Old 10-29-2014, 11:49 AM   #1
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Things I like to see on New Airstreams
Gray Water Tank Flushing Valve, like the one for black water tank.
Recently I bought a clear adapter for my dump valve hose connection. As usual, I emptied the black water tank first using the new clear adapter and connected a hose to the black water tank flushing valve.
I was fascinated watching what came out with the flushing valve in operation. Way better than anything on network television. Although, I have to admit an amazing similarity to celebrity worship shows like Entertainment Tonight, Academy Awards, and other orgy of self congratulation award shows, etc.
Anyway, after the black tank emptied, I did the gray tank. Then I thought I'll close the gray tank valve and add a couple of gallons of water. Whoa! I was surprised how much sludge (lack of a better word) came out with fresh water. It then occurred to me how nice it would be to have a gray tank flushing valve too. Or maybe a valve to switch the current flushing valve connection between black and gray. What do you think?
What else could Airstream add to improve new models?
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 10-29-2014, 11:53 AM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
It's a dream but with what I saw this past weekend on some SOB's - an outside kitchen hatch with stove, mini fridge and sink. It's a design issue but do-able.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-29-2014, 12:01 PM   #3
Kevin245's Avatar
Beer Taps.
Eleanor Roosevelt
Old 10-29-2014, 12:08 PM   #4
Portland , Oregon
Originally Posted by Kevin245 View Post
Beer Taps.
That's a good idea or least a mini bar instead of the silly shower thing I never use.
Old 10-29-2014, 12:13 PM   #5
Kevin245's Avatar
In the past I threw this back on the campground. See post 29. http://www.airforums.com/forums/f161...tml#post634460
Eleanor Roosevelt
Old 10-29-2014, 01:19 PM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Picatinny rails around the outside to which accessories can be easily attached… plus a selection of accessories to attach to the rails.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-29-2014, 01:25 PM   #7
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Aluminum decking as opposed to plywood flooring.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-29-2014, 01:31 PM   #8
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Standard Disc Brakes complete with ABS. Jim
Jim Flower is offline   Reply With Quote
Old 10-30-2014, 11:31 AM   #9
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Another vote for standard disc brakes with abs.
Dan
Old 10-30-2014, 12:18 PM   #10
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Disc brakes
16" Michelin LT
Larger AGM batteries
40# aluminum propane tanks
Hensley sway elimination integrated into coupler
Recliner seating option on mid-size models
Less gadgets, better hardware
Doug and Cheryl
Old 10-30-2014, 12:43 PM   #11
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Keyless door locks on trailers.
2012 Dodge Durango Hemi/AWD
Old 10-30-2014, 01:33 PM   #12
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Wi-fi repeater with antenna integrated into something outside, say inside a plastic cover. Maybe a big one on the inside cover of the AC shroud.
Propane fitting for outside grills - quick connect.
Outdoor showers with some sort of flip out ring to hold the head at the right height. I was thinking it would be nice to have an integrated D ring that you hook the shower head into. I may just bungie it into my awning.
robwok is offline   Reply With Quote
Old 10-30-2014, 02:06 PM   #13
Johnco's Avatar
2006 19' Safari
Anaheim , California
Perhaps a tank level monitoring system that actually works...
Johnco is offline   Reply With Quote
Old 10-30-2014, 02:25 PM   #14
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
- Recliner (either chairs or sofa) in the 25-28' units. Or at least something more comfortable than we have now with the "L-shaped" sofa
- more advanced inverter/charger system that actually will not boil the batteries out.
- Some type of built-in WFI system that will boost incoming internet signals.
- a switched external plug up high near the awning to allow for LED lights to be plugged in.
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Airstream - How Can You Get Some Things so Right....and Other Things so..... Fly at Night Our Community 19 12-08-2013 07:44 PM
one of these things is not like the other nesvt Photography 6 11-15-2012 06:33 PM
Do you see what I see? Foiled Again Airstreams on eBay 3 12-28-2011 04:51 PM
Things To See Between Du Quoin and Delaware PARKS1963 On The Road... 1 06-13-2011 02:55 PM
