Old 02-28-2019, 11:36 AM   #15
1976 31' Sovereign
Oswego , Illinois
The older AS that had aluminum frame w/square corners around glass were more dangerous than new style w/rounded corners. Yes I have large scar from old style & after 53 yrs. still forget to duck at door frame.
Old 02-28-2019, 11:45 AM   #16
2019 25' International
Washington , Washington, D.C.
eagletoo - I'm intrigued - where do you hang them on the windows?
PatLee is offline   Reply With Quote
Old 02-28-2019, 11:59 AM   #17
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
The older windows with frames were the worst... These have the little aluminum closure that bruises and cuts to the bone.... Double whammy!
Old 02-28-2019, 12:49 PM   #18
On Comet
2017 25' Flying Cloud
Santee , California
Try "Remove Before Flight" tags
I had the same problem when I first got my Flying Cloud and after banging my head a couple of times (was wearing a ball cap so no damage to the trailer) I got some red "Remove Before Flight" tags on Amazon.
I clipped a spring loaded key ring to each tag and clip it onto the latch bracket attached to the window glass when the window is open. Saved my noggin several times!
I also purchased a couple of 17" long tags and attach those to my X-Chocks so that I don't drive off with them still in place.
When fellow campers ask why Remove Before Flight, I just smile and replay "well, the trailer is a Flying Cloud".
Silver Comet is offline   Reply With Quote
Old 02-28-2019, 01:07 PM   #19
eagletoo's Avatar
2019 23' International
Long Island , New York
PatLee,
They are metal badge clips from Amazon (where else?)
The clips hold very well, will not blow off nor scratch the glass.
I also use them to hang my pumpkin mini lights off the awning.
Long May You Run!
Bruce
2019 23FB International Serenity
2018 Jeep Overland 5.7L Hemi with factory towing package
Equal-i-zer Hitch
WBCCI #2600
Id rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 02-28-2019, 01:27 PM   #20
Providence , Rhode Island
Pics or it didn't happen.........
kittmaster is offline   Reply With Quote
Old 02-28-2019, 01:54 PM   #21
eagletoo's Avatar
Here's my "warning" flag that I hang off my windows
Long May You Run!
Bruce
Equal-i-zer Hitch
WBCCI #2600
Old 02-28-2019, 01:57 PM   #22
eagletoo's Avatar
And my all-purpose clips
Long May You Run!
Bruce
Equal-i-zer Hitch
WBCCI #2600
Old 02-28-2019, 03:15 PM   #23
Fullerton , North Dakota
Sliced head open on window
After my husband cut his head open we decided to only open our windows to the first notch. Gives us plenty of air flow and no worries on head injuries.
LWinters is offline   Reply With Quote
Old 02-28-2019, 03:31 PM   #24
Mars , Pennsylvania
I punctured my head once and all the air leaked out.
RJake1 is offline   Reply With Quote
Old 02-28-2019, 04:43 PM   #25
2017 25' International
Framingham , Massachusetts
Another vote for pool noodles along the bottom of all open windows. Its a fast lesson otherwise.
quietguy is offline   Reply With Quote
Old 03-01-2019, 07:03 AM   #26
eagletoo - thanks for passing this along, just ordered the red tags and badge clips as I've had a couple of very close calls.
Old 03-01-2019, 08:14 AM   #27
Those "Remove Before Flight" tags are open to many interesting and humorous interpretations IMO.
Can't wait to get some. Thanks for the reminder, as they have been mentioned in many other threads through the years.
Peter
Old 03-01-2019, 08:15 AM   #28
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Rear bathroom window gets opened to first notch or 3rd notch (wide open), never the middle notch. Hubby has leaked too much blood on that middle notch! I may try pool noodles (pink of course)on that window this year!
Kay
Seven way cable sliced in half rk3326 General Repair Forum 30 06-29-2017 06:38 PM
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 03:47 PM
My Hitch Head Cracked Open mstephens Hitches, Couplers & Balls 11 03-08-2013 08:16 PM
? Idea for holding open rear window, '05 19' CCD Chilao Windows & Screens 5 08-19-2005 08:42 AM
safe to open window above wh? MariaRita Water Heaters, Filters & Pumps 3 08-16-2005 06:19 AM
