Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle
Old 08-31-2009, 12:15 AM   #1
Profile:  2005 22' Safari
Gresham , Oregon
It's five a clock, somewhere
It is 5 a clock somewhere.
Where are you and What are you doing????
sempi2 is offline   Reply With Quote
Old 08-31-2009, 01:25 AM   #2
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough , winter home Zavalla TX
Hello... Well it is 2:20am here and I should be in bed sleeping but 2 cups of coffee early last evening are working at keeping me awake..
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30 (Costalotta)
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
Yamaha 3000
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 08-31-2009, 01:52 AM   #3
Mexray's Avatar
Profile:  1978 29' Ambassador
Stockton , California
It's 11:43 PM here, and I was just outside in the back yard enjoying a 'sip' before bed and watching the night sky with a really bright Jupiter showing it's stuff in the southern sky...
BTW...check out Heavens-Above Home Page for the latest visible passes of the International Space Station...the space shuttle hooked up today, and together they are really bright as they float by overhead numerous times this week...
Set the web site for your location, using 'Configuration'....then click on the 'ISS' to see the passes near you...if you click on a 'date' from the passes chart, you will then see a sky chart showing the pass - also, you can then click on the 'click here' just below the 'Ground Track' lable to see a better chart of the pass, along with the times, direction, etc...
If you haven't check it out, do so, I promise that when you see a bright pass near you, you'll be amazed at the eerie sight of the Space Station as is moves across the sky - it's especially bright when the Shuttle is hooked up to it!
There is also a section of the web sit that list Daytime passes of the ISS, and I checked one out just after sunup a couple of weeks ago and was able to spot the ISS - it's a bright silvery object after sunup, and if you can keep up with it using binoculars, it's another fun view!
Try it, you'll like it...
Let us not be too particular;
it is better to have old secondhand Airstreams than none at all.
Mark Twain, updated (org...diamonds)
AIR # 11135
1978 - 28 ft Ambassador (Blue Halo)
2001 - Ford Excursion V-10 4x4
Wall clock Zia Upholstery, Blinds, Walls & Interior Finishes 34 11-19-2008 11:13 PM
clock replacement goransons General Interior Topics 0 01-22-2008 11:40 PM
Led Clock DesertRat General Interior Topics 4 05-31-2007 05:09 PM
Clock / Thermometer balrgn Electrical - Systems, Generators, Batteries & Solar 18 10-23-2005 09:39 AM
digital clock sovereign General Appliance Topics 3 08-07-2002 12:21 AM
