Old 04-18-2019, 07:13 AM   #1
2019 27' Tommy Bahama
Ocean Pines , Maryland
Solar and Walmart Campground
Our Tommy Bahama has solar panels. We plan on using solar only for "Walmart Campground". What can we run, or conversely, what can't we run during our Walmart stay. Secondly, what does Walmart, in general, think about using their parking lot as a wayside?
Docbutch is offline   Reply With Quote
Old 04-18-2019, 07:21 AM   #2
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Check with RV camp applications like RVParky or Campendium - not all WalMarts allow overnight parking.
You can run your refrigerator, hot water heater, and heater on propane.
For electricity, you can run the Fantastic Fan and stove vent and stereo.
When you turn on your inverter, you can run about any appliance you can plug into a 120V outlet. Heat-type appliances, like blow-dryers or toasters or elec. coffee pots will suck down your batteries.
The best way to do this is go to a regular campground for a couple of nights with full hookups. Spend one day fully hooked doing all your regular routine. The next day, unplug, and do it again. You will quickly learn whether you can survive overnight, and what if anything in your routine has to change.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 04-18-2019, 07:27 AM   #3
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Your inverter is probably 1000W, which won't be enough to run some appliances, and not all of your outlets are energized by the inverter.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 04-18-2019, 07:41 AM   #4
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
Do you have two 80W panels? That 160W of panels can produce 480W on a typical sunny day. 480w/13.5a=35AH of battery charging. What can I run on 35AH per day? I can run my refrigerator on propane which takes 24AH and have 11Ah for other items. You will need some amps for the propane water heater, water pump and lights. You will still have a few more amps which could run the fantastic fan for a few hours or maybe one hour of TV. That is what I think your solar can maintain on a daily basis.
Now your batteries will have some amp hours in storage. So you could run the fantastic fans all night or more TV if you will be connected to shore power within a day or two.
The above also assumes the factory solar is as efficient as my self-installed solar installation with a Victron controller and 6 Gauge cable to the bus bars. If I had factory solar, I would consider upgrading the controller to a Victron and upgrading the controller to busbar cables to 6 gauge to increase its efficiency.
2017 Flying Cloud 25FB (Miles) 234 nights 31,732 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's
2019 F250, 6.7 Power Stroke, 4x4, 1.5" Leveled (Sully)
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 04-18-2019, 07:55 AM   #5
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Solar PV is redundant when travelling as your TV will likely fully charge your house batteries while towing. As you will be stopping at Walmart late in the day and leaving early in the morning, when the sun is low, your solar panels will not be of much help. They can help charge your batteries on sunny days when you are boon docked for several days.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 04-18-2019, 08:06 AM   #6
Mollysdad's Avatar
Originally Posted by docbutch View Post
what can't we run during our walmart stay.
a/c
(That's funny, I typed A/C and the post is a/c)
Old 04-18-2019, 09:12 AM   #7
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Adventure AS is right
Adventure.AS has it nailed. By the time you pull into a Walmart and stay overnight your batteries are charged. You should be more concerned about the health of your batteries, their capacity. With healthy batteries you will easily have enough capacity to run your refrig and hot water on propane(they require DC control power), water pump for showers, LED lights, and a Fantastic Fan. You are pushing it if you plan to use your inverter for anything including TV, toaster, coffee pot, etc.
You will not stay more than one night as they generally do no allow it. We prefer Cracker Barrel, seems safer and quieter.
Larry
lsbrodsky is offline   Reply With Quote
Old 04-18-2019, 09:48 AM   #8
SewStream's Avatar
Sanford , Arizona
@Docbutch - if I am correct, your 27’ is nearly the same layout as our 27’ Globetrotter. Here is our experience boondocking/dry camping in a parking lot overnight. We had the same factory solar set up with the 1000W inverter. We did not use a generator. Batteries were fully charged when we arrived.
First total fail - the outlet in the galley is NOT an inverter outlet! If you have plans to use electricity in the galley; forget about it. No coffee maker, no Instant Pot, no nothing. Fortunately, we can make pour over coffee using the range and a tea kettle.
Second total fail - the outlet in the lavatory is NOT an inverter outlet. And, my hair dryer is 1200W. No can do. If you use an electric shaver; forget about it.
Third total fail - after running the Fantastic fan overnight, our batteries were at 36%! They should not go below 50%. Therefore, you cannot safely run the fan overnight without damaging the batteries.
