Old 04-06-2010, 09:26 PM   #29
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
I believe the denim is a little heavy, but is a good insulator (when dry). I would pencil out the weight vs other options.
newroswell is offline   Reply With Quote
Old 04-06-2010, 09:37 PM   #30
2010 27' FB International
Miami , Florida
Originally Posted by tdturn2 View Post
My concerns with foam are the toxicity, VOCs, etc. Getting green gets confusing sometimes, because even though it may be "green" to recycle, with some things you have to weigh the pros and cons of having a toxic environment.
Cellulose based products are a viable option. It is made out of recycled products (straw, sawdust, ..). They typically use Borax as fire retardant with is non-toxic.
gamana is offline   Reply With Quote
Old 04-06-2010, 09:45 PM   #31
Ottawa , ON
Does propane leak carbon monoxide?
There is a special detecter for propane gas. I can't remember all the specifics, but the main item with them is that propane is heavier than air, so it pools at the bottom of your trailer. The detector mounts low, for this reason. It's also why your refer has a grill underneath it so that air (and propane) can flow directly out of the refer's little "house" to the outside atmosphere.
I'm not certain that a propane furnace can let off carbon monoxide, but it is the appliance that I treat with more respect than any of the others, simply because it is a potentially dangerous machine that works while we sleep.
Certainly a properly-functioning one won't give off dangerous gas, and yet we tend to keep them well past their useful service life. If you had a 34-year-old furnace in your home, I'll bet you would be getting it professionally checked at least annually, or replacing it.
What is a catalytic heater?
It's a propane heater that has no fan (usually) and does not use ductwork like your AS's furnace. It does not have an open flame, and uses a process that I don't really understand, but it seems to be popular with those who live in relatively warm climates who don't wish to replace their ailing furnaces.
Can you tell I don't trust them? And yet I can't say why. LOL!
Good. That means by 2016 when gas is insane, I should have saved up enough money, and the price should be decent enough on alternative technology that I can actually do something about the problem.
Egg-zackly! I love your attitude, it's what's going to keep camping alive for many generations to come.
Old 04-06-2010, 09:55 PM   #32
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
It's important to read the background information. Some spray foams have HFC and PDBE; Icynene doesn't. I'm not aware of any outgassing problems. I'm not selling the stuff, nor am I a scientist, but we wouldn't have put it in our coach if we didn't think it was safe.
If I were an environmental purist, I'd live in a yurt. Because I'm an environmental pragmatist, I can tow our '67 Airstream with a fossil fuel powered vehicle, preferably our '66 Dodge.
The Airstream is a wonderful travel trailer, but it is environmentally suboptimal. Even with a composting toilet, solar power, cork floors, etc., it is big, rolling aluminum compromise. This is not to deter you, but simply a gentle nudge. Even the most environmentally sensitive Airstream on the planet will involve trade-offs you won't have to make with say, a straw bale house. It's just the nature of making a structure mobile.
As for your questions, carbon monoxide is gas created by combustion. Propane is colorless, odorless gas. Carbon monoxide is also a color, odorless gas created by the imperfect oxidation (think combustion) of carbon. If you burn propane (or any carbon fuel), carbon monoxide is created... which is why ventilation is important.
Catalytic heaters use a flameless catalytic reaction of (normally) propane and oxygen to generate heat.
As for windmills, meaningful power generation requires a great site, height and steady winds. Solar is a much better fit for RVs. Efficient wind energy is much better suited for a proper, static location.
hampstead38 is offline   Reply With Quote
Old 05-17-2010, 08:05 AM   #33
1967 26' Overlander
Upperco , Maryland
I have done enough goofing around on the wheel well and bed frame. It's time to break out the Nature's Head and dry fit it so I can mock up the bathroom framing. When I have it out, I'll snap a picture.
