Yes, the general consensus here on the Forums is that covers that touch the surface are not a good idea for the care and feeding of your Airstream for reasons mentioned above. It sounds counter-intuitive, but if you've ever seen the result of a tarp or cover rubbing on an Airstream's skin you would be convinced. Many store their Airstreams in the open air and survive fairly well (outside of potential hail and storm damage), but the better solution is a sturdy roof overhead. Even better is inside storage with climate control. But not everyone can manage that. Check out local storage facilities and see what you can find. You might find something just right!
We store our Bambi under a "port" attached to the end of our house...with canvas tarps on the exposed sides of the "port" to keep off as much direct sun as possible. It is never in direct sunlight or the elements unless we are traveling. I have to say that this has been a very good thing for our rig ...
Good luck with your new baby!
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
