Old 10-31-2014, 10:21 PM   #57
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Great to know someone from AS is watching.
Here is another thought regarding the black tank flushing valve. The fresh water inlet in just below the flushing valve inlet. When connecting and disconnecting a water to the black tank flushing valve at a dump station, it's almost impossible to prevent non-potable water from dripping onto the fresh water inlet. Not a good idea from a contamination standpoint. Either put them side by side or the fresh water inlet above the flushing valve hose connection.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 11-01-2014, 04:42 AM   #58
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
I would like a smaller trailer with a better layout.
We like the LOCATION of the dinette and bed in the Bambi 16. It has the best line of sight and amount of light in any trailer until you get to the 23 D with the skylights.
What I would add if a custom build option existed:
A wider bed
Oven with additional countertop on top on the kitchen side
As to the bathroom, either
Toilet and separate shower on the bath side. With gray and black tanks. I don't need/want an additional sink.
OR
Existing wet bath with gray and black tanks
OR
Much larger combined gray/black tank with existing wet bath, and a hutch cabinet next to the bath, with counter, cabinet with storage below and upper with storage.
Box that holds 2 batteries, and 2 batteries on the unit.
I know many of you will say that the 20 FC or 22 sport addresses most of these.
But the thing I LOVE the best on the 16 is the location of the bed and dinette. I want the dinette with the pano windows, and I want the bed on the other end, not the bathroom.
And if you look at aisle size, the 16 has the widest aisles of the small trailers, making moving around a bit easier for 2.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 11-01-2014, 05:27 AM   #59
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
A random idea that may or may not be good
At the barber shop they have a shop vac wired in a cabinet in such a way that they sweep hair up to the bottom of the cabinet where there is an opening - they step on a small pedal and the vacuum sucks up the hair
You could make a similar setup for AS maybe -
I store my small 2.5 gallon shop vac under the main bed in front - perhaps it could be simply a small duct built for that door below the bed and wire in a button to touch with you foot - then you could perhaps lift the bed and detach the vaccuum for portable use
I know this sounds kinda crazy I guess - I've been thinking about something like this for a few months - it may be silly - but often I just want to seep up a bit if dust and dirt very quickly
PharmGeek is offline   Reply With Quote
Old 11-01-2014, 05:36 AM   #60
Mont Vernon , New Hampshire
build the Winnick again or at least use the floor plan
it has the best layout to me but i can't buy one because they are so rare
i want one to pull behind my 2007 Interstate
bugsbunny is offline   Reply With Quote
Old 11-01-2014, 06:10 AM   #61
ottawa (greely) , Ontario
Get rid of those interstate junk batteries and put a real deep cycle A.G.M.battery like concord sun x tender ,and put a real converter with real three stage charger and maintenance charge(equalization), also aluminum propane tanks.
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 11-01-2014, 06:52 AM   #62
lewster's Avatar
Naples, FL , Hood River, OR
Interstates are now come equipped with a Magnum MMS-1012 1000 watt sine wave inverter/charger. This has one of the best battery charging systems fully integrated into the unit, which is far better than any converter made. And the are also equipped with Lifeline AGM deep cycle batteries. Looks like they listened a bit for these coaches.
In addition, you never equalize AGM batteries!
Old 11-01-2014, 07:26 AM   #63
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
A build design that assumes components will be upgraded and fixed. For example, conduit between circuit box and controls and major components. This will allow for easier change in wiring if necessary and addition of future sensors. Electrical center on standard rail structure (like server racks) so it would be easy to replace converters.
Access ports to tanks for future changes and current repairs.
DITTO on wifi repeater.
Split A/C so blower is quiet fan inside and inverter driven compressor located outside of shell.
Write a new owners manual that is not a bunch of copied pages from decades ago. With all the new changes in components, each trailer will have a manual tailored to it. A document management system would make this a trivial task with great results.
TheCabin is offline   Reply With Quote
Old 11-01-2014, 07:58 AM   #64
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
No Hensley hitch, don't want to be stuck with that!
Old 11-01-2014, 08:31 AM   #65
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Actually i'm liking this idea as this type of unit is available now right off the shelf. It is very light weight and easy to power. More important it is an issue that my GW complains about all the time as she still have not found a good place to store a dust pan and this eliminate the need for one.
Good Idea!
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 11-01-2014, 08:42 AM   #66
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I don't know why a few folks act like the Hensley/ProPride design is poison even though those who have actually used on know it's the sweetest thing that has happened to bumper pull towing.
Integrating the design elements into the coupler with an easy latch/unlatch system would truly set Airstream apart from the rest as indeed the safest, most comfortable towing travel trailer in the market. It would also allow many potential customers with marginal tow vehicles to be completely comfortable with this wonderfully stable (and possibly exclusive) Airstream trailer.
Doug and Cheryl
Old 11-01-2014, 08:45 AM   #67
millertimeUS's Avatar
1976 25' Tradewind
Great thread!
Ditto on a rot proof subfloor, imagine how secure this would make a new buyer knowing it was impossible to get floor rot with an undetected leak.
Leaks happen but the associated rot could be avoided with rot proof flooring unless Airstream makes too much off the repairs, just my honest observation.
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
Old 11-01-2014, 08:54 AM   #68
Arcticfox's Avatar
Central , Canada
Gee Doug you always know how to push buttons.... (ducking for cover...)
Mind you as a Pro-Pride user myself, I can attest to the superior nature of this type of hitch!
Old 11-01-2014, 08:54 AM   #69
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
This would be number one on my list:
Originally Posted by millertimeUS View Post
Great thread!
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 11-01-2014, 08:54 AM   #70
LucaBluPlus2's Avatar
2014 25' FB Flying Cloud
Rochester , Minnesota
One seemingly simple solution that I would love to see on new Airstreams would be drawers, as opposed to cabinets under couches and beds. While I realize it would steal a bit of space, it would be a fair trade off for not having to get on my hands and knees to access the contents.
-Carrie
If I only had a dollar for every time I got distracted, I wish I had a puppy.
LucaBluPlus2 is offline   Reply With Quote
Airstream - How Can You Get Some Things so Right....and Other Things so..... Fly at Night Our Community 19 12-08-2013 07:44 PM
one of these things is not like the other nesvt Photography 6 11-15-2012 06:33 PM
Do you see what I see? Foiled Again Airstreams on eBay 3 12-28-2011 04:51 PM
Things To See Between Du Quoin and Delaware PARKS1963 On The Road... 1 06-13-2011 02:55 PM
