--although it was still 90 degrees out at 9:00 PM, down from 108 during the day...sigh.
Spent the rest of the evening drinking a lot of cool water, enjoying air conditioning, and watching news coverage of the brush fires. One is a few miles south of our Corona house. Wife reports red sun through the smoke all day today. Dogs don't even want to go out in the smoke haze around the neighborhood. No danger, but keeping a very close eye on the situation. Part of the trailer move was to have it quickly available if family has to load stuff and scoot.
Old 08-08-2018, 02:43 PM   #14
Mollysdad's Avatar
I hope it all turns out well. Keep us posted.
What are your "Famous Last Words" - List them here Jim Jarzabek Fun & Games 351 04-06-2017 01:33 PM
Words Devoman Off Topic Forum 3 08-03-2006 05:40 PM
New words and phrases yukionna Off Topic Forum 19 05-09-2006 01:55 PM
Pictures tell a few words smily Our Community 16 08-03-2005 02:30 PM
Picture worth a thousand words! dinoburb On The Road... 1 01-13-2003 08:43 AM