Our conclusions about the factory solar package - it is only good for keeping the AGM batteries charged when your AS is in outside storage, and using the lights in the coach. Everything else (at least for us) will damage the batteries because they draw too much from the battery storage.
Our solution was to remove the factory solar package and upgrade our solar capabilities to support our boondocking Airstream lifestyle. Now we can use all our appliances, and even run our air conditioning for a few hours off of our solar/lithium batteries.
SewStream is offline   Reply With Quote
Old 04-18-2019, 10:09 AM   #9
AirMiles's Avatar
^^^^^Agreed!!!!!
My self-installed 400W of solar with a Victron 100/30 controller, using the factory prewire, can easily replace the 100AH per day I use from my 230AH golf cart batteries. Its like having "perpetual" battery power for boondocking. But some things cannot be powered from the small 1000W inverter and a small 230AH battery bank, such as the microwave and A/C, so I carry a generator to power those appliances.
My experience with the factory non-solar charging system, including the converter, Interstate batteries, and 12V charging from my tow vehicle was also a "total fail" for boondocking.
Old 04-18-2019, 12:19 PM   #10
Long Island , New York
. . . what does Walmart, in general, think about using their parking lot as a wayside?
There is a Sticky thread on this general topic FYI, with over one-thousand posts:
http://www.airforums.com/forums/f42/...ing-13082.html
Sticky on top of the list here: http://www.airforums.com/forums/f42/
As you can see, the reception at each Walmart varies widely.
FYI
Old 04-24-2019, 10:54 AM   #11
2018 30' Classic
Traverse City , Michigan
Have to get this off my chest. Why do people pay large sums of money to purchase an AS and tow vehicle then go cheap and sit in a parking lot? Understand if you’re “stuck” but a little planning would avoid that. Campgrounds are important and why not support them!?! Many are family owned. WalMart sure isn’t camping.
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
SMKovalchik is offline   Reply With Quote
Old 04-24-2019, 10:57 AM   #12
lsbrodsky's Avatar
Here is one answer. I have been on trips where there was absolutely no campground within a reasonable distance of the point where I needed to stay overnight. When I plan ahead, I try to use courtesy parking for that, but the coverage is limited. However, there always seems to be a Cracker Barrel or Walmart when necessary.
Larry
Old 04-24-2019, 11:34 AM   #13
2007 22' International CCD
Not everyone has the cash flow needed to pay for campgrounds all the time. Retired folk may be subject to this as well.
Besides, we don’t need many amenities when we stop overnight on a trip to get somewhere. A dump station, and 30-amp power in the summer is all we typically need. Our inverter generator is quiet enough if no power is available.
If I am making tracks cross country to a destination, it’s often easier to moochdock in a Walmart or Cracker Barrel lot than try to do the detailed planning to reserve spots in a campground.
This also avoids the “gotta get there syndrome” that makes you try to drive too late at night or too tired to make a reservation. If your Airstream is set up for even light boondocking it may be easier to just stop and camp out and get a nap instead of risking an accident.
We also travel with dogs, and potty breaks for them and us are highly variable in duration and spacing. Better to build on a lot of slack time, or just eliminate the urgency of making it to the next pre-paid stop.
Old 04-24-2019, 11:52 AM   #14
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you have the "stock" battery setup you likely have two 100 AH AGM batteries. That gives you 200 AH total of which half is "usable capacity". Roughly speaking 80 to 100 AH per day is not an unreasonable "power budget". You can get below that with some care. Inverter use is likely to make getting below 60 AH pretty hard.
If your "charge wire" from the TV is typical of many, you will get around 6A of charge current from it. Drive for 4 or 5 hours and you put 20 to 30 AH into the batteries. On a lot of vehicles, getting *anything* from the charge wire is a challenge ( relays / fuses missing ....).
Solar varies all over the place depending on things like shade and clouds. On a *really* good day the factory two panel setup might get you 50 AH. On a more normal day (at least around here ...) you could see half of that or less.
A lot of this gets clouded by the way a lead acid battery does its thing. Getting to 80% charge can be pretty quick. The next 20% may take quite a while. Since you are always operating above 50%, this *is* the region you will normally be in.
One thing that is *very* worthwhile is a shunt based battery monitor. Without one it is *very* hard to figure out what's what on a battery system,.
Walmart, Kmart and Targets... mack-in-nc On The Road... 1 05-27-2012 07:30 AM
Help With Campground Hunt - Sundance RV Park And Campground - Coram, MT rebelstand On The Road... 4 08-03-2011 12:18 PM
