Old 10-20-2015, 11:08 AM   #15
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I learned a long time ago that you get what you pay for. I typically throw out the hose that the dealer gives you when you buy the trailer and buy a heavy duty branded hose. The difference in the materials make the hose much more resilient to ground debris and wear and tear. As far as length goes, longer is better. I have a 20' hose which serves me well. You can join hoses together if you wish. I know my dealer supplied me with a 10' hose.
Finally I think one of the best things I have bought is a hose support. Here's one. 15' Flexible Sewer Hose Support - Direcsource Ltd 48565 - Sewer Accessories - Camping World
The beauty of these supports are the fact that they keep the hose off the ground and they provide a great drain angle. Again make sure you get one long enough to support a hose.
These are especially good for those sewer connections that stick up above ground level.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-20-2015, 11:34 AM   #16
2005 28' Safari
Saint Joseph , Michigan
Originally Posted by Gillpine View Post
Camco 39761 RhinoFLEX 15' Sewer Hose Kit with Swivel Fitting
It got good mostly good reviews on Amazon.
How does one find out whether one has Valterra or Thetford fittings? Our AS is a 1998 model with the dump valve on the side, not the back.
Thanks for your help again.
Gillpine
We like ours..
TruckerFritz is offline   Reply With Quote
Old 10-20-2015, 01:24 PM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
A tip to keep the hose setup properly,,,
We use the "cheap" hose... To get the proper "slope" get sections of rain gutter and block them up to establish a "grade/slope" from the AS waste outlet to the ground receptor. I then lay the hose in the gutter and "retain" with the long "twist" wire ties...so things stay in place when the water outrush from tanks occur.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-20-2015, 01:44 PM   #18
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
We've always used a single 20 foot hose with no issues other than the odd time I have forgotten to check out the location of the sewer dump on the campsite before setting up .....
If you do get a couple of shorter pieces that will, on occasion, need hooking up together then there is quite an excellent tutorial on how to do this easily and effectively in the movie "RV" with Robin Williams .....
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 10-20-2015, 02:25 PM   #19
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
This is our 6th year with the same Sewer Solution, and 10' extension hose when we need it. Over a thousand nights in our Airstream(s).
Doug and Cheryl
Old 10-20-2015, 02:55 PM   #20
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Using the grey PVC viper hose from Valterra. I see it now comes with a clear plastic sewer elbow so you can monitor the overall chunkiness of your flush....
Old 10-21-2015, 11:07 AM   #21
2000 30' Excella
Monticello , Florida
Six years with sewer solution 😍get rid of your stinky slinky! 😳
07007 is offline   Reply With Quote
Old 10-21-2015, 03:48 PM   #22
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Sewer solution is nice as long as you have running water. What do you do when there isn't water available?
Old 10-21-2015, 04:46 PM   #23
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
No running water? I then use my slinky.
MICHAEL
Old 10-21-2015, 05:33 PM   #24
2007 22' International CCD
No running water--dump gray only in appropriate manner. Haven't filled black on a trip yet without a chance to dump.
KE4GNK/AE
Old 10-21-2015, 10:40 PM   #25
1998 28' Excella
Little Rock , Arkansas
Sewer Solution!?!
What is Sewer Solution?
Gillpine is offline   Reply With Quote
Old 10-22-2015, 06:08 AM   #26
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
Here is a YouTube video on sewer solution.
https://youtu.be/SJ7Sk0-T4CM
Ron
Ron A is offline   Reply With Quote
Old 10-22-2015, 07:57 AM   #27
martian's Avatar
2012 31' Classic
Naples , Florida
I recently moved to the Rhino Extreme Sewer Hose because the connections are easier to unlock than the other brands I've used. They are just better engineered to lock and unlock smoother. Furthermore, in my experience, the connections are tight, no leaks. Rhino Extreme Sewer Hose by Camco Manufacturing is available at Camping World and Amazon.com.
martian is offline   Reply With Quote
Old 10-22-2015, 08:02 AM   #28
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Honestly no bashing, but I used a SS once. It took EPIC amounts of water and never did get my tank clean!
I do see its value for long runs into the sewer, but I'm not overly impressed.
Urgent!! Generator Question Kalidas 2011 - 2015 International 52 07-16-2016 05:43 PM
Urgent Door Question! royalcourt Doors & Locks 6 05-26-2009 02:04 PM
Waste dump hose storage location bkahler Classic Motorhomes 7 09-28-2007 06:38 PM
Urgent vintage grey water drainage question! 1959newbie Waste Systems, Tanks & Totes 6 04-21-2007 09:58 PM
dump hose connector Tin Hut Waste Systems, Tanks & Totes 5 10-11-2003 08:25 PM
