Old 03-29-2013, 07:22 PM   #1
1999 28' Excella
New Orleans , Louisiana
Fulltiming in my 28' AS
Wrote many months ago about never being in an AS but wanting to fulltime in one. It has happened and is so far a wonderful expereince. Love how so many things are simple. Had the brakes and bearings done. Leaving N.O. on Friday for Chicot State Park so we can go to Fred's Lounge in Mamou on Saturday morning for cajun music. Then off we go slowly to the NW waiting on the snowfall to turn to spring. We have a website www.lifeonthebluethehighways.com after Blue Highways by William Least Heat-Moon with his blessing. Great book. Stay tuned..
badkat is offline   Reply With Quote
Old 03-29-2013, 08:01 PM   #2
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
Sounds like a wonderful adventure and Chicot State Park & Cajun music is a great way to start! Good luck.
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 03-29-2013, 08:10 PM   #3
Jim Clark's Avatar
2012 28' International
The Mamou two-step, have fun.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 03-30-2013, 12:47 AM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
Correct url?
Life on the Blue Highways -
Old 03-30-2013, 05:13 AM   #5
Lily&Me's Avatar
Normal , Illinois
Mmmmmm, leaving NOLA and heading to Chicot State Park. Love them both,
We found our Miss Lily at Chicot in October 2010.
Life on the road is a grand experience. Have fun and travel safe.
Msggie
Old 04-02-2013, 09:29 AM   #6
1999 28' Excella
Since we are fulltiming and have learned a lot about our AS with much more to come..need help with the fresh water tank. How much water does one normally carry, how often should you change and how do you empty it? Does that sound like a newbie are what? thanks for any and all help!
Old 04-02-2013, 10:34 AM   #7
SStar's Avatar
2004 28' Classic
Midland , Texas
I'm envious, wish I was with you, maybe in September. If you know you are going to be in a park with full hookups there is no reason to keep your FW tank full. Just keep enough for flushing while on the road. Water at 8.34 ppg = 300 pounds of additional weight for a full tank= fuel usage. To empty the FW tank just turn the shore water off and run your water pump to empty it into the grey/blackwater tanks, then dump it. Don't leave fresh water in the tank for any length of time, especially in hot weather, bacterial will grow. A few drops of clorox in the tank will kill bacteria, there are also various commercial products. Don't drink the water coming through your water system, too much possibility of contamination. Good luck and good travels, we'll watch your progress.
SStar is offline   Reply With Quote
Old 04-02-2013, 10:40 AM   #8
1999 28' Excella
Thanks...will get it done!
Old 04-02-2013, 11:06 AM   #9
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Your Excella is the same year as ours. Nice choice. Fill the fresh tank until it overflows out of the little hole next to the input opening. We try to travel with at least half a tank for flexibility in choosing a site, but I often start with a full tank. Some folks tell us you get better mileage by running nearly empty, and fill up at the camp. You empty it from underneath. There are two ways: A small white "spigot" valve between the tires on the Curb Side (which you will likely break at least once), OR a bigger drain plug underneath, which you get to by unscrewing the cover plate on the bottom of the underbelly, just behind that little plastic spigot thing after you break it <grin>.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 04-02-2013, 12:22 PM   #10
1999 28' Excella
Too funny....the whole campground heard me laughing.
Old 04-02-2013, 05:10 PM   #11
SStar's Avatar
2004 28' Classic
Midland , Texas
As I said, we drain ours through the sink, haven't been able to talk the missus into crawling under the trailer since she did it the first time. Dang narrow minded woman anyway!
Old 04-02-2013, 07:18 PM   #12
airstreamhobo's Avatar
Hello BadKat , if you go to Fred's this weekend you will see The Cajun Caravan there. We were ther 3 weeks ago and had a Blast. There should be about 50 people there from the Airstream Group. Have Fun !! AirstreamHobo
AirstreamHobo
Lancaster Co. Pa.
1999 28' Excella
Ford Diesel Van "The Obie Van"
WBCCI #2590
TAC PA-2
http://airstreamhobo.blogspot.com/
airstreamhobo is offline   Reply With Quote
Old 04-03-2013, 09:16 AM   #13
1999 28' Excella
WOW..thanks for the heads up!
Old 04-03-2013, 03:58 PM   #14
beaubill57's Avatar
1992 25' Excella
2002 25' Classic
Daphne , Alabama
BadKat--- put some water in the holding tank --- curb side of trailer --- add some Clorox --- let it set for awhile or drive around to stir it up --- reach between the curb side wheels and open the drain valve and let the water drain out --- when the water stops coming out, add some more water to the tank and let that water run out---this is to rense out the tank.then close the valve between the wheels and add some water for use. Remember when using the water from the holding tank for drinking or cooking run the water through the water filter on the counter. I keep about 10 gal in the holding tank when traveling so I can use bathroom and sinks. I usually drain the holding tanks about every 2 weeks if I don't use the water up when traveling.Hope this helps ---Bill
2002 Classic 25 "The Silver Sleeper"
beaubill57 is offline   Reply With Quote
Seattle Fulltiming? MORA Full-Timing 7 06-05-2013 05:37 AM
Saving money Fulltiming - Legend or Fact? Foiled Again Full-Timing 59 05-14-2012 09:11 PM
Water in 19' Bambi & Fulltiming zlee Full-Timing 2 11-18-2011 01:13 PM
