10-16-2016, 08:04 PM
2017 30' International
Broomfield
I was at timeless travel trailers in Denver last week. They had a brand new blank 34 shell in the shop that they were custom building for a client.
They told me that airstream will, when asked, produce a 34' shell for them to customize. The axels are more forward than the panamera to reduce tongue weight / frame stress (there were issues with frame cracking on the panameras..) there was no rear hatch...
In any case just wanted to mention that airstream do have the ability to produce the 34' shell... until they are mainstream again you could certainly drop $2-300k on a custom one with timeless
10-16-2016, 09:48 PM
Dayton
, OH, 2017 33' Classic 8,561 dry
Like Toutsi I like the room without the mandatory lux & price. The reason I ask is a buddy did the tour the other week & they had a triple axle & frame in there. He asked the tour guide about it and the guide smiled & said I'm not allowed to talk about that yet.
On another note a 34' bumper pull would have to be a bit of a pain to maneuver. Certainly their are some fuel stations etc you would not pull into. Shoot the 30'11" can already force you around the block to avoid making a right at an intersection etc. I'm sure you would have to watch tail swing. Also was thinking a power everything lux Classic might weigh close to 9,000 dry. Guessing 1,200 pound TW dry? But I presume the triples would be resistant to sway.
Transportr AS & TT Mfg 2 dealr RAM ED factory brake controller tow mirror hitch camera & receiver 1,290/12k, No sway WDH, Adj. hitch, axle 2 frame air bags, tune w turbo brake, SLT Grill, 31.9" load tires, Max ED tow 9,200, GCAR 7,800, Max Ram 1500 GCVW 15,950, truck hitches steer 3,240 drive 2,560
10-17-2016, 07:45 PM
1988 34' Limited
Brunswick
, Georgia
We have a 1961 Overlander 26' and just bought a 1988 Limited 34'. It's definitely different trying to maneuver thru a campground or gas station but we love it. The extra room is nice plus ours is the model that does not have a dinette, instead we have a full size bath tub. Plus I like the fact that it looks like a train car compared to the other one.
10-17-2016, 08:11 PM
2016 28' International
Albuquerque
, New Mexico
If they would produce a 34' model with significantly larger fresh water, black and gray tanks, and an optional stacked washer and dryer, I would be ecstatic.
10-17-2016, 10:03 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
How about bringing back the Pan America? Not as a toy hauler, but make the rear area a nice "living room" space.
10-21-2016, 05:37 PM
1998 36' Land Yacht Widebody
Ft. Lauderdale
I was looking for a 34' six wheel AS when I found my 36' AS diesel pusher with washer/dryer, auto levelers, that was a time capsule from 1997. Perfect shape that even came with the deposit slip from 1997 when the owner moved $80k into an account to pay the deposit
No slideouts but have not missed them yet!!
10-22-2016, 08:40 PM
#21
Vintage Kin
Fort Worth
The 34' tridem were set with low tongue weight so that a car could pull them. 700-900 lbs back in 1980s, IIRC. Once the wide body came out, the TW may be higher gross and percentage. But they tow beautifully. Easier than any tandem.
The "swing" (pivot) on my 35' tandem axle Silver Streak is greater than the 34'. Even with the longer tongue cause by using a Hensley it's still not hard.
But watch out for dogleg backing.
It really comes down to the TV. A Chrysler 300 will have an easy time with its 121" wheelbase. It's the 172" Ford truck drivers that forever look like tenderfeet.
1990 35' Silver Streak
2004 555 Cummins
Hensley Arrow. 9-cpm solo, 15-cpm towing
10-22-2016, 09:45 PM
#22
2012 25' Flying Cloud
Battle Lake
We would like it while in camp, not so much at the fuel station. However as Slowmover says, maneuverability is more about tow vehicle wheelbase than trailer length.
Our last truck was 120", this one 140". The short truck was better for backing the same Airstream into a tight spot. Going down the road using a Hensley style hitch, no noticeable difference in stability.
Doug and Cheryl
10-23-2016, 10:17 AM
#23
Dayton
Thats a good point it is more about TV length for maneuverability. Yard dog drivers always make OTR trucks look silly putting trailers in dock slots. Doug you must have the shorter bed because I have the same wheelbase with the QC.
With a WDH Rams receiver is rated to a TW of 1,290. I would not want to exceed that but from what your saying Ross I would likely be good on a new dry trailer. No propane no water. I would check first.
From the stats I found on the old ones dry most grossed under 8,200. Figure the wide bodys might be 8,500? Part of me hopes they at least do a run of them again. I do like the train car looks as Cristobal put it. BTW your 34 looks fantastic. I'd sport that and enjoy it.
10-24-2016, 12:19 PM
#24
Vintage Kin
Fort Worth
Have a look at the thread by 2Airishuman from a dozen years ago.
"Visited Cat Scale - the numbers are in" (roughly).
He ran hard miles with a 2005 34'. (30,000+ in no time). You can see how the scale numbers worked for him. He learned as he went.
(And as reference, you can research any topic on which he comments and use his opinion as a baseline. Agree or disagree, in the end, he understood the subjects back and forth. Someone I someday hope to meet).
2004 555 Cummins
10-26-2016, 09:06 AM
#25
Dayton
Ross I found the thread. A good read so far. Only got through the first two pages, have to finish the rest after I get back. I've weighed a couple different loads/outfits but never kept numbers because it wasn't my trailer & or stuff. Also my situation is a constant steam of trailers so. I generally have the actual trailer weight can look up the TW & know my truck weight etc. All trailers are dry so you generally have enough info / experience with it to know if its going to be in the range where is will tow well.
10-26-2016, 10:14 AM
#26
2014 28' International
Blacksburg
, Virginia
yeah
Originally Posted by kamadeca
I second FCStreamer's comment. It is the only Airstream I would trade my 30' International for. That being said, I wouldn't want a Classic. If they ever made a 34' Serenity I would buy # 1.
 34' Serenity , yeah I could go for that !
No slide,
Stackable washer/dryer ? Intriguing.
I'd like a 'fireproof safe' strong box option. ( I'd like to put one in my 28') I keep thinking about it.
Oh yeah, 'no slide' .
safe travels !
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
10-31-2016, 11:26 PM
#27
2009 34' Panamerica
2008 22' Safari
Metro Detroit Area & Metro Dallas Area
, Michigan & Texas
My experience with the Panamerica M-34 was most enjoyable. Towed using a 2010 Tundra CrewMax 5.7L short bed (4x2). WD hitch w/1400# flat bars & dual friction sway controls made for a solid ride. CanAm RV did a great job guiding the setup. Towing wasn't too challenging; however, you did need to plan ahead where your travels would take you. Fuel stops needed to be at the same places the big rigs went - or at night - in city stations. You get used to it pretty fast. On the interior, the only drawback was the position of the queen bed, as there wasn't much space around the bed. The flexibility of the aft area allowed for another sleep area or adult playthings from cycles to kayaks. I used it as a retreat space. Currently looking for a second 34' model. Since only18 PAs were manufactured, they show up infrequently. One is in "The Accountant" (2016), staring Ben Affleck.
