Old 04-06-2014, 06:42 PM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by Ag&Au View Post
I think those are a kind of sacrificial skid plate to make a bunch of noise and warn you that if you continue your present ways, you will most likely bend the frame. I stuck them fairly deep into a sandy soil perm once, because they failed to screech in that soil. They cut right into it like a knife. I have found that the 16 inch tires and wheels help that clearance a surprising amount.
Ken
You really only gain 1/2" more clearance with the 16" wheels, but 1/2" clearance could be the difference between clearing the obstacle or a catastrophe...
In the back I regularly dig dirt with those reinforcements with no I'll consequences. The driveway thing is the result of 2 other things- us having a monsoon right now ( it is too wet/muddy in the back- I will get stuck) and recently getting low tree limbs cut so the trailer would fit under.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Back a 22' into a driveway? Belbein Towing, Tow Vehicles & Hitches 31 02-11-2014 08:33 PM
Rear compartment door problem '94 34 footer MR AIRSTREAM Exterior Storage Compartments & Access Doors 3 11-07-2012 06:09 PM
HELP getting 19' Bambi into steep driveway kimd8888 Towing, Tow Vehicles & Hitches 36 09-05-2012 08:01 PM
Shower Curtain doesn't fit right. darryl97420 All Argosy Trailers 3 11-06-2011 08:30 AM
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
