Old 09-29-2013, 06:59 PM   #1
Marion , Ohio
Question New Owner Questions
Our 25' International arrives Tuesday. and 'whoa' do we have questions..seemingly this forum has some experience AS folks. Here goes:
Last week poured concrete at our home so it has a permanent 'home' place.
I need two things answered please...
1) since it will be stored here at our home over winter, should we put the two axles on jack stands for tire's sake?
2) Concerned about 'theft' - it hasn't happened near where we live but I don't want the idea to cross anyone's mind. Is there any advice on how to keep your AS safe from theft?
One more:
We are within 60' of our home where we have WiFi..how do I 'stretch' my home WiFi signal to get to the motor home?
Kirt is offline   Reply With Quote
Old 09-29-2013, 08:03 PM   #2
Eburg , Washington
Hi Kirt,
I am not sure where home is, but if you are keeping your airstream on a concrete pad, do NOT leave the tires in direct contact with the concrete. Concrete does unpleasant things to rubber. If you are going to leave it like that, park the tires on small pieces of plywood on the concrete.
summerp is offline   Reply With Quote
Old 09-29-2013, 08:06 PM   #3
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Don't put jack stands under the axles! If you want to raise the tires off the concrete, put the jack stands under the frame at the axle mounting plates.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 09-29-2013, 08:27 PM   #4
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
#1 ditto on the plywood
#2 hitch lock, parking boot, Rhino Wheel Boot Immobilizer and Tire Lock, 12 inch Wheel Cover, RHINOWHEELBOOTH12, Orange Traffic Cones or BAC that threads from wheel to wheel with a good padlock
#3 there are boosters available, go to Best Buy and talk to a Geek
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 09-29-2013, 08:39 PM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I'll jump in on the Wi-Fi question. Typically most Wi-Fi routers will have a range of almost 300 feet. Now that is in a situation where you have nothing to block the signal. Walls, and location of your Wi-Fi router will affect the distance that your Wi-Fi will travel. For example my router is on the extreme side of the house. I've been to my neighbor's house on that side and can pick up my Wi-Fi perfectly anywhere within his house.
So one thing you can consider is the location of your home wireless router and possibly adjust that. The other thing you can consider is adding a second router in a location in the house that is closer to your trailer. For example I have an Apple Airport Express wireless router than can run in pass through or bridge mode. Your current wireless router can wirelessly connect to the Express in another area of your home which in turn allows the Express to operate and pass the connectivity wirelessly to your devices in the trailer. You might even be able to put that router in your trailer and its antenna may be better equipped to pick up your wireless router inside the house. Again you run that router in a pass through or bridge mode.
There are other possibilities in upgrading the antenna(s) on your home wireless router that will provide more signal strength.
I can tell you that my driveway is a good 60' from the spot where I park my Airstream when it's home. My main wireless router is an Apple Airport Extreme and I can easily connect from within the Airstream.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-29-2013, 10:05 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sitting by a window in your AS near the wifi source also helps signal strength.
Depending on your "need" to be connected there are other "options" like external antennas.
Lifting your AS is not extremely complex... Unless you have no experience safely lifting vehicles. There are NO shortcuts to safety. You CAN hurt or kill if done wrong. Anything you do, understand well before trying... Please!
Seeing it done properly will help.. But, safety is all on you...
So, if "storing" and not using for months at a time, and your capability, will influence what steps you take. Some steps are "absolute.
For instance...
- PrOperly stabilize,
- NEVER, ever "jack" on an AS axle. You will damage them, permanently.
- Cost $2000 or more to replace.
- When you "jack" the AS, do so at the steel plates or the "jack" locating locations specified in your "owners manual"... It will give specific locations.
- Usually one jack location aft of rear wheels and the "tongue jack" for the bow. You then lower the "stabilizers" to secure. Add wood blocks or stepping stones to minimize distance to extend.
I lift mine and use 6 jack stands rated for 3-4 tons each (our "baby" weighs in over 8k dry, nearly 10k loaaaaaded. So, spreading the load is important. It also helps increase stability. Not something I worry about...but do not want one failing jack stand (never happened yet) to mess things up.
I use a 10 ton bottle jack to lift one side high enough to place jack stands. Then repeat on other side.
You can "lift" one wheel off ground by rolling up on a wood ramp. This keeps things stable enough to change the tire off the ground. There are Youtubes on most of this...
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-30-2013, 03:59 AM   #7
Marion , Ohio
Awesome advice. I didn't know that but am going to cut some marine based plywood today - we're in Ohio where weather changes are famous from day to day
Old 09-30-2013, 04:02 AM   #8
Marion , Ohio
Just looked at this, this is the kind of thing I was looking to do. Something that would be very discouraging to a thief. Big thanks
Old 09-30-2013, 04:03 AM   #9
Marion , Ohio
I travel a great deal throughout the world and use my Airport Express extensively - love that product. I will try to make this work at home. Thanks for the advice and yep..Best Buy's Geek's are not far away
Old 09-30-2013, 05:40 AM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Actually, that's not as true as it used to be back when tires were made exclusively of natural rubber. Here is what Bridgestone Tires has to say on the subject (and they ought to know):
Concrete is not the tire enemy some people think it is.
We would recommend the following steps in storing a vehicle:
1. Make sure the floor / ground surface is free of any petroleum product contamination (Oil, grease, fuel, etc.) since petroleum products will attack rubber and can cause significant damage to compound characteristics.
2. Thoroughly clean your tires with soap and water.
3. Place a barrier such as plastic, cardboard, or plywood between the tires and the ground surface.
4. Cover your tires to block out direct sunlight and ultra violet rays.
5. Do not store the vehicle in close proximity to steam pipes, electrical generators or animal manure since these accelerate oxidation of the rubber.
6. Make sure your tires are fully inflated with air.
7. When the vehicle is ready to go back into service, inspect the tires for excessive cracking in both the sidewall and tread area and check all tire air pressures. Tires will normally lose about 2 PSI per month so you should expect to find the pressures lower than when you put the vehicle into storage. Re-inflate the tires to the correct air pressure before operation.
That bit about petroleum products means that storing tires on concrete is FAR better than storing on asphalt, which uses petroleum products in the binder.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-30-2013, 08:22 AM   #11
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
tirea and concrete
Kinda contradicts themselves because they say concrete is not the enemy but then they tell you to put plastic or cardboard or something between tires and ground surface
panheaddale is offline   Reply With Quote
Old 09-30-2013, 09:40 AM   #12
Ground, they say, not necessarily concrete.
WBCCI #1105
TAC LA-4
Old 12-21-2013, 06:14 PM   #13
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
What about a "California Immobilizer" coupler lock?
Just saw this today as I was looking for something to help make it a little harder to hitch up to my new Airstream and take in an unauthorized adventure. Does anybody have experience with this device? Airstream Trailer Coupler Locks - California Immobilizer
Old 12-22-2013, 07:46 AM   #14
1972 Travelux Princess 25
Cobourg , Ontario
Highly recommended to jack up your trailer when storing for long periods, like a month or more.
Letting the suspension hang prevents the rubber suspension from collapsing. It also saves the tires from getting flat spots.
In extreme cases, if you have a slow leak and a tire goes flat it can be permanently weakened. This may not show if someone pumps it up, until the tire blows out on the hiway.
So yes, jack it up if you can. The main support should be next to the axles with support front and rear for stability.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
