Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle
Old 02-26-2014, 02:12 PM   #21
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Originally Posted by Cannonball View Post
Ok, I am a bit puzzled. Rig is 2014 Sport 22FB. On the A/C unit there is a switch position labeled "Opt. Heat". This is the heat pump, correct? I have tried it twice, and it blows rather tepid air. Stat is set all the way to "warm". Does it warm up over time or what?
yes, over time . . . probably around May or June for someone in your region
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 02-26-2014, 02:17 PM   #22
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
I avoid using the heat pump in our trailer. I find the noise to be intolerable.
I hated the air to air heat pump we had in our house. We have a geothermal heat pump in the house now and I love it. Guess that won't work in a trailer
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 02-26-2014, 02:18 PM   #23
DKB_SATX's Avatar
Alamo Heights , Texas
From Airstream's specs, it looks like the Sports don't come with a heat pump (at least not standard.) If that's the case, I'd guess "Opt Heat" would be a heat strip in the AC unit. I thought the newest version of the thermostat says "HP" for Heat Pump and "HS" for Heat Strip...
— David
Old 02-26-2014, 02:27 PM   #24
Cannonball's Avatar
2024 23' Flying Cloud
San Antonio , Texas
Thanks. If it is a heat strip, it is pretty wimpy. I'll just throw a small electric space heater in my "go box". I have one about the size of a cube box of Kleenix that works really well.
Cannonball is offline   Reply With Quote
Heat Pump Question Ljsydney Full-Timing, Winter Living & Workamping 5 02-23-2014 03:00 PM
heat pump not switching to furnace Alumitater Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-01-2014 06:20 PM
Aux Heat Element Question Ridgerunner3 Furnaces, Heaters, Fireplaces & Air Conditioning 2 02-12-2012 07:16 PM
Ignitor Carbon, Poor Heat linc54 Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-30-2011 06:09 PM
