Old 03-01-2015, 07:22 AM   #1
Airborne6's Avatar
2015 23' International
Lakeview , Arkansas
Newbie questions
Trying to prep for travel. AS on order.
1. Is there a 5 gal water can out there that is conducive to topping off fresh water tank periodically that has the hose end adapter?? I'm thinking the only fill point is the hose hookup. (Water hook-up is not available)
2. When pulling/traveling is the refrigerator cooling via LP?
3. Any thoughts on the rear cameras for the AS. Brand?
4. When solely running off batteries, basically one can only expect to use a light or two and the TV/radio? At this point is the fridge on battery power or LP.
Just trying to get as knowledgeable as possible before AS arrives and retirement begins. Sure I'll most likely have more questions in the future.
Dave
Some days your the bug.
Some days your the windshield.
WBCCI # 1959
Black 2015 Toyota Tundra TRD Pro CrewMax
2015 23D International Signature (Salsa)
Stella our Bull Pointer mix
Airborne6 is offline   Reply With Quote
Old 03-01-2015, 07:28 AM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Dave
1. Short answer is no, but many choose to buy an inexpensive 12 volt water pump (Harbor Freight has) and transfer water from a large container.
2. Technically, many states prohibit this practice. Realistically, most use LP to cool in transit.
3. Using the search function on this forum, you'll find many discussions on this subject.
4. In boon docking mode, the fridge uses LP.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 03-01-2015, 08:00 AM   #3
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Keep in mind that to be self contained, in boon docking mode, the main power system will be 12v. Only the outlets, AC, microwave are 110v. You must be plugged in to shore power or use a generator for them to function.
Lights, water pump, furnace fan, all 12v. Frig runs on propane but also needs 12v to operate it's control board. An inverter would let you watch TV. Some of the new trailers may have a built in inverter.
How long the batts last depends on how much 12v you use. Lights are minimal, furnace fan uses lots.
John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 03-01-2015, 08:16 AM   #4
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I have a 6gal plastic container with a nozzle that works fine to replenish our water tank. They are available just about anywhere. We use propane to run the refer when traveling. Our GR29 battery can go 3-5 days when boondocking but we have purchased a Honda genny to recharge it or run the micro.
Ahab is offline   Reply With Quote
Old 03-01-2015, 10:52 AM   #5
Airborne6's Avatar
Lakeview , Arkansas
Appreciate the responses. Honda generator on the short list now. Still learning to navigate this forum. Will investigate the search option. Is there just the one fresh tank fill port (I imagine).
Dave
WBCCI # 1959
Old 03-01-2015, 12:05 PM   #6
Archie
archiedh's Avatar
2014 30' Flying Cloud
Ridgeland , Mississippi
John, I would like to speak with you about ordering a 5-hole flag holder from you when you have time. I sent you an email with my phone number. Thanks, Archie.
archiedh is offline   Reply With Quote
Mexican Insurance Questions, Questions! CaddyGrn Travel Beyond US/Canada 5 01-31-2014 11:23 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
Airstream/Argosy Floorplans? Questions from a newbie ErichC Airstream Motorhome Forums 12 07-07-2002 10:29 PM
General Engine questions from a newbie ErichC Mechanics Corner - Engines, Transmission & More... 1 07-07-2002 05:23 PM
