Old 07-31-2017, 01:40 PM   #1
2008 27' Classic FB
Green Cove Springs , Florida
Sleep Number
Hello there,
Has anyone ever tried to install or use a Sleep Number mattress in an Airstream?
tujeeze is offline   Reply With Quote
Old 07-31-2017, 02:10 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I have Sleep Number C2 extended twins in our Classic 30. We have Sleep Number P5 kings in two home bedrooms. We added 2" of foam on top of the C2s and they sleep as well as our P5s which we love.
They are about an inch too wide, so are slightly crushed at the nightstand and I had to cut plywood to support the edges of the bed between the nightstand and the foot. It narrows the floor area a few inches but the additional comfort over the matresses (upgraded by the previous owner) is worth the compromise.
The control units fit in the unused space between the rear of the underbed storage compartments and the back walls.
I'd do it again. If you are interested, they have a sale on right now but I didn't see the C2s on sale. When I bought mine they were $499 each, almost half off. Let me recommend you and we both get a discount.
I think you can buy the RV queen from them direct if that is what you need.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-31-2017, 02:18 PM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Yes, we have the RV Queen and love it. Made a huge difference for us, in addition to have two independent sides for adjustment.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-31-2017, 02:40 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We also installed a Sleep Number RV Queen Radius Corner model in our Airstream. Specially designed model for RV's, with the shorter RV queen length and radius lower corners to fit our Airstream platform nicely.
Can't beat it, each side adjustable with wireless remote control(s). The air pump runs on AC. Available at Camping World at a good price when on periodic sale.
Doug and Cheryl
Old 07-31-2017, 05:36 PM   #5
extiger's Avatar
2011 30' Classic
Kingwood , Texas
We also have a sleep number at home and in our AS. We purchased the short Queen with the radius corners. Controls on each side and plugged into 120 outlet. Not a big deal. Very comfortable. We also purchased at CW when on sale and registered it with Sleep Number.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
Old 08-01-2017, 12:09 PM   #6
2008 27' Classic FB
sleep number
I've got a Queen C-2 that I sleep on at home and was wondering how it would fit in an AS Queen hole...I guess its too much to ask to get my adjustable base in there too
Old 08-01-2017, 12:59 PM   #7
Try as I may I couldn't get the adjustable bases in the door.
You can check on line and find the dimensions of your RV queen and compare them with the dimensions of your Sleep Number Queen. The RV bed is probably several inches shorter and maybe narrower and have a curved corner, depending on trailer layout. Folks with east-west queens have extended the foot of their bed base to put a full queen in.
Al
S/OS #004
Old 08-01-2017, 01:33 PM   #8
1989 34.5' Airstream 345
Ebro , Fla Panhandle
I really like the east west queen sleep number in my Moho.
I've ended up using a softer setting than I'd thought I would. One of the advantages of the adjustability is being able to try it at different settings.
Another issue is the need to adjust the pressure with changes of altitude.
Need to let air out before going to higher elevation, or it will end up very hard or popped.
I have had to fire up my generator at times I wouldn't have wanted to, to get it pumped back up for the night.
Still very comfortable!
Cheers Richard
tevake is offline   Reply With Quote
Old 08-01-2017, 01:43 PM   #9
dkottum's Avatar
A couple of points.
The Sleep Number RV queen is the same size as the Airstream plywood queen platform.
I've heard the story about altitude changes and there may be some. We may have noticed a very little in ours traveling from sea level to 8,000 feet this spring. Have never reset it for altitude, but would use the Airstream's inverter for the pump if we did.
Doug and Cheryl
Just installed a Sleep Number bed! lsbrodsky General Interior Topics 7 07-03-2015 07:07 AM
Sleep Number Wiremanranch Interior Restoration Forum 11 12-08-2013 08:31 PM
Can I hookup my Sleep Number bed directly to the DC power bank? jasperkins Electrical - Systems, Generators, Batteries & Solar 6 10-04-2013 03:51 AM
1965 Airstream Overlander 26 foot Land Yacht RV w/ King Size Sleep Number Bed! eBay Watch Airstreams on eBay 0 09-13-2012 06:30 PM
Sleep Number Bed? millvalleyca General Interior Topics 9 06-12-2008 06:37 PM
