Old 06-30-2012, 03:52 PM   #1
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley , Georgia
Need some help
HI, just purchased a 23' Flying Cloud. So far we love it. I am trying to get a generator that will run the appliances and the ac unit. Does anyone have a guess at what the minimum size would be required? I have a 4000 watt generator but it struggles with the ac. I think the power cord being 30 ft. long is affecting it. Any help would be greatly appreciated.
Mike S. is offline   Reply With Quote
Old 06-30-2012, 04:01 PM   #2
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
4000 should be plenty. The ac only pulls around 2000. The rest should be marginal.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 06-30-2012, 04:21 PM   #3
The generator I have will run the ac for about a minute before the circuit breaks. Nothing else is on. I should be more specific, it is 3500 continuous and 4400 surge watt capacity. I wonder what the drop is for a 30 ft. cord. Should still be enough. Thanks for the reply.
Old 06-30-2012, 04:31 PM   #4
Naper's Avatar
Loretto , Ontario
You should be fine. What is the gauge of your 30' cord? What type / brand is your generator? Have you checked the output?
Naper is offline   Reply With Quote
Old 06-30-2012, 05:01 PM   #5
1988 32' Excella
Robbinsville , New Jersey
Many people use the 2800 watt continuous Hondas and Yamahas with 13,500 BTU AC no problems.
Do you have a 13,500 BTU or a 15,000 BTU AC?
Old 06-30-2012, 05:52 PM   #6
We have the 13,500 ac unit. The cord is fairly large, don't know the specific guages of the wire inside of it. It's the cord that came with the trailer. The generator is Duro Max. Trying the cheap one before I have to spend more money on the Honda.
Old 06-30-2012, 06:08 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Welcome to the Forums, Mike...
You have more than enough wattage to run your AC unless there is an issue with the generator, the cord, or the breakers. If you got the cord with the AS it should be fine for 30 feet carrying 30 amps.
We run our 13, 500 BTU AC running two Honda 2000w genrators in parallel.
There is something else going on in your situation.
Hint: your camping neighbors will be more friendly if you have a quiet generator.
TB & Greg and Abbey Schnauzer
#3954
Old 06-30-2012, 06:47 PM   #8
Thanks for the replies. It's cooling off a little (97) at 8:30, so I tried to do more troubleshooting. I measured the voltage at an outlet with the generator running. Constant 136 volts. Turned the fan on, constant 136 volts. When the compressor came on, 134 volts. Breaker kicked in @ 45 seconds. Not sure how to measure amps. Felt good for a short while. The trailer is at my house, wife won't go until everything is working well. The generator is really not loud, I have had hondas in the past, maybe just a tad louder. Not bad though. Everything worked fine at the rv store where purchased, on shore power, so I think the generator is the problem.
Old 06-30-2012, 07:52 PM   #9
richinny's Avatar
2011 34' Classic
you're a short ride to an Airstream campground. why not take a ride over to check them out and see if the ac runs ok?
Top of Georgia Airstream Park
Ricky
Old 06-30-2012, 07:54 PM   #10
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
We have 2 Honda 2000 gens hooked up in parrallel, and they power our 2010 FC23FB just fine, but the wife always shuts the AC off prior to running the microwave just as a matter of good engineering principles due to starting surges. We use the factory supplied power cord.
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 06-30-2012, 10:08 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It is probably the inrush current when the compressor on the AC starts that is tripping the breaker on the generator. What is the current rating of the breaker on the generator?
If it is 15 amp, it's too small. It could also just be a bad breaker.
Old 06-30-2012, 10:48 PM   #12
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I think a better generator will hold right at 120 volts, your's might be too high. My Yamaha 2400 will run my 11,000 BTU air conditioner, my inverter, and my refrigerator all at once and has done it at high altitude.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-01-2012, 07:06 AM   #13
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Try to return the generator and get a Honda or Yamaha, better money spent and less grief for you and your neighbors who have to listen to it.
doug k
Old 07-01-2012, 08:19 AM   #14
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I had a cheap harbor freight mig welder ONCE! It would weld about a 9" line and trip the over heat breaker. Two of them did this. I took the second one back and then went and bought a Hobart mig welder. Never a problem. Sometimes it pays to get the right one in the beginning. Saves you money and time.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
