Old 10-09-2019, 11:46 AM   #41
2018 27' International
Georgetown , Texas
Watch your payload if towing with a half ton truck. Our Tundra's payload is only 1540#. 180# for the ARE cap, 20# for the Yakima rack, 950-1000# for the (loaded) trailer tongue weight (27FB), 100+# for the hitch/sway control, (for us) 33# for Rock Tamers...leaves you roughly 200# to share between people, gear, generators, extra fuel and water, any mods you've done to the truck, and whatever goes on the rack. We can pretty much run empty and be over payload.
YMMV depending on the TV of course, but many are in that range. Just make sure you do the math to see if this is even a safe possibility. Also weigh that tongue...I was going by AS spec at 890#, and lightly loaded discovered we had 1000# on the hitch on our last trip. Definitely a lesson learned. We were WAY over in this photo.
wayoutwanderer is offline   Reply With Quote
Old 10-09-2019, 11:52 AM   #42
Georgetown , Texas
Actually I think the rated tongue weight is also only including the first AC unit. I'm guessing some of that extra weight is coming from the "optional" AC in front. Optional isn't really optional if you live in Texas.
Old 10-09-2019, 03:23 PM   #43
2014 23' FB International
Topsham , Maine
Hi Peter, Iíve been looking for this solution since I already own the Hulivators. Your truck appears to be an F150 supercrew as is mine. Are those Thule roof racks as well?
Thanks George
Geobolduc is offline   Reply With Quote
Old 10-09-2019, 05:16 PM   #44
2019 27' Globetrotter
Cypress , Texas
JamesnPcola, we also have an 2019 F-250 and we are carrying two Hobie kayaks. We went with a Yakima Overhaul ladder rack and Thule Hullavators. Loading is much easier with the Hullavators. Although, I am not yet fully comfortable with the Kayak to AS clearance when making sharp turns.
ID:	353907   Click image for larger version
olgoat is offline   Reply With Quote
Old 10-09-2019, 05:57 PM   #45
2016 20' Flying Cloud
Cocoa Beach , Florida
This is a very informative post. I have a 2015 F-150 Super-Crew and are transitioning from my ARE hard cover tonneau to the Retrax Pro XR, as that cover will allow me to mount the Yakima Overhaul HD Truck bed rack.
I am working with e-trailer and plan on using the 78" crossbar to place two Thule hullavator racks to carry our two kayaks, weighing 50 pounds each. I was unable to place the racks on the truck cab roof due to weight restrictions, in addition to my concerns of lifting the kayaks up to the rack. We also plan on using the core locks to lock the racks and locking kayak cables to deter a potential thieves.
I did not, and now need to consider the additional weight - towing a 20 foot Flying Cloud. Estimated weight total = 240 lbs (100 kayak, 90 hullavator, 50 bed rack), do I need to adjust my Equilizer WDH? We are planning a 10 week trip and want to be certain we travel safely.
Any advise and input is greatly appreciated.
Thanks, Skip
Skip Stone is offline   Reply With Quote
Old 10-09-2019, 07:35 PM   #46
Cypress , Texas
SkipStone, don't forget to include the weight of the tonneau in your payload, 90# in the case of a short bed F-250. Others on this site have more expertise than I do on W/D systems, but I believe you will need to make adjustments.
I have this same combo. BTW first use of the Overhaul on the Retrax, damaged the tonneau rails, even though I followed the installation instructions exactly. Where the Overhaul attaches to the tonneau rail, the rails have deformed. Retrax is shipping me new rails but they believe it was due to over tightening the fasteners, even though I used a torque wrench to their specs. The attachment method needs to be modified so the load is spread over a wider area.
Old 10-09-2019, 10:05 PM   #47
1994 30' Limited
Fallon , Nevada
Hobie pro angler 14 rack
I have the rack that is made for a pro angler 14. I would like to tell you how it works and where you can get it. 775-741-2605
farmeric is offline   Reply With Quote
Old 10-10-2019, 02:13 AM   #48
JamesnPcola's Avatar
2020 26' Flying Cloud
Pensacola , Florida
First, I must say All of you are Awesome. I am very new to this community and did not expect such a tremendous positive response. My absolute gratitude to All of You! Iíve read every response and gotten some fantastic ideas! I failed to mention that the 2020 Hobie Pro Angler weighs 122.5 pounds dry. I know thatís heavy. Which unfortunately is to heavy for the Hullivator.
My truck is an f250 4door 4WD beast that can haul / pull anything. From all the excellent post from All of You, I think Iíve come up with a solution to install Yakima ladder racks on the bed with the roller assist on the back rail. Using a make-shift assist, removable pully system for the initial lift Up and removal Down from the rack. The next option is to find a travel partner in the future To assist me LOL😊.
JamesnPcola is offline   Reply With Quote
Old 10-10-2019, 07:56 AM   #49
richw46's Avatar
Lexington , Kentucky
When you get it all fixed up to suit you, don't forget to post pictures of your solution. This is a good thread that can help others in the future.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-11-2019, 05:01 PM   #50
EarStreaming's Avatar
2016 23' Flying Cloud
Hillsboro , Oregon
Thumbs up Look into EZ Rec Rack, it may help?
Here is my setup with a Thule Xsporter. That is a Hobie Compass Duo. I bought an EZ Rec Rack and as awesome as that rack was it didn't work out for me because I'm short and weak and when the trailer is unhitched, the rake is even higher It ended up to be a two person load and unload. I since bought a PWC trailer for the Duo and love it. I also ended up getting the Hobie Passport as our main yak when we camping The EZ Rec Rack may be something you should look into. I'd barter with you if you were closer but it's now collecting dust waiting to be sold or re-purposed
It's better to have it and not need it, than to need it and not have it. The importance of that expression doubles in significance if you made the conscious decision to "go without it" and then ended up needing it.
EarStreaming is offline   Reply With Quote
Old 10-12-2019, 01:40 PM   #51
sparkymark's Avatar
2012 25' FB Eddie Bauer
laguna beach , California
ID:	354117I love my Hobbie Revolution fishing kayak! I take it everywhere! Thule makes a simple rack that bolts to the bed
sparkymark is offline   Reply With Quote
Towing a 2 person kayak alymorales Towing, Tow Vehicles & Hitches 23 09-04-2017 03:40 PM
Bass Pro+Cabela's=Cass Pro? Hittenstiehl Off Topic Forum 16 03-09-2017 06:23 AM
14ft A&E/Dometic Awning Doctorpolish Airstream Classifieds 1 08-07-2015 10:54 PM
I want a Kayak..... Boondocker Off Topic Forum 21 11-14-2009 11:41 AM