Old 05-21-2010, 11:14 AM   #34
1967 26' Overlander
Upperco , Maryland
As promised:
Name:	NH front.jpg
ID:	103041   Click image for larger version
Name:	NH side view.jpg
Old 10-20-2010, 08:44 PM   #35
stephenh2's Avatar
Tyler , Texas
Terry,
We have been full-timing in our 31' AS for 4 months now. There are 4 of us, Me, wife, two children. We've been pretty happy so far. We spend a lot of time and elbow grease working on leaks, plumbing and electrical. Nothing major to replace so far. We homeschool, too. My wife and I are not living off the grid. We live as conservatively as we can in an RV park. I have lived in Texas all my life and could not stand summer heat/humidity without air conditioning. We will convert our systems to greener ones as they need replacing. I reuse everything that I can.
Not sure where you are moving to, but we are in central Texas and not too far from San Antonio. Might get to say 'hi' sometime. Notice you haven't posted in awhile, how's the rebuild going?
On tow vehicles: a standard diesel truck, one of the older models, will burn biodiesel without modification. Some pretty standard mods can make it burn waste vegetable oil. There is plenty of info on the web about it. The newer trucks, like my '05 Suburban, will burn 80% ethanol. I have a cousin who used to have a solar 'still to make ethanol.
Safe travels,
Stephen
Home again in Tyler, Texas
Please visit any time!
stephenh2 is offline   Reply With Quote
Old 10-24-2010, 07:53 PM   #36
1976 31' Sovereign
Memphis , TN
Green Streaming
My husband is a certified green builder... He suggests Isonyne insulation.. It's soybean based... Not sure of the outgassing- we are still researching... Bamboo is heavy- have you thought marmoleum? Hope this helps!!
pfisher is offline   Reply With Quote
Old 06-23-2011, 09:29 PM   #37
greenrvlife's Avatar
2003 25' Safari
alameda , California
tdturn2 - just found this thread. Great questions and comments. So are you on the road full-time and how is it going? We are on a similar path...
Brenda and Cece
www.greenrvlife.com
2003 25' Airstream Safari
Veggie powered 2006 Dodge Ram 2500
greenrvlife is offline   Reply With Quote
Old 08-11-2011, 09:29 AM   #38
2003 25' Safari
Just checking in to see how other folks are coming along with their green remodels, additions. Ours is about done.
Brenda and Cece
www.greenrvlife.com
Old 08-12-2011, 05:44 AM   #39
1976 31' Sovereign
Memphis , TN
Soo luv your remodel especially the cabinets... Can you share if you custom made them? We haven't started yet because I have to redo everything and due to the economy we arent there yet..... Although, I am still sourcing and planning what I'm going to do. What did you end up putting on the walls? Also bamboo flooring or vinyl? I know vinyl isn't green but it sure weighs less...can you share a picture of your bathroom? Thanks - so happy that you are almost there!! Congrats!
Pam
Old 08-12-2011, 07:41 AM   #40
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
Love the pics! I have two '95 motorhomes (Classic 36 & Land Yacht) that I'll be trying to make as "green" as possible with possible biofuel conversion and so forth...
Also, a '67 Caravel that will be the "in-law" suite that we definitely want to make comfortable and green!
GREENovaters is offline   Reply With Quote
Old 08-12-2011, 01:28 PM   #41
2003 25' Safari
Hi Pam - Thanks for the love. We used the existing cabinetry since it was already a perfect fit and in great shape. We just wanted to give it a fresh modern look with a sustainable product and that's where the eco veneer came in. We did it ourselves with the help of our cabinet installer sponsor. turned out great but an FYI that it does take many hours of time - but worth it! Here's the shower with lumicor recycled plastic (they sell lower cost remnants too). There are more detailed photos on our site too:
Brenda and Cece
www.greenrvlife.com
compost, green, non-toxic, solar, sustainable
'streaming with a bicycle jeneric Tow Vehicles 23 03-26-2010 05:57 PM
New to 'Streaming and need help! AirsDream Member Introductions 4 11-21-2008 10:21 PM
Not new to Air Streaming hutch309.2 Member Introductions 5 02-23-2008 07:18 AM
Streaming' at Glamis.... Kestrell On The Road... 2 05-23-2005 10:13 PM
Streaming............... till Off Topic Forum 4 04-20-2004 03:56 AM
