Old 09-08-2019, 03:45 PM   #1
BoatnutG2
BoatNutG2's Avatar
2015 28' Flying Cloud
Fountain Valley , California
Stuck propane valve on full propane tank.
Hi all
When I tried to fill up my two propane tanks at Tractor Supply yesterday. They could fill one fine(it felt empty when we started). The other would not take any more propane with the valve turned all the way open and it felt full by weight. When I open the valve (disconnected) I can not hear any leaking nor smell any gas.
Any suggestions on how to free up the stuck valve? Or how to get rid of the full tank?
BoatNutG2 is offline   Reply With Quote
Old 09-08-2019, 04:00 PM   #2
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Originally Posted by BoatNutG2 View Post
Hi all
I had a similar experience. I had a full tank that I could not get to work. I took it to a propane fill station and they couldn't make it work. It was a 20# exchange tank so I just exchanged it with one that worked.
But, after learning more about propane tanks, I believe the tank was overfilled when I had it refilled. I believe I could have turned the bleed valve that is used while refilling to let some of the pressure off and then the tank may have worked. I'm not sure of this. Just giving my thoughts on something I could have tried to make that tank work.
Maybe others can give their thoughts on bleeding some excess propane from the tank to make it work?
2018 Globetrotter 27Q, 32 nights 4,935 miles, 600W Solar, PD4655L, Duracell EGC2 Batteries, ProPride, 16" Michelin's, Champion 3400W Dual-Fuel, 2019 F250
Sold: 2017 Flying Cloud 25FB, 316 nights 40,150 miles, 400W Solar
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 09-08-2019, 05:33 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The Over Pressure Device will also shut off flow if no back pressure is felt. You must have something connected and open the tank valve slowly or it will not allow propane to leave the tank.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-15-2019, 10:22 PM   #4
BoatnutG2
BoatNutG2's Avatar
Thank you for the input. You are both correct. I bleed off the overpressure on both tanks. Also on the crossover valve there is a pressure bleed screw and now the stove, fridge, water heater and external port works great. It turns out when I filled the tank last year that I was having “trouble with” the air temperature was in the 50s now the air temperature is in the 90s so I’m guessing the gas has expanded and over pressured the tank.
Black Tank Valve Stuck in ON. Tank not emptying. eyechip Sprinter and B-van Forum 3 09-25-2018 11:07 PM
Black Water Tank Valve Stuck Closed coolbabe Waste Systems, Tanks & Totes 9 11-21-2017 09:47 AM
Hot Water Heater Stuck on Full Blast clicknathan Water Heaters, Filters & Pumps 2 06-08-2015 01:00 PM
Black water tank valve stuck open MJBear General Repair Forum 7 06-18-2013 11:40 AM
Tank valve stuck Goin camping LP Gas, Piping, Tanks & Regulators 3 11-22-2009 10:54 AM
