Old 09-20-2011, 09:13 AM   #57
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by azflycaster
...One word of warning - More then a few members have hired an electrician to install an outlet only to have it wired for 240 volts by mistake. Make sure who ever you hire to do the work knows that this is a 120 volt single phase circuit.
Amen! One would think an electrician couldn't get this wrong. It's not a common mistake, but it does happen. Have the electrician confirm it's 110v before you plug in. There are other threads out here that discuss the merits for owning a simple inexpensive tester for checking campground outlets before plugging in.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 09-20-2011, 09:20 AM   #58
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Get a 30 Amp Service Installed
Short answer is, Yes, get 30 amp installed.
A 30 amp plug at the house is really nice for all the reasons stated above.
Make sure the electrican understands what you want.
Many electricians assume you are an idiot who just thinks he wants 30 amps who really needs 220 volts.
Call your nearest RV park and ask for the name of their favorite electrician.
Try to get the circuit run to a point close enough to your parking pad that you won't need a 30 amp extension cord.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 09-20-2011, 09:25 AM   #59
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
On the rare occasions we are plugged in while camping I use this, with adaptor, to check supply/tower.
Also nice to have when on the genset.
ID:	140625   Click image for larger version
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-20-2011, 10:57 AM   #60
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Originally Posted by mcintoshMD View Post
Took delivery yesterday:-).
Congrats! That is my favorite floor plan.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 09-20-2011, 11:54 AM   #61
mcintoshMD's Avatar
2012 20' Flying Cloud
Hopewell , Virginia
The dealer here wants to send their own electrician to hook me up, I'm afraid they are going to take my arm and my leg along with that.
mcintoshMD is offline   Reply With Quote
Old 09-20-2011, 11:56 AM   #62
mcintoshMD's Avatar
Hopewell , Virginia
Actually, I prefer a 16 ft Bambi, go any where park any where just me my dog and may be my wife if Ritz Carlton is close by.
Old 09-20-2011, 12:01 PM   #63
mcintoshMD's Avatar
Hopewell , Virginia
Where do you get one of this?what does it called?
Old 09-20-2011, 12:15 PM   #64
2008 27' Classic FB
Burkburnett , Texas
CW has them
http://www.campingworld.com/shopping...-monitor/24900
If you plug it into a 30A to 15A adapter, you can use it to check the campground's outlet before plugging in
AIR 47751
Old 09-20-2011, 01:32 PM   #65
Doc,
Amazon has 'em also..Amazon.com: TRC AECM20020-3-012 Electra Check Digital Monitor for all AC Power Sources, Black with White Face: Home Improvement
If your planning on getting "hooked-up" a lot in the AS you might also consider getting your surge protected.
PFC
RLC
Old 09-20-2011, 02:10 PM   #66
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
It's not that big a deal - you do have to worry about the breaker connection in a hot main panel box but that is a minor concern if you have ever done it before. The wiring and connection to the RV plug box is very straight forward. It does hit an electrician a little strange to be hooking up a 120VAC 30 amp plug but a little prep on your part will go a long way. First off, if I were to hire an electrician, I would buy all the parts myself. A 30 amp breaker that is designed to fit in your supply panel box - that info is available in your box, a length of 10/2 wire for up to 50 feet of cable length (larger if longer) and the weatherproof RV box/outlet found at Home Depot or Lowes in the electrical section - just ask they will find it for you. This leaves any questions the electrician may have completely out of the install deal - he uses your stuff. Parts ran me about $50.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Electric Jack ...............Rest of the story ohwally Jacks, Stabilizers, Lifting and Leveling 1 05-29-2011 06:43 PM
Airstream Public Television Story Corps Lothlorian Off Topic Forum 4 03-07-2011 07:31 PM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
