Old 11-13-2019, 07:42 PM   #41
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Following "Less junk more journey" I saw that they had bought a small ceramic heater for the rear of their Airstream. My classic is always 4 degrees colder in the back. This thing fits great between the twin beds on the face of the center cabinet and provides 350 watts of heat. It's a ceramic heater that is thermostatically controlled and also has a timer.
It is perfect for balancing the heat in the back, uses very little electricity, and looks very safe. It is also very quiet! Get one!!!!
https://www.walmart.com/ip/Soleil-Ce...?selected=true
x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
turk123 is offline   Reply With Quote
Old 11-13-2019, 10:35 PM   #42
Mollysdad's Avatar
Originally Posted by Kaydub View Post
I also use a 90° connector at the water inlet that I leave on the trailer to reduce hose strain.
Me too.
I love this product. It's a slightly less than 90 deg connection, and a quick connect. Never leaks a drop. I just leave it on the inlet.
The problem is the seller goes to all the RV shows and so ordering online means you'll wait until you think you've been ripped off.
I want to try a quick connect at both ends of the hose now. I'll screw a "Y" on the supply faucet, then snap the hose/filter on that.
Old 11-14-2019, 02:35 AM   #43
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, several years ago a co-worker and I were looking at RV accessories on line. We found this really neat smoke detector. It had two buttons on it. One button was the normal test button and the other one was called a HUSH button. When pushed, the HUSH button would stop the alarm that was set off by cooking. Or, you could push the HUSH button before hand and the alarm would only chirp for several minutes allowing you to cook without getting your ears blasted. We both decided that this was a must for his motorhome and my trailer, so we ordered one each.
Several months later when I was able to get inside of my trailer and get it ready for another random trip, I was going to install this fantastic find; Only to find out that my trailer came with this exact same smoke alarm from the factory.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-14-2019, 06:18 AM   #44
Dave-n-Janet's Avatar
Moss Point , Mississippi
We use same heater in our 26RBT (integrated bath/shower). Works great!
Dave-n-Janet is offline   Reply With Quote
Old 11-14-2019, 07:22 PM   #45
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Here is a good one.
Everyone here uses Silkaflex or equivalent sealant. You buy a $12 tube, use a little dab to fix a small crack somewhere, and then try to seal up the tube so it won't dry out. It drys out.
When I need just a small amount, instead of opening the tube and cutting the end, I get a sharp nail and poke a hole in the cardboard tube. I can squeeze out what I need and just let it seal itself up. Next time I need another dab, just poke another hole. Better than wasting the whole tube for one job and it lasts a long time.
Name:	Sikaflex-221_Polyurethane_Adhesive_Sealant_10_1_fl__oz__Cartridge__Black__Amazon_com__Industrial.jpg
Old 11-18-2019, 09:05 AM   #46
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Relax Awning.
I just discovered, that if you put the Relax Zip-dee awning all the way out, then bring it in to say, 5 feet showing, it is very stable in the wind. We are on a beach right now in Texas and it is windy all the time. 10-12 mph is common and normally I would not put the awning out in this, but with just 5-6 feet out, it works quite well!
The important thing is to get it out all the way as the arms allow the awning to drop down. When you bring it back in, the awning stays down. It is very stable in its shortened form and still provides shade.
Old 11-18-2019, 09:49 AM   #47
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Turk - I believe that’s the Caravan mode described in the user manual. Kudos on the discovery!
Old 11-28-2019, 04:35 AM   #48
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
Nightlight – Lighted toilet seats by Kohler
Soft closing residential seat with nightlight. Home depot.
https://www.us.kohler.com/us/Nightli...T120400001.htm
Laurence
LAWBC is offline   Reply With Quote
Old 11-28-2019, 06:26 AM   #49
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Motion activated, rechargeable LED light pucks, for the odd cabinet or two that does not have good lighting. I use them in my FC26 food cabinets.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 11-28-2019, 07:34 AM   #50
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Lots of great ideas here! Following............
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 11-28-2019, 06:25 PM   #51
turk123's Avatar
2019 30' Classic
Canfield , Ohio
We were closing up the trailer getting ready to move tomorrow up to SanAntonia tx when I realized an issue I've had when putting down the front "protector" plexiglass. Oh, it drops ok and that is easy enough, but those rubber "T" handled stretch locks you have to pull on to get that little ball part of the handle to lock in is always difficult. I broke one on my first trailer and had to have airstream replace.
I just discovered an easier way. hook two fingers around that lower "lobe" that sticks out and grab the "T" with your other hand. Pull up with both hands and the rubber band stretches very easily and you can put the ball in the socket with ease.
