08-21-2013, 06:18 AM
2014 25' FB Flying Cloud
Palestine
Storage: Covered vs. Uncovered
We live in east Texas. Besides the cost of storage, what are the pros and cons of covered vs. uncovered?
08-21-2013, 06:30 AM
2014 Bowlus Road Chief
Cumming
, Iowa
I can't think of any reason not to prefer covered storage, aside from the increased cost. Better all around.
John S.
08-21-2013, 06:38 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Depends on whether you're relying on solar panels to keep the house batteries charged up.
Also depends on what you mean by "covered." If you're talking about a fabric cover draped over your trailer, the abrasion casued by wind blowing the fabric every day can do more damage than the sun. Especially in a dusty environment where you can get dust under the cover. That turns the soft knap on the inside of the cover into something resembling sandpaper.
If you're talking about under a roof, that's ALWAYS better, unless you're relying upon solar panels. Some reasons: Hail turning your Airstream into a shiny golf ball. Rain finding new ways to leak in. Ultraviolet light damaging the tires and a/c shroud. None of those happen nearly as often under a roof.
08-21-2013, 07:05 AM
Palestine
Covered
Intended it to mean a structure with a roof.
08-21-2013, 07:48 AM
2012 25' Flying Cloud
Battle Lake
Covered storage is much better than in the open. The sun eventually ruins seals, plastics, tires, and even the clearcoat finish on your Airstream. The heat generated inside an uncovered Airstream deteriorates interior components.
A con would be if the structure was too weak, and the wind blew it over onto the trailer.
doug
08-21-2013, 07:51 AM
2014 30' FB FC Bunk
Hoover
, Alabama
I have my concrete pad ready to pour soon...and my new AS will be in the open likely until march 2014 at which point I plan on constructing something...a pole barn likely...
As I debated this question, the only argument against I heard made was:
1) if a new AS, let it get the water exposure and see if any leaks during 2 year warranty period.
2) aesthetics if in your back yard are changed...
3) cost
4) cant get a permit for covered storage at your house
It seems like your insurance rate should tick down a bit if you have covered storage?
I have seen very few arguments against covered storage, except for the cost....and I am sure many will run some numbers to show that a typical cost of build vs. projected savings in maintenance makes this pretty desirable...then factor in peace of mind and keeping it in better general appearances for longer...seems like a no brainer?
08-21-2013, 09:12 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
How long have you lived in Texas? Hail up to four inches in diameter. Inch hail all the time. And.....storage in the sun will deteriorate the clear coat for sure.
08-21-2013, 09:36 AM
Alamo Heights
Between the heat and UV radiation you're guaranteed to get, and the hail you're likely to get, there's no downside to covered storage except the extra expense.
I didn't seriously consider uncovered storage for the trailers. I lucked out and found a good price on covered storage WITH power that's next door to a police station, so security is pretty decent too.
— David
08-21-2013, 09:46 AM
1968 17' Caravel
Battle Ground
If you can afford a covered storage, it's totally worthwhile. You'll be protecting your finish, bird crap won't get on it, protect it from flying debris from nearby trees (if there are any in East TX). There's no downside to covered storage as far as I'm concerned.
Our cover is 12 X 20 and cost $1600 fully installed. We didn't have to lift a finger. We had used vinyl 'carport' type covers for years, replacing the cover every few years. This will last forever. This is particularly important for our vintage trailer because it has tiny leaks, and it rains a lot here.
Stephanie
08-21-2013, 10:10 AM
Alamo Heights
There are lots and lots of trees in East TX, and quite a few in central (Hill Country) and north-central (Prairies and lakes). It's West and South TX that are largely plains country with scrubby trees or none.
— David
08-21-2013, 10:45 AM
Battle Lake
Under tree storage is troublesome; extremely dirty from tree sap, bird crap, leaves, bugs, seeds, mold, and dirt that sticks to it all from our experience. A difficult and abrasive scrubbing can result.
doug
08-21-2013, 11:50 AM
1965 22' Safari
Austin
Definitely covered also consider what amenities they have:
30a power
water
dump station
Having a place with a dump station is something to consider, it is certainly a convenience..
08-21-2013, 12:32 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
IF you can do, it go for the covered storage. Weather, tree stuff, sun, you name it....are not so much of an issue, and it's sure easier to clean the trailer without layers of gunk.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
08-21-2013, 12:57 PM
1968 24' Tradewind
Oxford,
, Mississippi
Look at a 10-15 y/o car or truck that has always been kept in a garage when not being used vs one that has never been garaged or covered. The sun is tough on things and tree "funk" is too if you park it in the shade. I am ordering a carport type cover for my 68 Trade Wind next week. Many of the things that I spent hours and days restoring are already showing age from sitting out after only 3 years.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
08-21-2013, 01:03 PM
2014 30' FB FC Bunk
Hoover
, Alabama
BAB...how much did that design/build end up costing you if you do not mind me asking...also what are the dimensions?
I am still figuring out the cover...the carport will be put down (concrete) supposedly any day
08-21-2013, 07:43 PM
2015 30' Classic
Greensboro
, North Carolina
I didn't really have an architect, but sketched out what I wanted. The company that did the structure had built a pool house for me, and I wanted to match the roofline, the posts and the cedar siding. The SilverLeaf shed is 32 feet long (trailer is 28'), and it is 11 feet wide between the posts. This is VERY narrow when you're backing an 8.5' trailer. The shed was $17,000 and the cement slab (around 45 feet from the edge of my driveway to the end of the shed) was around $6,000. I also had landscaping done ($500), then I ran a cable and a 30 amp RV box from the panel in my pool house (around $100), water pipe (PEX) and a hose bib ($35), and tapped into the sewer line under my pool house for the sewer connection (PVC pipe-- $20). Gutters for the shed were around $200). The shed has an insulated roof, and the siding goes down more than halfway on three sides. It was also built so someone could come in and finish the siding, install a garage door and put a car or a boat in there (or perhaps use as a workshop/studio). BTW, my two basset hounds love to go out there and sleep on the cool cement slab under the trailer. This was a no-cost add on!
_________________
ProPride 3P
AIR# 58452
08-21-2013, 08:27 PM
1999 34' Excella
Hillsboro
Here's our rented place for now. $220/mo
Peace and Blessings..
Channing
WBCCI# 30676
08-21-2013, 08:38 PM
2013 27' FB Classic
Clermont
Pictures please!
Tom & Lori
2013 27 FB Classic Limited
2019 Ford F250 King Ranch 6.7L Diesel
WBCCI 03288 TAC PA-17
08-22-2013, 06:12 AM
2015 30' Classic
Greensboro
, North Carolina
There's a pic at post #13. Here are a couple of others as construction progressed:
_________________
ProPride 3P
AIR# 58452
08-24-2013, 08:34 PM
JandD
Weaverville
Very nice looking pole barn for your airstream. I am hopping to have a similar one built for my 25' flying cloud. It will be a littler smaller and cheaper I trust. And thanks for sharing the cost information.
J and D
