Old 08-21-2013, 06:18 AM   #1
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
Storage: Covered vs. Uncovered
We live in east Texas. Besides the cost of storage, what are the pros and cons of covered vs. uncovered?
Will_Brule is offline   Reply With Quote
Old 08-21-2013, 06:30 AM   #2
JDS
2014 Bowlus Road Chief
JDS's Avatar
Cumming , Iowa
I can't think of any reason not to prefer covered storage, aside from the increased cost. Better all around.
John S.
JDS is offline   Reply With Quote
Old 08-21-2013, 06:38 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Depends on whether you're relying on solar panels to keep the house batteries charged up.
Also depends on what you mean by "covered." If you're talking about a fabric cover draped over your trailer, the abrasion casued by wind blowing the fabric every day can do more damage than the sun. Especially in a dusty environment where you can get dust under the cover. That turns the soft knap on the inside of the cover into something resembling sandpaper.
If you're talking about under a roof, that's ALWAYS better, unless you're relying upon solar panels. Some reasons: Hail turning your Airstream into a shiny golf ball. Rain finding new ways to leak in. Ultraviolet light damaging the tires and a/c shroud. None of those happen nearly as often under a roof.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-21-2013, 07:05 AM   #4
Will_Brule's Avatar
Palestine , Texas
Covered
Intended it to mean a structure with a roof.
Old 08-21-2013, 07:48 AM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Covered storage is much better than in the open. The sun eventually ruins seals, plastics, tires, and even the clearcoat finish on your Airstream. The heat generated inside an uncovered Airstream deteriorates interior components.
A con would be if the structure was too weak, and the wind blew it over onto the trailer.
doug
Old 08-21-2013, 07:51 AM   #6
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I have my concrete pad ready to pour soon...and my new AS will be in the open likely until march 2014 at which point I plan on constructing something...a pole barn likely...
As I debated this question, the only argument against I heard made was:
1) if a new AS, let it get the water exposure and see if any leaks during 2 year warranty period.
2) aesthetics if in your back yard are changed...
3) cost
4) cant get a permit for covered storage at your house
It seems like your insurance rate should tick down a bit if you have covered storage?
I have seen very few arguments against covered storage, except for the cost....and I am sure many will run some numbers to show that a typical cost of build vs. projected savings in maintenance makes this pretty desirable...then factor in peace of mind and keeping it in better general appearances for longer...seems like a no brainer?
PharmGeek is offline   Reply With Quote
Old 08-21-2013, 09:12 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
How long have you lived in Texas? Hail up to four inches in diameter. Inch hail all the time. And.....storage in the sun will deteriorate the clear coat for sure.
Old 08-21-2013, 09:36 AM   #8
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Between the heat and UV radiation you're guaranteed to get, and the hail you're likely to get, there's no downside to covered storage except the extra expense.
I didn't seriously consider uncovered storage for the trailers. I lucked out and found a good price on covered storage WITH power that's next door to a police station, so security is pretty decent too.
— David
Old 08-21-2013, 09:46 AM   #9
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
If you can afford a covered storage, it's totally worthwhile. You'll be protecting your finish, bird crap won't get on it, protect it from flying debris from nearby trees (if there are any in East TX). There's no downside to covered storage as far as I'm concerned.
Our cover is 12 X 20 and cost $1600 fully installed. We didn't have to lift a finger. We had used vinyl 'carport' type covers for years, replacing the cover every few years. This will last forever. This is particularly important for our vintage trailer because it has tiny leaks, and it rains a lot here.
ID:	193745   Click image for larger version
Stephanie
Old 08-21-2013, 10:10 AM   #10
DKB_SATX's Avatar
1976 Argosy 28
There are lots and lots of trees in East TX, and quite a few in central (Hill Country) and north-central (Prairies and lakes). It's West and South TX that are largely plains country with scrubby trees or none.
— David
Old 08-21-2013, 10:45 AM   #11
dkottum's Avatar
Under tree storage is troublesome; extremely dirty from tree sap, bird crap, leaves, bugs, seeds, mold, and dirt that sticks to it all from our experience. A difficult and abrasive scrubbing can result.
doug
Old 08-21-2013, 11:50 AM   #12
1965 22' Safari
Send a message via Skype™ to chromis
Definitely covered also consider what amenities they have:
30a power
water
dump station
Having a place with a dump station is something to consider, it is certainly a convenience..
chromis is offline   Reply With Quote
Old 08-21-2013, 12:32 PM   #13
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
IF you can do, it go for the covered storage. Weather, tree stuff, sun, you name it....are not so much of an issue, and it's sure easier to clean the trailer without layers of gunk.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-21-2013, 12:57 PM   #14
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Look at a 10-15 y/o car or truck that has always been kept in a garage when not being used vs one that has never been garaged or covered. The sun is tough on things and tree "funk" is too if you park it in the shade. I am ordering a carport type cover for my 68 Trade Wind next week. Many of the things that I spent hours and days restoring are already showing age from sitting out after only 3 years.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
