Welcome to the Forums!
There is nothing unique to rennovating a 23' Safari. They all, regardless of length, seem to have similar challenges, ie., rot prone floors, leak prone shells, etc..
Anyway, from your post, it sounds like you took possession of a trailer that has already had some work done. I would suggest that you start by verifying the condition of the floor and frame, and confirming that the work that has been done is done correctly, and isn't just hiding problems. After that, seal up everything you can (door, window, and hatch gaskets, plumbing vent gaskets, etc.), and once you are fairly sure it isn't leaking, then move forward with the interior rebuild. Are the interior walls in place, or are you looking at the inside of the shell (ie., exposed wiring, no insulation in the walls)?
good luck!
