07-19-2013, 06:07 AM
Itatiba
, São Paulo
Help to inspect a classic Airstream
Hello friends,
My name is Luiz and i am from Brazil, please forgive my english errors.
I am an american muscle car colector and i was lokking for a classic airstream to enjoy on our USA vacations and future send it to Brazil.
Finally seems to have found a very beautiful 345 diesel one and i am here to ask you if is there any classic as lover located at MN who can send me a detailed report of the vehicle.
Appreciate your help in advance.
Regards,
Luiz Eduardo Penazzi
Itatiba - São Paulo - Brasil
07-19-2013, 09:31 AM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings Luiz!
Welcome to the Forums and the world of Airstreaming!
Originally Posted by Luiz
Hello friends,
Regards,
You might also try clicking on the "Portal" button at the top of this thread . . . this will take you to the Forums homepage . . . on the homepage, observe the far right hand column and scroll down until you see . . . Airstream Inspectors . . . Select state and Type of Airstream -- then submit . . . you may find that there is a volunteer inspector near the Classic Airstream Motorhome in which you are interested.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
07-20-2013, 12:39 PM
Itatiba
, São Paulo
Hi Kevin!
Thanks for the information but unfortunately it seems there is no AS inspectors on Minnesota.
I tried the site rvsurvey and they told me that inspection was not available on that region.
I apreciate any indication.
Thanks again,
Luiz
07-20-2013, 01:08 PM
Princeton
, New Jersey
Try the above search and ask for trailer inspectors. There are several inspectors in Mn. and one of them may be able to help.
2004 Excursion 4x4
07-21-2013, 05:27 AM
Itatiba
, São Paulo
Mn inspection
Good morning friend,
Yesterday i found two private companies (lemon....?? and "wegolook") but when i placed the order their both sites do not accept billing adress outside USA and CANADA?
Luiz
07-21-2013, 07:26 AM
Wauwatosa
, Wisconsin
If you are legitimate, and i hope you are, you should really contact someone here on the forums to do an inspection.
If you are not legitimate, I see a scam coming.
Luiz
Can I send someone a check and they pay the bill? (then the check is no good etc.)
Judging a person does not define who they are, it defines who YOU are.
07-22-2013, 06:52 AM
Itatiba
, São Paulo
Hello,
I believe that i did not understand what you are saying.......
What do you think i am trying to do here??
By the way, can you go to Farmington, MN, and inspect Mr Carol Cooper's RV for me? How much it will cost me?
Luiz
07-22-2013, 08:35 AM
Itatiba
, São Paulo
airstream inspection
Hello!
I thank you all for the help.
Talked few minutes ago with "lemonsquad" team and thaey are able to make the rv inspection for me, i am just waiting for the reply of the seller to confirm if the vehicle is still available and if he can store it for me untill the date that i can travel to the US.
I hope to return to these pages as an AS owner!!!
Regards,
Luiz
