Old 06-03-2019, 08:55 AM   #1
VeloBuckeye's Avatar
2018 27' Flying Cloud
Easton , Pennsylvania
Interior aluminum type?
I am planning on adding/fabricating a "side-splash" (versus a back-splash) onto the laminate wall next to the stovetop. At times when using the burners, we've noticed the wall gets pretty warm. I'd like to use the same type of interior aluminum sheet in the AS to keep the look consistent, but I'm not sure of which type of sheeting and thickness to use. I think the interiors are .040/3004 alum, but not sure. Will be looking to buy a small sheet, maybe 2' x 3', then trim as needed to look original. Also, any suggestions where to purchase?
2018 27' Flying Cloud FB.
Any input is welcome. Thanks!
VeloBuckeye is offline   Reply With Quote
Old 06-03-2019, 09:22 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The challenge you have is finding a small piece of factory clear-coated aluminum. Some of the online dealerships (ie., Outofdoorsmart.com, InlandRV.com, etc) sell the factory coated sheets, so that is the first place I would check. If you buy something from your local aluminum supplier, you will get bare metal, and every fingerprint will turn into an oxidized blotch, unless you buy 2024 T3 Alclad, which will look diferent than your factory interior.
good luck!
Old 06-03-2019, 09:40 AM   #3
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
You might consider a thin piece of stainless instead. It's a little heavier and slightly darker than aluminum, but it might be better for this kitchen/stove top application.
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Old 06-13-2019, 05:48 AM   #4
Work in progress
Thanks all for the comments. Found a 3000 series sheet of aluminum, cut to size, then polished and coated it. Matches very well. Dry fitted it for now to get the boss's approval. Thinking about adding rivet heads to keep the look consistent.
VeloBuckeye
2018 Flying Cloud 27FB
2018 F150 Lariat PowerStroke Diesel
Old 06-13-2019, 06:19 AM   #5
1989 29' Land Yacht
St. Catharines , Ontario
I used 5054 then used Everbrite Protecaclear to coat it.
ktmkirby is offline   Reply With Quote
Type of aluminum used for interior skin on 60 Tradewind Bexar 1959-69 Tradewind 2 08-03-2017 09:05 PM
Best type of aluminum for interior walls? jmalexan Upholstery, Blinds, Walls & Interior Finishes 11 03-31-2015 07:47 AM
Interior aluminum type on 71' Darkspeed General Interior Topics 19 08-22-2011 05:29 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
