Suggestions about winterization..
Hi community,
I have an Airstream Serenity 19´2016 that I am running as an Arbnb in my yard in Flagstaff.
1. How I can keep running the Airstream during winter times?
2. It is enough to use Heat pump unit in my AC to avoid winterization, frozen pipes, related issues,etc?
3. Do I have to run the furnace on propane? If so, Will be enough a 100lb manchester propane tank for a month?
4. How much shuld I expect to spend per month to run the Arisream during winterazion?
Thank you so much communit
