Old 02-21-2015, 12:02 PM   #15
johncook's Avatar
2007 27' Safari FB SE
Mesa , Arizona
I juut installed a front receiver on my 2500 Silverado. This is better than the back of an AS
Puresilver
johncook is offline   Reply With Quote
Old 02-21-2015, 02:49 PM   #16
HandyGuy
Vancouver , British Columbia
Front bike racks: Lessons learned...
I have had two front receivers mounted previously on my '96 Dodge 2500 and '04 Dodge 3500 for transporting up to 4 bikes.
I too encountered some distraction from constant bike movement. To solve this I used to take a wooden stick (or tapered clothes pin) and drive it into the space between the bike rack and hitch mount. Sometimes these temporary "fixes" would fall out and need to be redone. Never had the unit jam and not be able to remove it though.
When I installed the 2nd hitch on the newer vehicle, I spoke to the welding shop staff about this problem. Their suggestion was to drill a single 5/8 hole, tack weld a "nut" on the outside of it and add a matching bolt (3/4" long) for tightening. This acted as a "locking" mechanism. This was done just forward of the normal rack pin hole. It worked great to stop the bouncing bikes. You still get some wiggle on the bigger bumps but overall the movement is much more subdued and no longer acts as much of a distraction.
WAWood99 is offline   Reply With Quote
Old 02-21-2015, 07:30 PM   #17
1966 20' Globetrotter
2008 23' International
Cedar Falls , Iowa
Send a message via AIM to hahnstead
I use a front hitch receiver to carry two bikes and have no problem driving this way. I remove the seats from both bikes and set the bikes on the rack so that the handlebars of both are on the passenger side. Much better than carrying the bikes on the back of your Airstream.
Hahnstead Airstream Park
hahnstead is offline   Reply With Quote
Old 02-22-2015, 05:36 PM   #18
casarodante's Avatar
2012 31' Classic
We have a front hitch and use a bike rack also. Here are some pics. The out the window pic is with our older F250 but our newer one has a higher hood so you see less of the bikes.
ID:	232924   Click image for larger version
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 02-24-2015, 12:00 PM   #19
MontyV's Avatar
1994 34' Limited
Salem , Oregon
we went a different way with out bike rack. We bought an adjustable resin bike rack from REI it is mady by Thule. I can send a picture over the weekend but I do not have one on my computer. We mount it on the pick up bed tail gate. The bottom rests on the bumper, for us the top arms rest on the cover. It is adjustable enough to work with a canopy of you have one. Once the bikes are loaded we tilt the arms up a couple of degrees and there is no risk of the tires coming into contact with the any part of the hitch mechanism and we can not turn tight enough to risk contact with the body of the AS. an added benefit is that we can run a bike lock cable through the bikes and rack and around the tail gate to secure them if we are away from the TT.
MontyV is offline   Reply With Quote
Old 02-24-2015, 01:40 PM   #20
87MH's Avatar
1978 31' Sovereign
Images: 292
Front Bike Rack
I need to post on the negative side of the front bumper mount.
I have front mounts on both the F 250 and the Excursion.
I have found that the bikes interfered with the street vision on both vehicles. I posed the question to myself that if an officer of the law stopped me could I convince him that my vision was not obscured. I honestly could not justify taking a chance.
Maybe the OP could borrow one for a test ride with a bike on the front of his tow vehicle to determine how much his front vision would be obscured with the bike(s) mounted on the front.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 02-24-2015, 02:35 PM   #21
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Same Issue
Thought I might have the same issue with the headlights being obstructed by pieces parts of bikes and reverted to using my driving lights and they worked well.
tsunami is offline   Reply With Quote
Old 02-24-2015, 07:36 PM   #22
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Negative on the front bike mount. Although it is really handy to have the bikes with the tow vehicle, a really good mount in side the Airstream is the safest way to carry the bikes. I carry mine on the roof but only when I am going a short distance in order to use the bike. The rest of the time it is inside. Road salt, gravel, bugs, and miscellaneous garbage will all find their way into the drive train. If it's a cheap bike, maybe it doesn't matter. If it's an expensive carbon fibre road bike, it matters a lot. At least to me. Jim
Jim Flower is offline   Reply With Quote
Old 02-25-2015, 11:46 AM   #23
2007 28' Safari SE
Deland , Florida
front bike rack
I have a Reese Hitch for the front of my tundra-have used it on a 2009 Tundra and a 2014 Tundra-works great-does not impair my vision-I secure both bikes with straps and bungee cords for added strength-good luck-better than a back mount
Jeffg24 is offline   Reply With Quote
Old 02-25-2015, 09:57 PM   #24
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
I am in favor of a front mounted rack also. I have one on my MH. The only distraction I had was the bikes front wheel spinning. The wind would push on the reflector like a windmill and make it spin. A short bungi cord fixed that. Here's a link to my photos.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Bike Friday / Swift Folder / Airnimal folding bike? 85MH325 Off Topic Forum 47 09-26-2008 06:21 AM
Household chemicals Yes, yes or No, No? thecatsandi On The Road... 3 03-27-2006 07:01 PM
bike rack mount on rear of AS trailer rmmm68 Repairing/Replacing Floor &/or Frame 7 11-26-2002 10:55 AM
Bike Rack ALANSD Our Community 3 03-19-2002 10:57 AM
