Old 10-30-2014, 02:32 PM   #15
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by dkottum View Post
Disc brakes
16" Michelin LT
Larger AGM batteries
40# aluminum propane tanks
Hensley sway elimination integrated into coupler
Recliner seating option on mid-size models
Less gadgets, better hardware
Ditto.
Brian
SuEllyn & Brian McCabe
Old 10-30-2014, 03:20 PM   #16
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
ideas
Yeah, I like the disc brakes idea. Would be very simple to change those brake pads at maintenance time and better stopping power.
Not to sure about full blown ABS, should keep it as simple as possible to keep some of the cost down.
The outside grill is an excellent idea. My previous Some other brand, had a flip down propane grill and sink with hot and cold running water, or you could plug in the handy hose attachment into the spigot and have outside shower. It was neat.
I like the modern converter idea with four stage battery charger that doesn't cook your batts well done.
I would like the belly-pan to be held up with actual bolts or screws so that you could remove a section at a time for access to work on stuff underneath.
I had actual LED lights (2) with a switch under there so you could work at night on wires or water lines. I could remove the belly covering in sections for access. I was going to do that here and then I saw all of those rivets. Holy Cow.
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 10-30-2014, 03:23 PM   #17
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Pleased with our disc brake conversion. Tuson does have an ABS conversion.
Old 10-30-2014, 03:29 PM   #18
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
Things I like to see on New Airstreams
The new trailers do have a propane quick disconnect port....just not on the side where it would be more useful.
I wish there was an easy/simple way of knowing what your actual propane level was at.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
cory_can is offline   Reply With Quote
Old 10-30-2014, 03:36 PM   #19
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I don't know why they did that, couldn't have been much more effort to put it on the street side.
2012 Dodge Durango Hemi/AWD
Old 10-30-2014, 03:39 PM   #20
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
It seems like a trailer disc brake ABS system would be out of sync with the truck's ABS system and cause a lot of jerking for the hitch system to withstand. I'd rather keep it simpler.
Doug and Cheryl
Old 10-30-2014, 03:44 PM   #21
switz's Avatar
2014 31' Classic
Images: 8
The Tuson control system plugs into the OBDII port of the truck so it knows what the truck is doing as it sends a brake signal to the ABS hydraulic brake controller mounted on the trailer. The main thing is that the trailer brakes do not lock up when the roads are wet and a max brake situation arises.
Old 10-30-2014, 03:47 PM   #22
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by clancy_boy View Post
It's a dream but with what I saw this past weekend on some SOB's - an outside kitchen hatch with stove, mini fridge and sink. It's a design issue but do-able.
My Airstream has an outside kitchen- a folding table and an electric griddle-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-30-2014, 04:46 PM   #23
laducky's Avatar
1978 28' Ambassador
Pacifica , California
Originally Posted by robwok View Post
Wi-fi repeater with antenna integrated into something outside, say inside a plastic cover. Maybe a big one on the inside cover of the AC shroud.
Oh that's a good one!! Hmm has anyone done this? I would consider doing that if it's functional...
Keep on truckin!
airstreamcalledtrouble.blogspot.com
laducky is offline   Reply With Quote
Old 10-30-2014, 04:47 PM   #24
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
I'd like wiring chases with taglines that connect the equipment spaces together. Many boat builders include these to make it easier to install electronics and other equipment that needs power. It would add very little materials and labor cost to put in the chases when the wiring is pulled at the factory.
Our Flying Cloud didn't come with the factory-installed inverter, and it will be tough to install one in the finished trailer. There's no way to get wiring from the battery relay in the front to the charger and load center in the galley, or to the space behind the fridge on the road side. I want to install a simple inverter in the front stowage area that will power a dedicated outlet strip in the closet, on the road side forward of the fridge - to run the wine cooler while we're on the road! The trailer gets too warm when on the road, and the wine cooler will keep the Cabernet ready to drink when we stop for the night. The cooler draws very little AC current, and the batteries are being charged by the TV when connected, so no discharge worries. We can also use the outlets in the closet to charge all our electronic toys.
We're talkin' necessities here...
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 10-30-2014, 04:48 PM   #25
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Plug inverter into 12v accent light?
robwok is offline   Reply With Quote
Old 10-30-2014, 04:49 PM   #26
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
If it's a low use charge...
Old 10-30-2014, 05:05 PM   #27
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I second a tank level monitoring system that works excellent as well and a battery monitor
4 stage charger/inverter
If not better stock batteries - make the box very simple for upgrade later
Replace the outdoor "scare light" with anything that would be in some way desirable
Disc brakes sounds very nice
Better FW tank valve
PharmGeek is offline   Reply With Quote
Old 10-30-2014, 05:56 PM   #28
Slowpoke
Gnorts's Avatar
Portland , Oregon
Too much load for that. Gotta plan for the worst case. None of the loads are large individually, but if they were all on at once, drawing maybe 5A of 120V, that translates to 50A of 12VDC. Bigger than any single DC load on the trailer. Hence, a 1000W inverter, connected directly to the batteries (fused, of course) with short lengths of #2 wire, and then 14-3 stranded wire from the inverter to the closet. I'll use an outdoor grade commercial extension cord for the AC run, but I sure would like to be able to pull that wire inside the trailer without having to drill out rivets and drop belly pan panels...
Airstream - How Can You Get Some Things so Right....and Other Things so..... Fly at Night Our Community 19 12-08-2013 07:44 PM
one of these things is not like the other nesvt Photography 6 11-15-2012 06:33 PM
Do you see what I see? Foiled Again Airstreams on eBay 3 12-28-2011 04:51 PM
Things To See Between Du Quoin and Delaware PARKS1963 On The Road... 1 06-13-2011 02:55 PM