I've struggled with that for two years! It took me this long to figure it out.
Name:	rubber handle.jpg
Old 01-03-2020, 11:32 AM   #52
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Thiel post this elsewhere so I thought I would bring it here. Great tip!
I keep finding that folks don't know about these little doodads that domestic includes with the refrigerator to help with storage, so I did a 90-second video on the topic. Enjoy!
https://youtu.be/h5zrGLLNFBo
Old 01-04-2020, 06:54 AM   #53
2019 25' International
Washington , Washington, D.C.
turk123 - I have always wondered how to use the 'door ajar thingamajig' - brilliant!! Beats the heck out of sticking my ice tray perpendicularly in the doors. Thanks!
PatLee is offline   Reply With Quote
Old 01-04-2020, 05:21 PM   #54
rfisher's Avatar
2020 27' Globetrotter
Newark , Delaware
Angry What Trick or Tip Do You Have?
I hate the privacy curtains - We just bought a 27ft Globetrotter. My husband and I pick her up the first week of March, and we could not be more excited! We are going full-time, and I love everything about my new home - except those darn interior privacy curtains.
The plain curtains that hang at the "kitchen" and at the "bedroom" to give you "privacy" if you are taking a shower or whatnot. I am the only person in the Airstream world who hates those curtains! I'm not a fan of accordion doors either, but I would even have preferred that instead of those stupid curtains.
I've complained to Airstream about this, but this is the design - for now. All thoughts welcome. I'm new to this forum, but if you have any tips/tricks to replace the curtains, please let me know.
In advance - Thanks. RRF
rfisher is offline   Reply With Quote
Old 01-04-2020, 07:01 PM   #55
2018 30' Classic
Williamsburg , VA
My wife and I are big fans of bidets so I added one to the Airstream toilet, as well as the houses. Real cheap on amazon, easy install other than connecting RV plumbing sizes to house sizes. Works great, use less toilet paper, and we really prefer it for many reasons. We always camp with full hook ups so maybe not a good idea for dry campers. We use Piranha black water tank cleaner and it requires a good amount of water. This helps us make sure we use more water, so that is a plus.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 01-04-2020, 07:06 PM   #56
2007 22' International CCD
A few more details of the bidet or a link to Amazon would be real nice.
rmkrum is online now   Reply With Quote
Old 01-04-2020, 07:25 PM   #57
2018 30' Classic
Williamsburg , VA
I always use this brand: Luxe Bidet Neo 120 - Self Cleaning Nozzle - Fresh Water Non-Electric Mechanical Bidet Toilet Attachment (blue and white) https://www.amazon.com/dp/B00A0RHSJO..._CQteEb1FZ340X
I have used different models of that brand though as some you attach hot water to in that is real nice however can be a pain to run the line for. Also got this for my grandma after her surgery on her foot and she really likes it.
2018 Classic 30
2012 F250 6.7l
Old 01-04-2020, 07:56 PM   #58
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Hi rfisher, welcome to the Airstream Community and Forums!
We also have a 27’ Globetrotter and spent two weeks on the road last August. It’s just The dear wife and me and we didn’t have any trouble with the curtains. They’re functional and easy to store. She never complained about a lack of privacy. I think Airstream went with the cloth to match the overall theme (matches the window curtains and Euro look).
What is it about them you dislike?
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1500#
WBCCI# 10258
April 3, 2020 Retirement Plan
jeffmc306 is offline   Reply With Quote
Old 01-04-2020, 08:17 PM   #59
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I am puzzled also? What is wrong with the curtains? We close off the bedroom and bathroom and it makes a large area that you can shower and get dressed. The windows in front can be left open.
They are very functional and they last a very long time. The little strap that snaps the doors shut I hear will last several centuries and may even survive the end of the world. That is a very long time, I hope.
Old 01-04-2020, 08:21 PM   #60
2018 27' Globetrotter
Japser , Georgia
I bought an inexpensive grill cover at Walmart and use it to cover my hitch and tanks when it’s in storage.
Gary Collier
2019 Globetrotter
2018 F250 Lariat
Jasper, GA (North of Atlanta)
garypilot55 is offline   Reply With Quote
Rear airbags on '87 345 - any tips or tricks moeriv Classic Motorhomes 11 06-25-2019 08:13 AM
Foil insulation - observations, tips and tricks malconium General Interior Topics 103 08-05-2015 03:51 PM
Insulation tips & tricks Sro Full-Timing 3 01-12-2014 09:26 PM
RV campground planning tips and tricks Mifair Member Introductions 23 10-25-2010 11:52 AM
New Full Timer any tips and tricks Court Member Introductions 2 06-08-2010 07:29 PM
