Old 02-15-2014, 02:06 PM   #1
time2play's Avatar
2013 30' Classic
Kent , Washington
Gap in backsplash
Hello
We have a 2013 30' trailer, and I'm hoping to get your opinion on this.
We have a "gap between the backsplash and the wall of the trailer in the kitchen behind the kitchen sink.
Here are a couple of pictures of this gap.
http://yolanda.smugmug.com/Other/Air...0/L/gap1-L.jpg
http://yolanda.smugmug.com/Other/Air...0/L/gap2-L.jpg
Basically, I'm hoping to find out if you have a similar problem in your trailer. And how did you "fix" it. What about caulking or sealant? Any other solutions?
Just as an FYI - I contacted Airstream and it is not covered under warranty. However, they have offered to authorize the dealer to apply a bead of clear sealant along the back edge. Before accepting their offer, I thought it would be a good idea to see what you all think.
Is there a better solution to this problem? Or is it even a problem?
Thanks for your input.
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 02-15-2014, 02:17 PM   #2
Firedog1
Firedog1's Avatar
2015 30' Classic
Woodbridge Connecticut & , Venice Florida
gap in backsplash
Here is a suggestion, find someone at from a body shop that has a set of suction cups, they use them all the time to pull dents. attach couple of suction cups to the backsplash, fill the gap with clear silicone sealant and pull (gently) the backsplash out until flush with corian counter,then brace it overnight until sealant hardens. Good Luck.
Firedog1 is offline   Reply With Quote
Old 02-15-2014, 02:24 PM   #3
cameront120's Avatar
1972 25' Tradewind
I vote for 'not a problem'. In a vehicle that moves, it makes some sense for there to be that gap to allow free movement between the counter top and the trailer shell. If you decide to run a bead of sealant, I'd not use silicon as that can etch the aluminum.
North Vancouver, BC
Old 02-15-2014, 03:24 PM   #4
dznf0g's Avatar
Oswego , Illinois
I don't believe it is a problem. Sealer will just pull apart and look bad. There must be the ability for the wall to move independently from the counter.
Sent from my XT907 using Airstream Forums mobile app
-Rich-
Old 02-15-2014, 04:33 PM   #5
2002 30' Classic
Ocala , Florida
Had a problem gap in my 30' Classic behind the sink. There was a screw that held the counter top in place that had worked loose. It was a constant problem re-tightening as it was not into a structural member only the skin. Solution was a moly rivet that expands like an Olympic. Problem has not returned in 5 years. Check to see if the problem may be a screw that worked loose.
Bigdaddy_2 is offline   Reply With Quote
Old 02-15-2014, 07:40 PM   #6
time2play's Avatar
2013 30' Classic
Kent , Washington
Thanks everyone for your comments and feedback!
Before I contacted Airstream, I took a look at a couple of other trailers on the dealer's lot, trailers which had the same backsplash. None of them had the gap. They all looked pretty tight against the wall. I guess I just wanted mine to be the same.
I feel like it will be very easy for water to splash into the gap. I'll have to remember to cover it up each time I use the sink.
I appreciate all your suggestions. Bigdaddy - I'll check the screw, see if maybe that's the problem.
Yolanda (and Phil)
WBCCI #7878
Old 02-15-2014, 08:41 PM   #7
1972 25' Tradewind
Keep in mind that the metal will expand and contract so those trailers that you saw with no gap may, in fact, now have them. When temperatures warm (or cool) you may fine the gap disappears. Remember, theses things move constantly (even when not being towed) and wherever materials join there is going to be the potential for seeing evidence of theta movement (expansion and contraction).
North Vancouver, BC
Old 02-15-2014, 09:31 PM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Silicone can be a nasty material if you ever want to remove it from a place like that, nearly impossible. And like others said, there will most probably be continued movement of that junction that will cause silicone to separate and not in a pretty way.
Look at the Flying Cloud models. They use an aluminum strip in that junction to close the gap somewhat like flashing. Part of the T-profile strip rests on the counter edge but allows the counter to move under it. Maybe Airstream can provide a section of this material as a fix.
I sort of understand why they do not warranty this because there really isn't a failure, but a poor fit of parts. They may consider crud falling behind the counter okay but I wouldn't like it. Have you talked to Airstream Customer Service; maybe they will authorize something better than silicone if you suggest it.
Doug and Cheryl
Old 02-18-2014, 02:38 PM   #9
time2play's Avatar
2013 30' Classic
Kent , Washington
Thank you Doug. That's great advice about the Flying Cloud. I'll explore that option.
Yolanda (and Phil)
WBCCI #7878
How to attach aluminum backsplash dznf0g Cabinets, Counter Tops & Furnishings 29 03-04-2012 07:41 AM
Gap between floor & frame at the rear end ASNomads Repairing/Replacing Floor &/or Frame 6 01-30-2012 05:09 PM
How to enlarge gap on window bar to accept new window vitzman Windows & Screens 9 09-20-2011 10:45 PM
Aluminum backsplash.. prevent scratching? timmaah Upholstery, Blinds, Walls & Interior Finishes 6 09-18-2011 09:01 PM
Trim to cover gap between wall and floor? adwriter73 Floor Finishes 5 02-20-2011 11:02 PM
