When we travel, we like to take my guitar and Nancy's keyboard along. It would be really great, in our FC-19 to totally remove the table (temporarily set-a-side) and put music and/or piano stands where the table is for the hour or so we each play. We generally play outside. The problem with that is that we end up with an "audience." Flattering, but distracting. Does anyone utilize this dining space for such foolishness. Our last trailer had a couch area that worked great ... No, we're keeping the FC-19 ... HA! I probably can figure out a way, myself. But, I want to maintain the integrity of the table attachments. Dave
We sit at the table a lot. We haven't, and probably won't use it for sleeping. Always Seated, for both instruments (classical guitar) ... At the table location, only one would fit. Thanks for asking. We don't play together. The question evolved because the hinge system for the table isn't designed to facilitate removing the table. I could probably just spread the thing. But, wondered if anyone had specifically done this.
Good questions ... Thanks for asking! Dave
Some RVs have tables with similar hinges that don't have the wire bales that tie the table top to the wall. These also tip up to unhinge, but then the tabletop completely separates from the mating bracket on the wall.
See post below (on another forum) that has a hinge that might work for you:
Ideas would be to modify the table legs (possibly with the Eddie Bauer style), modify the hinge as suggested above so that it comes off the wall, remove the table altogether and replace with something else, or make up the front table as a bed/lounge, and add a secondary table. I would probably do the last, and then find a nice adjustable height table that could be used for playing and for food prep area either inside or outside.
1965 26' Overlander
Ferndale
Why not just get rid of the table all together and get a couple of folding table trays..?
I sit on a "drummers stool" in mine to practice....compact and provides the proper height and posture support.
I am a guitarist too and often travel with a fellow player. My Airstream 534 has a fixed table that drops up and down to form a second bed. I often have to migrate to my mate's 'van to play inside. This is the only drawback to this otherwise beautiful trailer. Do what I do - go to warm places (we do southern Europe) and set up outside. You will be amazed how many people bring along instruments - usually guitars, and join in. They often bring a few beers as well, and many friendships have been formed this way, with fellow Europeans, French, Dutch, German, Italian, Spanish etc., singing their own songs in their own language, as well as English. Music is international after all! We may have fought each other for centuries, but this is a good way to avoid any more unpleasant episodes! I'm a Brit by the way, but quite proud to be 'European'
You could probably squeeze a Marshal double stack in there along with a B-3 but it might get tight....
Not necessary for Classical guitar, but-
I wonder if a Marshall 8 x 10 speaker cabinet would come through the door. I used to haul it around in a VW bug with the passenger seat and back seat removed. The amp head was in the front trunk...
We also hauled a big ole component stereo system with those big ole monster speaker cabinets and a rack for the many components in there- turntable, EQ, tuner, amp, tape deck, CD player-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
On our 25' International we have removed the table and the starboard side part of the couch and replaced the table with a used flip top unit that we purchased from the used forum. This provides us with the room and the table for my wife to play her keyboard and for me to play my guitar. This set up works for us. Check out our pictures. We are moving to a larger AS, but not because of a lack of room to play our instruments.
We'll be putting our 25' International up for sale soon.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
In our 19'er we've eliminated the dinette table, giving us lots more room. It just seems bigger not dodging the table all of the time. Two shots - with the table, after our first remodel, and without the table, after the remodel we did this year. We have a small table to set up if we need it, but we've found that putting a tray on the cushion at the front suffices in most cases.
Yep, by removing the table (if only temporarily, at times) will sure work. Thanks for the two sets of photos, folks! Very nice of you to take the time to answer our question, any posting these. Dave
Great to know there's other musicians out there bringing along the instruments.
On the drumming side, anyone using electronic ie: Roland TD style due to space / weight or portable recording or live mixing rigs along?
Personally have a small but well equipped home studio, various elect, acoustic guitars, pedal steel, amps, keys, TD drums and would love to bring much of it on the road. Fear size and weight constraints in a 25ft would limit the herd. But could emagine how cool to have the various options on occasion.
Anyone doing this with some road experience and can recommend what works well for you? How about some unique stories or pics of your rigs or chance sessions out on the road?
__________________ Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2020 GMC Sierra Denali Diesel 2500 4X4 10 spd 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
