Old 08-29-2014, 07:46 AM   #1
2014 22' FB Sport
Atlanta , Georgia
Help! STAT! With my Dometic fridge
I'm a pretty new AS owner. We just headed out for a long weekend, and I switched the Dometic 'fridge to "Gas." It's giving me the blinking flame icon and the blinking triangle/exclamation mark/warning. I can't find this in the documentation.
Yes, the gas is on. (No, I don't want to engage in that debate again. If worse comes to worst, I get to buy a 25.)
As far as I know, both gas cylinders are at least 1/3 full. The burners on the stove light, so there's gas.
Can someone give me a quick answer on what's going on?
(I'm signed up for "instant carrier pigeon notification" so I'll get your responses right away. Thanks in advance.)
Belbein is offline   Reply With Quote
Old 08-29-2014, 08:20 AM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
First off, it is under warranty. Call the dealer or Dometic.
Dan
Old 08-29-2014, 08:21 AM   #3
Central , Mississippi
Your fridge is newer than mine but I will offer a suggestion from my experience. Sometimes mine fails to light after a bottle change and I simply turn off the fridge, count to 10 and turn it back on. It may take 2 - 3 times but eventually it gets gas to the burner and kicks off.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-29-2014, 08:25 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You can go to the Dometic webpage to download PDF versions of the manuals:
https://www.dometic.com/enus/America...ation-Manuals/
I don't know what model you have, or I'd download a copy myself and look it up for you.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 08-29-2014, 09:12 AM   #5
1998 19' Bambi
Parkville , Missouri
Also the 12v system needs to able to run the control board and provide the "spark" to start the heater and there by enable the frig to cool or the control panel needs replacing ...does the frig work on 110...........
MoBambi is offline   Reply With Quote
Old 08-29-2014, 09:20 AM   #6
If you get a blinking icon on the control panel, then you've definitely got 12vDC power to the fridge else the control panel wouldn't show anything (and apparently the control panel is working, too); but that's no guarantee that you've got spark.
WBCCI #1105
TAC LA-4
Help an HVAC noobie out... can I combine the furnace and A/C t-stat? Taylormade Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-16-2012 02:13 PM
Need Help Removing Silicone Caulk! STAT! Alumaholic Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 06-08-2007 08:21 PM
Signal Stat 9007 driftwood Electrical - Systems, Generators, Batteries & Solar 6 10-06-2003 06:57 PM
M52 fridge t-stat won't react Jabba Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-15-2003 06:57 AM
