Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle
Old 03-22-2014, 07:22 AM   #1
VNO
1975 Argosy 24
Germantown , Tennessee
Will a 31 footer fit in my driveway?
We are moving up from 24 to 31 feet. We live in a suburb and I have been backing our 24 foot in. Should I anticipate problems with the extra 7 feet?
Eaglemate is offline   Reply With Quote
Old 03-22-2014, 07:25 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
There is a myth about trailers that is just backwards. "The longer it is the harder it is to back up." Reality is just the opposite.
2004 Excursion 4x4
Old 03-22-2014, 07:39 AM   #3
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Not really except that you might be 7 feet closer to the garage door or a tree in the back of the driveway
urnmor is offline   Reply With Quote
Old 03-22-2014, 08:00 AM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I went from 28' to 31' and other than the length itself, which was not a problem with the driveway, I did have to adjust my back in technique. I live on a cul-de-sac which required me to change my pivot point and pull a little further away from the drive prior to starting the back in process. The key is in the back in angle and pulling away further allows you to compensate for that extra length.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 04-05-2014, 09:18 PM   #5
purdytj's Avatar
Tacoma , Washington
Send a message via Skype™ to purdytj
It also depends on the wheelbase of your tow vehicle... K-5 Blazer? Easy! Suburban... a bit more Austin Powers back-and-forth may be necessary.
2007 Silverado 2500: www.purdygreatlife.weebly.com/truck
RIP (https://purdygreatlife.weebly.com/2014-blog):
1998 Dodge Ram 2500 QC-LB 4x4 12-valve
1974 Airstream Sovereign
purdytj is offline   Reply With Quote
Old 04-06-2014, 04:54 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Do you have 7 more feet to the street?
I have never tried backing mine into the driveway, but it looks like the tongue would be almost in the street.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-06-2014, 05:06 AM   #7
Luigi123's Avatar
2018 30' International
2014 30' Flying Cloud
Los alamos , New Mexico
Key is to go slow, use a second person, tape measure before attempting--I am new to the 30ft world and just experienced this adjustment. I have a 12 ft cargo trailer single axle, and I would agree backing the dual axle, 30 ft was more manageable than the 12 ft. always back up with the view of trailer on your drivers side.
Luigi123 is offline   Reply With Quote
Old 04-06-2014, 04:32 PM   #8
m.hony's Avatar
2013 30' Classic
Now I have backed it into the driveway. The driveway is much longer than I realized. I have 50' from the house to the street.Click image for larger version
Name:	ImageUploadedByAirstream Forums1396823470.028174.jpg
ID:	209105Click image for larger version
Name:	ImageUploadedByAirstream Forums1396823491.497266.jpg
ID:	209106Click image for larger version
Name:	ImageUploadedByAirstream Forums1396823511.866047.jpg
TAC #MS-10
Airforums #70955
Old 04-06-2014, 04:40 PM   #9
Ag&Au's Avatar
Port Orchard , Washington
On factor I have not read mentioned:
The longer trailer will have a longer distance between the rear tires and the rear frame ends. If there is any dip and/or rise involved, the rear of the frame may touch the ground where the 24's would not. Probably not a factor, but watch for it.
Ken
Old 04-06-2014, 05:18 PM   #10
m.hony's Avatar
2013 30' Classic
Here in the Mississippi delta it is not a factor, but I have bottomed it out in a dip in a gas station entrance in Texas. There is a piece of vertical steel welded under the bumper/rear frame rails I assume to give it more strength to keep it from buckling if it bottoms out.
TAC #MS-10
Airforums #70955
Old 04-06-2014, 05:32 PM   #11
Ag&Au's Avatar
I think those are a kind of sacrificial skid plate to make a bunch of noise and warn you that if you continue your present ways, you will most likely bend the frame. I stuck them fairly deep into a sandy soil perm once, because they failed to screech in that soil. They cut right into it like a knife. I have found that the 16 inch tires and wheels help that clearance a surprising amount.
Ken
Old 04-06-2014, 05:45 PM   #12
m.hony's Avatar
2013 30' Classic
It was just a millisecond, but the people following us noticed. I ground off a little bit. I hope to never ever bottom out again.
TAC #MS-10
Airforums #70955
Old 04-06-2014, 06:14 PM   #13
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Reminds me of the pneumonic I had to learn for 7th grade print shop "Large Elephants don't fit in small Ford Garages"
AFTER you have mastered the art watch the trailer backing scene in Lucy and Desi's "The Long, Long Trailer".
Old 04-06-2014, 06:18 PM   #14
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
You can measure to find out of the longer trailer will fit into your driveway.
The question is, can you get it into your driveway?
A banana will fit into a two liter soft drink bottle. Getting it there is another matter.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 04-06-2014, 06:42 PM   #15
m.hony's Avatar
2013 30' Classic
Ken
You really only gain 1/2" more clearance with the 16" wheels, but 1/2" clearance could be the difference between clearing the obstacle or a catastrophe...
In the back I regularly dig dirt with those reinforcements with no I'll consequences. The driveway thing is the result of 2 other things- us having a monsoon right now ( it is too wet/muddy in the back- I will get stuck) and recently getting low tree limbs cut so the trailer would fit under.
TAC #MS-10
Airforums #70955
Back a 22' into a driveway? Belbein Towing, Tow Vehicles & Hitches 31 02-11-2014 08:33 PM
Rear compartment door problem '94 34 footer MR AIRSTREAM Exterior Storage Compartments & Access Doors 3 11-07-2012 06:09 PM
HELP getting 19' Bambi into steep driveway kimd8888 Towing, Tow Vehicles & Hitches 36 09-05-2012 08:01 PM
Shower Curtain doesn't fit right. darryl97420 All Argosy Trailers 3 11-06-2011 08:30 AM
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
