Old 05-06-2015, 06:19 AM   #43
r carl's Avatar
Lin , Ne
Originally Posted by Boxite View Post
Why can't you control your own mice? (Is everything that occurs an Airstream QC fault?)
Never been a mouse in my Avion, no holes.
Old 05-06-2015, 07:12 AM   #44
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Mice
Difficult area to get good photo of but here they are. First is the wheel well area I spray painted it black to match and used black sealant. I cleaned out the large blob of sealant that AS used it was starting to loosen, then I cut a section out of roof flashing to match the hole plus enough over lap to have space to pop rivet it to the wheel well. If you look close you can see the seam. The tongue area was not a good photo but I found two small areas were the rounded banana wrap meets the frame I just put a very small amount of expanding foam. Then you can see the foil tape along the seam of banana wrap and belly pan any where I found any small gaps. Hope this helps. Rand
ID:	237880   Click image for larger version
grizbear is offline   Reply With Quote
Old 05-06-2015, 07:12 AM   #45
2015 30' FB FC Bunk
North Bend , Washington
Most glaring spot I found on our brand new trailer was around the dump valve lever rods. On ours they lazily cut out huge openings, then put flimsy rubber gaskets around. My solution was sheet metal flashing. Steel wool and sealant every where else.
spstream is offline   Reply With Quote
Old 05-07-2015, 04:54 AM   #46
palmtreegirl's Avatar
2008 25' Safari FB SE
Medina , Ohio
I'll be at the factory next week (Thurs and Fri) for some leaking repairs. I'll be using the tape and giving further inspections for possible holes.....going to check on those dump valves for sure. I can't stand mice!
Thank you, everyone, for the info on how you're handling this apparently common problem.
Liz, Brian and 3 Yorkies
The Silver Pearl & The Black Pearl
2008 25' Safari FB SE Queen converted to King
2014 Ford Expedition EXP Limited 4x4 V-8
McKesh towing mirrors
Centramatic Balancers
Hensley Swift-Arrow Hitch
palmtreegirl is offline   Reply With Quote
Old 05-29-2015, 10:14 PM   #47
CoolCat's Avatar
2002 27' Safari
Porterdale , Georgia
Fort Knox is not mouse proof!! I use various sizes of sealed containers to keep foods out of reach. I use sticky mouse glue pkts, very effective.
CoolCat is offline   Reply With Quote
Sufficient Sway Bar Tension? Frank&Mike Hitches, Couplers & Balls 7 10-29-2012 04:37 AM
Is my GMC sufficient? macstrange Tow Vehicles 8 12-06-2011 02:59 AM
Mice, Mice, Mice Jake General Interior Topics 21 12-01-2009 12:09 PM
New 2008 airstream *dwr* ccd * fully self sufficient * eBay Watch Airstreams on eBay 0 06-15-2009 01:30 PM
New 2008 airstream *dwr* ccd * fully self sufficient * eBay Watch Airstreams on eBay 0 05-21-2009 12:00 PM
