Old 05-01-2013, 03:43 PM   #15
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
How about a cam and lock positioner on axle assy.? Turn a long screw (like bal jacks), it unlocks the axle assy. Back the trailer against wheel chocks, axle rotates in eliptical cam, and presto! instant 6 inches of addl. temporary clearance.
Phrunes is offline   Reply With Quote
Old 05-04-2013, 09:56 PM   #16
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Laminated fiberglass panels for floor instead of plywood.
Pull out ramp for handicap access (like Uhaul trucks have. )
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-04-2013, 10:34 PM   #17
Maniacal Engineer
barts's Avatar
Menlo Park , California
I'd prefer hybrid torsion/air suspension like is used on some high end horse trailers.... this would make trailer height quite adjustable, and with differential inflation side to side would allow trailer to self level in most cases. The frame section should taper to the rear if practical to offer additional ground clearance.
Wheel wells should be of 1/8" 6061 aluminum, fastened to the frame.
Hydraulic disc brakes of course.
I'd like that 6" boxed frame to include a full perimeter support for the floor.
I'd like to see the belly pan fastened in smaller sections.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 05-04-2013, 10:38 PM   #18
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Laminated Fiberglas panel flooring. Can imbed heat strips for chilly morns
Pull out ramp at door for handicap access.
Wiring raceway with installed "pull strings"
Access panels for service of tank sensors
Slots under frame into which you can slide and secure underbelly panels. (More accessible to components. )
Hydraulic leveling jacks could push down the plate where axles are attached.
Tire pressure monitors wireless to TV
Built in air lines with quick disconnects secured in recessed panels near wheel well openings.
Hot and cold external water sources.
Channing
WBCCI# 30676
Old 05-04-2013, 10:50 PM   #19
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, hydraulic disc brakes, only if they can be controlled with a vacuum booster, run by a vacuum pump, with a vacuum storage tank, and with ABS. Todays little electric motor driven pumps are a joke with many failures.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-05-2013, 05:54 AM   #20
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
How about a discussion on what size this virtual airstream is going to be... That's a lot of "stuff' for a Bambi ;.) 1 axle /2/3/4? Weight an issue? This is already turned into a 10,000 lb elephant and we haven't even gotten to the pair of 200 gal fresh water tanks yet. I think we need to agree on what the final size will be before we can 'build' it.
goshawks00 is offline   Reply With Quote
Old 05-05-2013, 06:56 AM   #21
Baltimore , Maryland
This one is so easy,
I would send a 1962 Overlander to China and have them copy it rivet for rivet...
Old 05-05-2013, 07:30 AM   #22
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Ooooohhhh! Good catch on the size.
My vote is 26 footer.
Old 05-05-2013, 10:19 AM   #23
Maniacal Engineer
barts's Avatar
ABS would be nice. I've not had any problems w/ the Carlisle actuator I put in our trailer, but that's been only three years. Either a vacuum or air pressure based booster would be a better design, but right now those don't seem to be available for trailers. I could see converting a regular car brake booster with a vacuum pump; the linear motor needed to drive the brake booster might be a bit of a project. A compressed air system would be smaller.
- Bart
Bart Smaalders
Menlo Park, CA
Old 05-05-2013, 10:34 AM   #24
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
How about weight? I love the fiberglass floor idea, or maybe aluminum honeycomb/carbon fiber sheets, something that won't rot. High strength galvanized steel frame, or a boxed aluminum frame with a perimeter channel so the shell attaches to the frame more and not the flooring. Underfloor tanks for waster and water
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 05-08-2013, 08:28 PM   #25
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
3 axle 34' trailer...
Old 05-08-2013, 09:16 PM   #26
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Here's an idea...boxed frame as Bob suggeated, but channels integrated into inside perimeter of frame allowing "floating subfloor" to slide in from rear. Anchored from bottom with springloaded pins. Body frame connected to points on outside perimeter of said frame with location brackets to aide in construction at factory.
Old 05-09-2013, 03:22 AM   #27
m.hony's Avatar
2013 30' Classic
I thought I had posted this before, but I don't see it...3 axle 34' trailer.
Old 05-09-2013, 03:23 AM   #28
m.hony's Avatar
2013 30' Classic
Oh...there it is....twice....
