Old 05-01-2017, 05:26 PM   #1
2015 25' Flying Cloud
2012 19' Flying Cloud
Stillwater , Minnesota
How to store a full-size flag pole?
I have a yard size flag pole that I'd like to carry under the AS. It collapses to 6 ft long x 4" dia. The Valterra sewer hose carrier looks as if it would work, but before I go that direction I thought I'd check to see if there's an better answer that doesn't contain the word "sewer?"
Rod
StillRod is offline   Reply With Quote
Old 05-01-2017, 05:39 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Hose carrier, bumper compartment, on the floor or in a cabinet inside the trailer, bed or rear compartment of TV. Basically wherever it will fit and be out of the way.
MICHAEL
Old 05-01-2017, 09:34 PM   #3
2016 25' International
Deerfield , Massachusetts
Rod
Airstream makes flagpole carriers purpose built for this sort of thing. (Because so many WBCCI people carry flags). I haven't seen them listed in the catalogs though, so you need to call and inquire.
thiel is offline   Reply With Quote
Old 05-01-2017, 09:45 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy! we don't even use the sewer hose storage feature... we store the hose in the rear tray.
So, how about another PVC pipe under the AS? You can mount forward of the "sewer" storage... If you make it out of aluminum ... that would be cool.
The PVC doesn't cost too much... and you can use caps for sealing.
Of course you can get a genuine Airstream replacement and mount it forward of the existing one..
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-02-2017, 11:55 AM   #5
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
Yep I use the sewer hose pvc compartment for my 3 flag poles except we call it the flag pole holder. Painted the ends gray to match the trailer. It's mounted foward of the sewer hose tube.
Streamracer is offline   Reply With Quote
Old 05-02-2017, 12:03 PM   #6
timmaah's Avatar
1999 25' Safari
On , the road
I just leave ours in place on the hitch.
http://www.watsonswander.com/flag/
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 05-02-2017, 05:50 PM   #7
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
IiRC the Airstream sewer hose carriers are only 4' deep and the telescoping flag poles are longer. A PVC pipe would be better cut to the needed length.
guskmg
Old 05-03-2017, 12:25 AM   #8
2004 22' Safari
Albuquerque , New Mexico
Rod
I have one from Camping World. It comes in a nylon case and is about that length. Since the flagpole is one of the first things to be used (my unit has a plate that is positioned either under the wheel or under the tongue foot) and is the last to be packed, I just put it on the bed. It rides against the wall and is out of the way quickly when I set up. I don't see any reason to put more things under the trailer to drag on high ground when in non-level areas. Your mileage may vary.
Silver.Sanctuary is offline   Reply With Quote
Old 05-03-2017, 07:17 AM   #9
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I sometimes carry an antenna pole and 6' J-pole antenna, that is about what you describe only a little thinner maybe. Carried behind the backrest of the gaucho.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 05-04-2017, 08:13 AM   #10
Thanks for the ideas. I'm thinking I'll rearrange my bumper compartment and stow the pole in there. Alternately, underbelly in a PVC tube.
Flag pole holder grnthumbguy Exterior Restoration Forum 3 10-21-2017 11:23 AM
flag pole mounting and flag pole in general chrischarles General Repair Forum 42 08-09-2017 02:05 PM
rope and pole awning pole replacement link please greenrig Awnings 10 05-06-2009 12:52 PM
I Want a 5 Pole Flag Holder/Bracket myboyburt WBCCI Forum 45 12-28-2008 06:45 PM
Flag pole bracket/holder? Kistler Our Community 7 11-25-2003 10:29 AM
