Old 03-04-2015, 02:14 PM   #1
Air Apparent's Avatar
Northern Illinois , Illinois
Queen Bed
I have a rear bedroom with a queen bed in a classic 34. The mattress is a short queen that is 60" by 75". I'm thinking of replacing the mattress with at regular queen (60" by 80"). Has anyone done this? Do you have enough room to walk around the bed or does the mattress come out too far?
Do you need to replace the plywood platform or could you use a bunkee board?
Thanks for the help.
Dave
2008 Classic 34
Dodge Ram 2500 Quad Cab CTD
AIR #7317 WBCCI #1772 TAC-IL 1
Air Apparent is offline   Reply With Quote
Old 03-04-2015, 02:26 PM   #2
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Have not done it, but measured and in our 30' FC it would make a tight situation even tighter to the point of not being worth it. The bedroom is pretty tight as it is.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-04-2015, 04:31 PM   #3
terryV's Avatar
2002 31' Classic
Monroe , Iowa
I'm thinking those few inches would be a little too much in our 31'. Also it would make it more dificult to reach the drawers underneath.
You would probably have to re-engineer the struts that hold the bed in the up position, too, as the addition length may be too much weight.
terryV is offline   Reply With Quote
Old 03-04-2015, 04:36 PM   #4
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
I have a full size queen in my '74 Sov. Set up east/west. There is no walking around it. Not even close. I tried setting it up north south to get more room on the sides, but then it touches wall to wall front to back. I built my own frame, because the bed (as well as the floor of the bedroom) was missing when I got her.
I'll try to get a picture of it for you, if you'd like.
-Red, sleeping like a king on a queen (sized bed that is)...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 03-04-2015, 05:14 PM   #5
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I don't know about the space you have, but in our 25' FB, I extended the OEM mattress—I screwed a 1/4" plywood board across the bottom thus extended the mattress stupport, no extra support needed. There's not much weight at the end of the bed.
I moved the mattress down and filled the space at the top with a bolster my wife made. This is the part under the top of the pillows and there's not much weight there either. Now you can use standard queen sheets. I cut a piece of 1/4" plywood and stuffed it into the bottom of the bolster so there would be something hard to fit the sheets around.
This way we added around 4" and our feet are now on, not extended over the end of the bed. We also put a standard queen foam pad on top because the OEM bed was uncomfortable. There isn't much room between the end of the bed and the wall, but we spend a lot more time in bed than we do trying to walk around the end.
Gene
Gene
Old 03-04-2015, 08:55 PM   #6
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Queen Bed
Threw away the short queen junk mattress and installed Tempurpedic regular queen
Still have walk around room in our 28ft international.This is one of the best upgrades that we have made.
Old 03-05-2015, 03:35 AM   #7
Panama Red's Avatar
Obrien , Florida
Was going to post these last night, but the site locked up on me...
Here's how the queen fit in mine... If the 34 ha me room from the back wall to the bathroom wall, I'd turn it north/south, and not have to climb over the DW to get out of bed in the middle of the night.
Name:	ImageUploadedByAirstream Forums1425551586.403863.jpg
ID:	233639Click image for larger version
Name:	ImageUploadedByAirstream Forums1425551605.709123.jpg
ID:	233640Click image for larger version
Name:	ImageUploadedByAirstream Forums1425551638.944365.jpg
Hope this helps.
-Red...
Old 03-05-2015, 03:36 AM   #8
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
I put a regular queen in my '99 34'. I still squeeze around by side/slide stepping. It was a good choice.
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 03-05-2015, 09:05 AM   #9
Thanks for the replies.
Our trailer will be out of winter storage in four weeks. I will then measure to see how much room I will have to maneuver to get to the side of the bed.
It would be nice to have a regular queen.
Dave
2008 Classic 34
Old 03-05-2015, 09:08 AM   #10
Thanks Red for the pictures.
Dave
2008 Classic 34
Int'l 27-twin bed vs queen; convert to queen Soul Food II General Interior Topics 1 03-20-2013 10:07 PM
Rear Queen Bed Platform/under bed storage AluminumGirl Cabinets, Counter Tops & Furnishings 0 04-18-2010 11:57 PM
Queen size bed somefun General Interior Topics 3 06-17-2004 09:38 AM
Convert Rear Queen to Couch/Bed? fangthorpe Airstream Motorhome Forums 0 10-13-2003 08:25 PM
