Old 10-30-2014, 06:35 PM   #29
1974 Argosy 20
Kooskia , Idaho
I would like the option of clear glass in the windows. Not all of us live in hot climates with sunshine which needs to be shielded out all the time. On a gray day my FC 20' is like a tomb inside. My old Argosy with clear glass windows is fine.
Old 10-30-2014, 07:39 PM   #30
Flying Cloud 27
smlbob's Avatar
2015 27' Flying Cloud
Union Hall , Virginia
Better door catches, option recliner in place of dinette
smlbob is offline   Reply With Quote
Old 10-30-2014, 07:53 PM   #31
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I would like to see an on-board 3000 watt LP gas generator to go along with the new 40# aluminum tanks.
Brian
SuEllyn & Brian McCabe
Old 10-30-2014, 08:00 PM   #32
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
I would like the option of having the all in one bath on all models with a bathroom window that opens, even if its small. Also bring back the tub like in the vintage models. I also would kinda like to see out the window in the door. Maybe i could put a decorative stained glass decal on it for a bit of privacy but not that smoked out oval they have now. I would also like the location of the booth and kitchen reversed on the 30ft so the neighbors arent staring at you as you eat breakfast, and while we are at it not have the door block part of the window like the 28ft, and a few diff bedroom layout options I would rather have a smaller bed vs a queen and have more living or dressing room area. hmmm that sums it up I think ooh more plugs both kinds.I think you should be able to design your own.
LilNomad
LiLNomad is offline   Reply With Quote
Old 10-30-2014, 08:48 PM   #33
ottawa (greely) , Ontario
#1 better quality! #2 a floor that doesn't rot , maybe a marine plywood floor covered with a fiber glass resin,or epoxy ,etc, #3 aluminum steps, #4 aluminum frame,#5 a separate black tank on the 16 sport, #6 12 volt outlets (3)one at the tv cable outlet in bed area and one near the radio and one at the dinette area for pluging in Accessories to the already usb outlets that are already on the 2015 models,#7 a outside led light additional,To the LED step light, #8 standard front stainless steel wrap around protectors. #9 Optional 120 volt inverter,# 10 better quality rims ( should not see any corrossion on them for at least 6 years ! Or more.
Don and Carole ( greely ,ontario,Canada)
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 10-31-2014, 01:10 AM   #34
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Why don't they have aluminum floors like the Livin' Lite Camplite (recently bought by Thor)? Or Trex decking?
The Classic does have aluminum steps. That influenced my decision.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-31-2014, 01:12 AM   #35
m.hony's Avatar
2013 30' Classic
The Classic also has a scare light and stainless steel rock guards. All of these things can be added to the Sport at Jackson Center. I know because I've seen it done.
TAC #MS-10
Airforums #70955
Old 10-31-2014, 07:45 AM   #36
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
It would be nice to have one of those "scare lights" especially today October 31....
Sorry could not resist.
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 10-31-2014, 08:10 AM   #37
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by Gnorts View Post
I'd like wiring chases with taglines that connect the equipment spaces together. Many boat builders include these to make it easier to install electronics and other equipment that needs power. It would add very little materials and labor cost to put in the chases when the wiring is pulled at the factory.
Our Flying Cloud didn't come with the factory-installed inverter, and it will be tough to install one in the finished trailer. There's no way to get wiring from the battery relay in the front to the charger and load center in the galley, or to the space behind the fridge on the road side. I want to install a simple inverter in the front stowage area that will power a dedicated outlet strip in the closet, on the road side forward of the fridge - to run the wine cooler while we're on the road! The trailer gets too warm when on the road, and the wine cooler will keep the Cabernet ready to drink when we stop for the night. The cooler draws very little AC current, and the batteries are being charged by the TV when connected, so no discharge worries. We can also use the outlets in the closet to charge all our electronic toys.
We're talkin' necessities here...
I've done that installation many times! There IS a very elegant way to do what you seek.
PM me for details!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-31-2014, 09:10 AM   #38
An aluminum frame was research tested in San Antonio, some 4 decades ago.
It was ahuge failure, yet it appeared to be well constructed.
I saw it under test.
Old 10-31-2014, 10:33 AM   #39
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Many folks are asking for more dc and ac electrical outlets. That most probably requires additional battery and battery charging capacity, which I would like to see in the form of larger solar output to larger AGM batteries with their solar option.
Doug and Cheryl
Old 10-31-2014, 11:16 AM   #40
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Wow! As the OP I'm didn't expect this many responses and so many great ideas. It was kind of a tongue in cheek comment about how I fell about network TV, especially celebrity worship shows. Most of you seemed to miss that or chose to ignore it. I hope some from Airstream Inc. is looking as this, as there are some good ideas and valid complaints.
I have mixed feelings about this but my wife would like to see a 30' front bedroom. Probably would have to buy a new AS, but at least I know what I'd order.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 10-31-2014, 12:46 PM   #41
Arcticfox's Avatar
Central , Canada
Originally Posted by hhendrix View Post
(snip) I hope some from Airstream Inc. is looking as this, as there are some good ideas and valid complaints.
If anyone has email addresses of Management people at Airstream it would be advisable to forward a link to this thread. As it will allow them to watch the thread and get valuable feedback from both their existing owners and the buying public as a whole. I would think that would be a valuable tool when planning future production options.
Cheers
Doug
Old 10-31-2014, 12:59 PM   #42
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Cheers
Doug
Can't verify, but I'm almost certain that Airstream Corp has someone in the management group monitor this forum. What better way to get feedback on their products?
If they don't, I'd be very surprised.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Airstream - How Can You Get Some Things so Right....and Other Things so..... Fly at Night Our Community 19 12-08-2013 07:44 PM
one of these things is not like the other nesvt Photography 6 11-15-2012 06:33 PM
Do you see what I see? Foiled Again Airstreams on eBay 3 12-28-2011 04:51 PM
Things To See Between Du Quoin and Delaware PARKS1963 On The Road... 1 06-13-2011 02:55 PM
