09-30-2018, 12:22 PM
#21
2017 28' International
Jim Falls
, Wisconsin
Traveling with a Motorcycle
Originally Posted by Nysaao
Thanks for the input. I’m trying not to buy another trailer but if necessary will get another truck. I have a Indian Vintage so it’s a bigger bike
Maybe a F450 with big flat bed?
https://m.commercialtrucktrader.com/...50--5003574162
10-01-2018, 06:54 PM
#22
Annandale
, Virginia
That might be a little excessive. I don’t want it to be cost prohibitive. Worse case I’ll pass on the AS and get a toy hauler. Point is I won’t bring the bike every time and I’m not a full timer at this point so what might work 50% of the time and still be reasonable. I’m thinking bed rack.
10-02-2018, 09:51 AM
#23
2016 28' Flying Cloud
Dover
, Pennsylvania
We haul 2 dual sport motorcycles inside a Chevy Express cargo van when we tow our Airstream. Bikes are out of the weather and secure. A van makes a really great tow vehicle. We looked at toy haulers but didn't want anythiing that big.
10-02-2018, 10:44 AM
#24
Jim Falls
, Wisconsin
Interesting with the van. What size AS and van?
10-02-2018, 07:53 PM
#25
Dover
, Pennsylvania
28 foot flying cloud trailer and a 3500 van with a 6.0 gas engine and Quigley 4x4 conversion
10-03-2018, 05:24 AM
#26
Annandale
, Virginia
That’s a nice set up Hadn’t thought of the van option.
10-10-2018, 10:43 PM
#27
2017 27' International
Fall City
Indian Road chief would be harder to load in a truck, especially solo, and you would want a 1 ton to be within payload capacity for bike and hitch weight. The ramps aren’t the issue as Big Boy ramps are very wide and you can get extended length; main issue is the height of the truck bed and the weight of the bike. Absent using the power lift, the van sounds like a winner, especially if you can locate a Diesel engine one. Use a mounted Condor chock, they really hold the bike rock steady.
2017 27FB International
2013 Ram 2500 Laramie Crew Cab CTD 4x4
10-11-2018, 12:20 AM
#28
Long Beach
I am building a front hitch mounted dirt bike carrier for my Ram 1500 and Yamaha TW200. I am adding snow plow lights with high and low beams and turn signals, wired to a 7-way pin that I am pigtailing off the rear trailer plug. i am also adding a front license plate holder with light to the front carrier. although my bike is smallish (270 lbs.), and fits mostly between the headlights, I wanted to avoid getting stopped by the highway patrol, so I figured the light/turn signal setup on the front carrier should help with that. i am also lifting the front three inches and adding adjustable shocks to stiffen it up. don't want the suspension bouncing around with the bike up there!
10-11-2018, 10:49 PM
#29
Fall City
RC111, check your payload. You have at least 320 lbs with your carrier, maybe as much as 380 if you use a Versahauler style heavy duty rack. If you are using a weight distribution hitch it may place a very heavy load on the tow vehicle. If it were me I would load the bike in the truck bed.
10-14-2018, 10:49 AM
#30
Annandale
, Virginia
I'm thinking truck bed option with a electric loader ramp type Im wondering about the clearance however. I'm guessing some overhang by the rear bike wheel and ramp. I would likely remove the tailgate and go with those web tailgate type things.
10-14-2018, 11:46 AM
#31
Tampa
After looking at the options, I'd get a van suitable to tow the Airstream. Load the bike in that.
